PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Feb 18, 2018 at 4:16 PM
    #1481
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    I wouldn't think these lifts would cause any dramatic increase in bearing wear due to the relatively low lift and angles associated. I thought about doing the ECGS but figured I would wait and see if I had a problem first.
  2. Feb 18, 2018 at 4:20 PM
    #1482
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    I'd like to hear some reports with that setup too.
  3. Feb 18, 2018 at 4:21 PM
    #1483
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    I feel slightly better knowing I'm putting a Toyota suspension on a Toyota truck but still, you never know.
  4. Feb 18, 2018 at 4:27 PM
    #1484
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    Yeah same, I'd at least be more confident taking it to the dealer if I suddenly have major vibes shortly after installation.
    The lift was supposed to be minor with this kit, but some are reporting 2" up front which is definitely in ECGS replacement territory. I don't know what I'll do yet. My set should arrive this week, but it'll be a few months before I get to installing.
  5. Feb 18, 2018 at 4:44 PM
    #1485
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    FYI, my bearing issue popped up with the installation of a leveling kit. Then I went back and added the ECGS. Personally I would plan for the Ecgs at the time of suspension installation if you don't already have it . You will save yourself some labor
  6. Feb 18, 2018 at 4:51 PM
    #1486
    ryager
    ryager Well-Known Member
    2017 Orange TRD OR
    0... it is a Toyota product. It is a Toyota suspension being taken from the PRO. The PRO is not special so how many bearing failures happen on the pro?
    NMTrailRider likes this.
  7. Feb 18, 2018 at 5:05 PM
    #1487
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Hmmm no. It happens to stock trucks. Toyota product or not for lifting, The needle bearing is a flawed design...
    However people can go 70k with no prob and others 1 mile down the road and have the problem.
    Lt. Dangle likes this.
  8. Feb 18, 2018 at 5:15 PM
    #1488
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I might get around to doing my new next week. Maybe.
    rooster32 likes this.
  9. Feb 18, 2018 at 5:20 PM
    #1489
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    yup, exactly.
  10. Feb 18, 2018 at 6:00 PM
    #1490
    ryager
    2017 Orange TRD OR
    That is true, the engine could also grenade in 2 miles and things like that. Saying that the lift from Pro shocks is going to cause bearing failure makes no sense. The PRO does not have anything different besides the suspension. So that would mean that the PRO would have a crazy amount of bearing failures. If this is the case then yeah bearing failure is going to happen. If it is not the case then it will be fine on the 99.99 percent of vehicles. We are talking about upgrading from a part that comes from the factory that is not known to cause any issues.
  11. Feb 18, 2018 at 6:11 PM
    #1491
    Lt. Dangle
    Ohio
    Installing any lift period is known to potentially cause bearing issues on any Tacoma built in the last 20 years. I'm confused on why this is even discussed.
    Dave4ep, oscolivar1 and pismo61 like this.
  12. Feb 18, 2018 at 6:12 PM
    #1492
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Amen.
  13. Feb 18, 2018 at 6:21 PM
    #1493
    ryager
    2017 Orange TRD OR
    Because it is stock that is why I am confused. It is a stock suspension and nothing special was put into the pro.
  14. Feb 18, 2018 at 6:22 PM
    #1494
    Lt. Dangle
    Ohio
    And? You don't think some of them had noisy bearings?
  15. Feb 18, 2018 at 6:23 PM
    #1495
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Toyota already knows the needle bearing is an issue as there is a TSB on it but doesn't exactly fix the issue with the replacement. It just a band aid fix.
    The needle bearing is the same one used from the 1st gen to the current model and has been a known issue.
    You can believe what you want but for those reading. Just be aware of the things that can happen if you lift with a spacer, a "TRD PRO" lift, aftermarket etc.
    Otherwise enjoy your lift! I have the 6112/5160. I did the ECGS fix before I lifted because I don't want the vibes if it did ever happen to me. PIECE OF MIND!
    Costs 150 for the ECGS shop for labor/parts to install
    pismo61 likes this.
  16. Feb 18, 2018 at 6:28 PM
    #1496
    Lt. Dangle
    Ohio
    Keep in mind that they only made like 1200 pro's with this setup. You don't hear much about bearing issues on the pro because they didn't make many. Now look at all the other Tacoma's that have had bearing issues after lifting. It's millions of Tacoma's. That's why there is a known issue with the setup.
    It's a known crapshoot.
    oscolivar1 likes this.
  17. Feb 18, 2018 at 6:32 PM
    #1497
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I'll clear things up...picture below is the stock needle bearing also known as a Piece of *hit. Those Teeth or needles tend to break over time or immediatley after any lift or even stock.
    Continue on with peoples review on the TRD pro suspension. :thumbsup:
  18. Feb 18, 2018 at 6:45 PM
    #1498
    wjrichardson
    WI
    2017 TRD/OR/AC
    Is this the guy? https://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    oscolivar1[QUOTED] likes this.
  19. Feb 18, 2018 at 6:49 PM
    #1499
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
  20. Feb 18, 2018 at 6:49 PM
    #1500
    Lt. Dangle
    Ohio
