Pulled the trigger and ordered a RollBak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmatheny, Jun 9, 2008.
  1. Jun 9, 2008 at 8:49 AM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Should be here late this week or next. I just like the ability to open the back up for spontaneous purchases - don't like the soft tonneaus at all, and the hard tops - where do you put it when you need the bed??
  2. Jun 9, 2008 at 8:51 AM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    I like the rollback too! the only downside would be (on the ones I looked at) that you loose your rails, and they are not cheap.
  3. Jun 9, 2008 at 9:05 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    I'm going to look real hard to see if I can mount it some other way, and move the rails down to just above the fenders.
  4. Jun 9, 2008 at 9:09 AM
    ChrisDeSoup
    Up in ya
    That would be a cool mod....My concern is what if I buy a new washer and dryer or some other crap I want to use my rails and cleats. Also spending 800 bucks is not in my wifes agenda:D I have been attempting to talk her into the TRD exhaust for 2 months......some day my balls will drop and I will just buy it.
  5. Jun 9, 2008 at 12:09 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Yeah, but at $800 it's the cheapest hard cover available!!
  6. Jun 10, 2008 at 6:27 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Called the dealer yesterday - about $170 for all rails and bolts/nuts.
  7. Jun 10, 2008 at 6:33 AM
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    are the roll baks water proof for when it rains hard? I agree with you about the soft tonneaus, those wont benefit me considering i mainly wnat a cover for security. i was going to get the Fold a Cover, since they just came out with one specifically for the 08 tacoma model (dont loose rails) until i asked the dealer and they said its only about 97% rain resistant. i'm still considering it but not being rain proof is a big downside. So where did you order yours from?
  8. Jun 10, 2008 at 7:39 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    http://www.rollbaktonneaucover.com/
    Got a special, free shipping and no tax.
    They claim they are relatively waterproof - torrential downpour might be an issue, but for me it is the best compromise between waterproof/security and functionality.
    If I can't figure out an alternative mounting scheme, I'm going to buy a new set of rails and mount them right above the wheel wells. I think lower would be better anyway.
  9. Jun 10, 2008 at 6:45 PM
    t-frax
    Cali
    thanks for the link.
  10. Jun 10, 2008 at 10:23 PM
    Anthony999
    Anthony999 Well-Known Member
    Glendale, AZ
    05 Tacoma
    MB Seven X Wheels, Hankook Optima Tires, Billet Grille, Blacked out headlights tailights and third brake light, LEER 700 Series tonneau cover, Blacked out emblems, Wolo air horn, Sony Xplod stereo, 8" Bazooka subwoofer, painted to match bumpers, leather arm rests.
    Whenever I need my bed for whatever, I just leave my hard cover up. Its not that bad driving with it up.
  11. Jun 12, 2008 at 9:28 AM
    danusa
    danusa Well-Known Member
    I Squeezeed a trigger and got results.
  12. Jun 17, 2008 at 8:47 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Came in yesterday - will be evaluating the install this weekend.
  13. Jun 23, 2008 at 9:58 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Well, got it installed Sunday minus one part that was the wrong one. I will post hints/gotchas later, as there are a few, and if they would just put these in the darn manual it would only be about a 1.5hr install.
  14. Jul 1, 2008 at 7:40 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    OK - here's the tips scoop on this most excellent top.
    1. Drill the drain holes FIRST - you can't get your drill under the canister, and you can't reach the bed from the bottom (I had to loosen the rails, slide them back, and remove the canister to drill the holes!) Also, if you drill out the two existing drain holes (3/4 wood bit worked fine), don't forget to drill some more small drain holes.
    2. The bed is fiberglass reinforced plastic - once you drill the holes, WASH THE BED OUT VERY WELL - I was itching for a week!
    4. The rail mounting system is a rectangular piece of aluminum that fits in the Taco rails. It has a hole in it, that you run a large screw through, then put a fiber nut on, then the rail bolts on to this - put locktite on the nut because the fiber nut does not hold tight enough, and they will come loose when you try to bolt the rail to it.
    3. You don't use the flat felt piece.
    4. The rubber piece on the plastic trim thingy goes on the end of the cover where it fits up against the tailgate.
    5. The round rubber piece with the adhesive on one side goes on top of the bed up next to the cab to keep water from getting in there.
    6. When you mount the piece that trips the latch when you open it fully, do not put it on the bolts with the nuts on there already - it must fit up against the bottom of the rails. In other words, no nut between the rail and the latch tripper thingy.
    They sent me the wrong canister cover - a Tundra one. I called them and they immediately sent out the correct one.
    I will be investigating getting some aluminum blocks that I can use to replace the deck rail mounting scheme, freeing up my deck rails to move them down to the top of the wheel covers so they are functional again. I asked them why they didn't have a kit like that, and they replied they had looked into it, but didn't think people would want to drill holes in their bed - hey, it's only 5 ea. 1/4" holes per side and they are covered up by the system! And it isn't like the bed will rust where the holes are drilled!
    I absolutely love this top - it is there when I need it, but out of the way when I don't. It is like a large trunk! Also, the design makes it very waterproof. I wouldn't hesitate to purchase it again.
    I saw a GMC Canyon with a RollNLock on it, very similar, but the actual cover is not as strong, and is covered with vinyl, which will deteriorate rapidly in the Texas sun. The RollBak is powder coated aluminum. Plus, the RollNLock is $300 more!
  15. Jul 1, 2008 at 8:42 PM
    Flyin' Squirrel
    Flyin' Squirrel Well-Known Member
    Austin, Tx
    06 SR5 Longbed 4X4
    TRD Sport, 3" Revtek suspension lift, Borla exhaust, AFE Pro Dry filter, Westin chrome nerf bars, Moto Metal chrome rims, limo tinted rear windows, Devil Horns grill emblem, extra bed D-rings
    Let's see some pics! I'm also curious how much this will improve gas mileage if any. Keep us informed if possible.
  16. Jul 2, 2008 at 9:19 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Well, I'm heading to Austin Thursday, so will report MPG after that. I'll get some pics when I get back. I'm also putting it through the car wash today, so I'll also report on water proof ability.
  17. Jul 7, 2008 at 8:14 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    OK - coming back from Austin, I got 22mpg doing 70-80mph. Also, here's pics as promised.
