Pulled out a GMC Canyon in loose sand using 4LO In reverse. 2016 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma_2016, Feb 27, 2018.
  1. Feb 27, 2018 at 1:25 PM
    Tacoma_2016
    Tacoma_2016 [OP] Member
    2016 TRD Sport
    So yesterday I pulled out a 2016 GMC Canyon SLE in loose sand. This was my first time ever pulling a stuck vehicle out. I was in 4LO and pulling in reverse. I was heavy on the gas and was at about 6-8 RPM... I realize now how stupid it was. Any recommendation on how I should pull others out in the future? Should I check my differentials, Transmission or any other components for damage?
    Thanks
  2. Feb 27, 2018 at 1:27 PM
    Tacoma_2016
    2016 TRD Sport
    The dude was pretty stuck and was giving some assistance but not much.
  3. Feb 27, 2018 at 1:29 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Pull in the forward direction if possible. Your ring and pinion are weaker in reverse. Also some form of kinetic strap.
  4. Feb 27, 2018 at 1:31 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Tow straps, 2 tree savors, 3 shakles, a pully and a winch or come-a-long... on beach towing is the only way unless shovel and pcs of rug... and beer. Dont forget the beer.
    You did you good deed for the day. Prop yerself up and do some elbow bends, courtesy of the Canyon owner... wait thats a big truck bro.. manual or automatic tranny?
  5. Feb 27, 2018 at 1:33 PM
    Tacoma_2016
    2016 TRD Sport
    Automatic.
  6. Feb 27, 2018 at 1:59 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Did it smell like burning paint or burning rubber?
  7. Feb 27, 2018 at 2:08 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ive pulled out sandburbans, sandundras, a mudahoe and a sandodge with my 1st gen automatic in reverse 4low with the locker on- no problems there.
    Tacoma_2016[OP] likes this.
  8. Feb 27, 2018 at 2:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What kind of strap were you using? That's the biggest thing. Most standard "tow straps" that you find in stores are static straps, meaning they don't stretch. You take out all slack and gently pull with those. In most off road scenarios, this is useless.
    The solution to that is a kinetic recovery strap/snatch strap, one that stretches. It's essentially a giant rubber band that stretches and allows you to get a running start to yank them out, all while remaining smooth. Here's one that I use and recommend.
    https://www.amazon.com/ARB-ARB705-2...pID=51aCdObtztL&preST=_SX300_QL70_&dpSrc=srch
    Here's a short 26 second video demonstrating the difference between the two.
    https://www.youtube.com/watch?v=WLJjXQYOKGk
  9. Feb 27, 2018 at 3:25 PM
    Tacoma_2016
    2016 TRD Sport
    Didn't smell like anything burning.
    I was using a static strap, all we had. Started pulling slow. Getting the tension out of the strap applying more and more gas.. got the job done but at some points I was at 6000, 7000 RPM.
    The kinetic recovery strap is awesome. Truck has been running fine since so I think I'm in the clear. Ill make sure to pick one up.
    EatSleepTacos likes this.
  10. Feb 27, 2018 at 3:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Once you get it, make sure you have a proper point to connect it. I'm a huge fan of these, that go in the hitch.
    https://www.amazon.com/USA-Receiver...&qid=1519774106&sr=8-4&keywords=hitch+shackle
    If you frequent sand, some traction boards are a huge help as well!
    https://www.amazon.com/Escaper-Trac...pID=41r0N2OOheL&preST=_SX300_QL70_&dpSrc=srch
    I know you're not asking for all this recovery advice, but I figured it wouldn't hurt. I can shut up if you like.
  11. Feb 27, 2018 at 3:36 PM
    Tacoma_2016
    2016 TRD Sport
    Nah I appreciate the advice. I am new to off-roading so anything helps.
    I used the front tow hook on the frame and it did just fine but I'm always looking for better.
  12. Feb 27, 2018 at 3:48 PM
    OnHartung'sRoad
    Not really a fan of bungee tow straps- have to be really careful with them but they do work- just be careful what part you tie them to. I always let the other car’s owner put their own end on their car- while checking it too.
  13. Feb 27, 2018 at 3:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What do you mean really careful with them? You're a lot less likely to avoid damaging anything with them as opposed to a static strap.
    EDIT: That gif you posted is using a static strap, and a prime example of why those should NOT be used with a running start.
  14. Feb 27, 2018 at 4:01 PM
    OnHartung'sRoad
    Thats a static strap? Youre right, not supposed to get a running start with them for the jerking factor, but doesnt that one show the bumper getting pulled along as it recoils? My bad. Ive always pulled just nice n easy starting with the strap pulled tight- definitely not by jerking it.
    EatSleepTacos[QUOTED] likes this.
  15. Feb 27, 2018 at 4:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's hard to tell from the small GIF, but it appears that someone got a running start with a static strap, and that sudden and violent pull was too much for the stock bumper to handle on that jeep, so it just yanked off. I've seen plenty of videos on YouTube of idiots with static straps ripping bumpers off and breaking stuff, but have yet to see someone do the same with a kinetic strap. I'm sure it's possible, but just less likely. As you mentioned, proper recovery points on the vehicle are also crucial.
    Edit: And static straps will stretch a tiny bit (enough to cause that recoil) but not enough to get the proper slingshot affect
  16. Feb 27, 2018 at 4:13 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I see you have a Sport.... Did you pull with the round attachment on the driver's side or the recovery point on the pass. side..??
    I believe that one on the driver's side is for transport only and not a recovery point. The recovery point on the pass. side will mess up your air damn, if you still have one..... You said you used the "hook", so I'm not sure what you used. My TRD Sport does not have a "hook".
    Just wondering if you added one and removed the air damn..
  17. Feb 27, 2018 at 4:24 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Yeah, no pulling in reverse with reverse cut gears
  18. Feb 27, 2018 at 4:37 PM
    Tacoma_2016
    2016 TRD Sport
    I absolutely used the round attachment on the driver side..oops. Hope I didn’t damage anything. I have not done any modifications.
  19. Feb 27, 2018 at 4:37 PM
    Tacoma_2016
    2016 TRD Sport
    What do you mean by reverse cut gears?
  20. Feb 27, 2018 at 5:04 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Second this. Or use a buddy with another static strap. 8x4 :anonymous:
