pulling a boat with 4 cylinders
Discussion in '4 Cylinder' started by Rich8419, Nov 2, 2008.
  1. Nov 2, 2008 at 6:03 AM
    Rich8419
    Rich8419 [OP] Well-Known Member
    Louisiana
    2009 Dbl Cab Short Bed Offroad Pkg
    weathertech floor liners, scan guage, gatekeeper
    How many of you have pulled a boat with your 4 cylinder? I'm looking around for a 16ft flat boat and was wondering if anyone had any troubles pulling.
  2. Nov 2, 2008 at 10:28 AM
    dsailer
    dsailer Member
    Orlando, FL
    No problems. I pull 18ft Fish & Ski with mine. Seems to handle it fine.
    I did add a transmission oil cooler, just for peace of mind
    D Sailer
  3. Nov 2, 2008 at 1:06 PM
    dsailer
    dsailer Member
    Orlando, FL
    I know my boat has a package weight of 2200 lbs. Add for fuel and gear I'd guess around 2800 lbs. Mind you, its no rocket off the line, but it will get the rig moving. Once up to speed it handles the load well
  4. Nov 7, 2008 at 3:18 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    I pull my 18' Caravelle with my 2.7 4X4 with no problems 2400lb boat plus 300lb in gear. It is not quick by no means, but does OK once you get going. Brakes good, handles good. I use 4L to pull the boat out of the water up the loading ramp.
  5. Nov 7, 2008 at 8:04 AM
    Roy Matson
    Roy Matson Member
    Daryl
    minnesota
    03 SR5 4x4
    in dash gps and custom subs, 2.5 "coil spacers & 2" blocks, aluminium wheels & 33" Yokohamas
    I pulled my 14ft lund all the time with my old 97 2.7 5spd 4x4. It had 33s an a lift kit tho and it wouldn go past 70mph on the interstate but it worked fine. Any hills or wind and youll slow right down pulling a boat tho. Havent pulled with my new truck yet, its the 3.4 so now i can haul ass
  6. Nov 10, 2008 at 10:20 AM
    Rich8419
    Louisiana
    yeah. I figured if all else fails put it in 4 lo and pull the boat out of the water that way. A bridge or hill on the other hand.... well i guess I'll just have to get a running start.
  7. Nov 12, 2008 at 4:47 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    I pull my 18' crownline loaded at a boat/trailer weight around 4,000lbs. It pulls good enough for me not to even want a v6 and I pull the boat every weekend in the summer.
  8. Nov 13, 2008 at 9:40 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    If you pull boats or stuff often.
    just reember to have the brakes adjusted and the fluid fluid more often.
    If you have an Automatic, drain and fll a bit more often.
    Fresh fluid is good fluid.
    This will also tell you if you are over heating that tranner.
    If so add a good cooler..
  9. Nov 13, 2008 at 9:47 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    14ft aluminum!! no problem! don't burn your clutch on the loading ramp it you have one!! lol
  10. Jul 28, 2009 at 4:38 PM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    Pull a trailered 2000lb zodiac.
    MPG suffers, and have to manually hit 3rd on the auto for hills.
    No issues with sway or braking.
  11. Jul 28, 2009 at 5:53 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I tow my 17' bowrider (somewhere around 2500 lbs. loaded with fuel & gear) with my 5-lugger (4-cyl reg. cab 2WD 5-speed manual - 3.31 rear end) and agree with what pretty much everyone has said so far. It's slow off the line, but cruises fine once you get going. Handles and brakes very well. Have to downshift on hills. MPG obviously suffers (but still probably comparable to an unloaded V6). Getting up the ramp when taking the boat out is a bit of a challenge, but not bad at all. I have to slip the clutch - so I'm real careful to keep the revs as low as possible so as not to fry the clutch. The 2.7L has a lot of low-end grunt (for a 4-banger) so it's not a problem. If you have a 4x4 (4.10 rear end) it will be easier (especially if you use 4L). If you have an auto... obviously not an issue either way.
  12. Jul 29, 2009 at 5:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    im renting some seadoos and dont have a tow hitch...can i just put a ball in the bumper and tow it that way? or no
  13. Jul 29, 2009 at 5:32 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    If your doing it for traction then you could use the gas and brake but obviously not too much of each and that prevents you from rolling back and from having to give too much gas to get going and spinning. It just makes it smoother cuz often there is a small line on a slippery boat ramp between spinning and rolling back.
  14. Jul 29, 2009 at 7:32 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Yeah, you can use the bumper (that's why it's there) but go easy - if the truck's higher than the trailer it'll be a little unbalanced, plus the rear of the ski's will be closer to the ground. For my 16' boat & Pre-runner I had to get a bit of a drop hitch or I would scrape the motor getting it in my angled driveway.
  15. Aug 3, 2009 at 7:54 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    I pull a 24' pontoon a few times a year with mine. I've no idea what it weighs, but I think it's pretty heavy. A bit slow to start but handles fine.
  16. Aug 4, 2009 at 1:31 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    16 foot Carolina Skiff with no trouble.
  17. Aug 4, 2009 at 2:05 PM
    02tacoma2.7
    02tacoma2.7 Well-Known Member
    Barrett
    Albany, Ky
    02 tacoma 2.7 4x4
    K&N cold air Eagle 102 15x10 wheels 31x10.50x15 Cooper STT Line-X rocker planels Window Tint
    i pull a 18 foot fiberglass boat with mine.
