PTR13-35150 - Bilstein TRD PRO kit - Upgrade??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by commbubba19, Jan 22, 2018.
  1. Jan 25, 2018 at 7:13 PM
    #141
    tow-coma
    tow-coma Well-Known Member
    I hope the droop is the same as the regular 5160. You can only lift 2-2.5 inches over stock with the smaller 5160, which i think these are.
  2. Jan 25, 2018 at 7:16 PM
    #142
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    2" is all i'm looking for so I hope you're right.
  3. Jan 25, 2018 at 7:18 PM
    #143
    tow-coma
    I hope so, for your sake. Bilstein makes 2 different sets if 5160 for Tacoma. I believe the cut off is 2 inches over stock rear lift. The bigger ones won't compress all the way with a smaller lift and the smaller won't droop all the way with a larger lift.
  4. Jan 25, 2018 at 7:22 PM
    #144
    Lt. Dangle
    Ohio
    I'm not too concerned*. I don't do much that requires lifting and flexing outside of trails and dirt and mud. No rocks.
    * I am...
  5. Jan 25, 2018 at 9:44 PM
    #145
    crowder
    crowder Active Member
    I have the same set-up, but I have the longed. Need to raise the rear a tad. How exactly did you raise yours and how did it impact the drive?
  6. Jan 25, 2018 at 9:46 PM
    #146
    RAV3N
    RAV3N Well-Known Member
    24 TRD O/R
    That’s correct. Also I don’t know if the life of the rear shock will be affected by adding blocks or AAL since it is not designed for a lift.
  7. Jan 25, 2018 at 10:06 PM
    #147
    lees17taco
    lees17taco New Member
    Denver, CO
    17 TRDOR DCSB
    RCI sliders/front skid, Bilstein 6120/5160, TRD Pro grill, Depo Pro Tails, duratracs
    Just pulled the trigger on this set up from olathe toyota $625 shipped. I read the kit comes with two notches on the front, driver is set higher, what are your thoughts on putting both on higher setting then adding a 1/4 inch spacer for the taco lean (thinking headstrong's $29) to get a little more lift? Also saw in another thread someone added an icon 1.5" add a leaf with this package, which sounds like that should help level it out. I don't have topper so 2" in the rear sounds too high
    Dylla34 likes this.
  8. Jan 26, 2018 at 12:44 AM
    #148
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    I used 2” blocksfor the rear. Keep in mind the weight of the shell, platform and gear gives it just a slight riseto level in the rear.
    It rides fine. Actually, I can see across the hood better too.
  9. Jan 26, 2018 at 1:50 AM
    #149
    tow-coma
    this is what we are talking about above this.
  10. Jan 26, 2018 at 4:45 AM
    #150
    Lt. Dangle
    Ohio
    That's what I did to give me some more adjustability.
  11. Jan 26, 2018 at 5:45 AM
    #151
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Right. Per my old research when I had my 2G at the time 5160s were designed for 0-1" of lift, which is the big reason I went with the 5100 that could supposedly tolerate 0-2" of lift per DownSouth Motorsports.
    I'd be hesitant to run 5160s with a lot of rear lift.
  12. Jan 26, 2018 at 7:47 AM
    #152
    tow-coma
    Is it only 1 inch?! I thought I read 0-2 inches. Maybe I was reading 5100
    @Lt. Dangle
  13. Jan 26, 2018 at 8:03 AM
    #153
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  14. Jan 26, 2018 at 8:19 AM
    #154
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
  15. Jan 26, 2018 at 8:43 AM
    #155
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
  16. Jan 26, 2018 at 9:13 AM
    #156
    pocketsmcaaron
    Oregon
    I liked them, they handled well. I ended up though switching to KO2s as I wanted a 6 ply. Toyos offfered either 4 or 10 (too heavy imo).
  17. Jan 26, 2018 at 9:32 AM
    #157
    backcountryj
    Jonathan
    GA
    They offer them in 255/80/17 with a reported weight of 50lbs. Which for a 255 is actually a featherlight. There doesn’t seem to be much feedback on the forum about that tire in general, and I’m not aware of anyone trying them in 255 yet.
  18. Jan 26, 2018 at 9:47 AM
    #158
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That's a tire I was looking into as well. Some 255 look really skinny and some look good. I'm trying to find a picture of an actual tire to see. Sidewall design plays a big part in the look.
  19. Jan 26, 2018 at 10:01 AM
    #159
    backcountryj
    Jonathan
    GA
    I agree on the sidewall. A coworker has the open country’s which he really likes. I think they are similar to what folks are saying about the Falken atw3, they look better in person.
    255s are definitely skinny, but on the right wheel they don’t look dinky. I had 255s on SCS s6s on my last truck, 17x8.5, and I didn’t think they looked skinny at all.
  20. Jan 26, 2018 at 10:27 AM
    #160
    pocketsmcaaron
    Oregon
    Part of the reason I switched to trd 4 runner wheels- better off set and you can place a c rated tire on them. Ko2 c rated 265-70-r17 are 45lbs. I believe toyo e rated are over 50 lbs.
