Pulling out another truck: worst case scenario?
Discussion in 'Towing' started by live4perfection, Jun 23, 2012.
  1. Jun 23, 2012 at 12:18 AM
    live4perfection
    live4perfection [OP] Well-Known Member
    Deep South Texas
    '12 TRD SPORT 4x4 LONG BED
    Ok...so we've all pulled out other trucks. Sometimes we're on pavement/gravel/dirt roads/hard packed sand while they're in mud/sand or even down a hill etc. At times all we've ever needed was a soft pull/hard tug/accelerated pop etc...but what I'm wanting to know is say we're also on loose sand or thick mud etc...should I put my truck on 4hi (normal drive, down shift 1,2,3) or 4low etc? Every time I've ever pulled someone out I've always been able to place myself in a pretty position. So I've never really experienced this worst case scenario. Say someone is stuck in middle of a crop field...how do u guys go about it? Or maybe in extremely loose sand. Let me know.
  2. Jun 23, 2012 at 12:21 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Air down, 4 low, diff locked. only got 1 shot sometimes don't want to mess it up.
  3. Jun 23, 2012 at 12:22 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Don't pull while in reverse..only if you absolutely have to. Pulling in reverse greatly increases the chance of breaking the rear ring and pinion gears ..
  4. Jun 24, 2012 at 9:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    use a snatch strap, not a tow strap.
    get a little bit of momentum and the strap will spring and yank them out. This works well in mud or sand.
    EDIT: 4lo and air down if needed.
  5. Jun 24, 2012 at 9:36 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    when your pulling dont shift unless your goin fwd real good. ive found that is better to just play with the gas and leave it in first /4lo its better. watch your revs and keep it steady.
  6. Jun 24, 2012 at 9:40 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    ok your auto. most of my pulls are on lose beach sand. 4lo. lo gear rear lock if you have it
    once you get moving then your good. ive yet to get stuck with my dc trd offroad. i always lock the rear also. and below 3 miles atrac is on automatic so you have equalpower all wheels. impressive trucks we have :D
  7. Jun 24, 2012 at 9:41 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If you're not gonna be able to get another vehicle to help you, don't get yourself stuck.
    If he's buried, clear everything you can from in front and under him. 4LO and pull going forward. If winching, never rely on park to hold you. Use your brakes from inside the vehicle and chock your tires if you can. If whatever you're driving on is soft but not hard enough to fall through just idling through it, then you can run back and forth across it to pack it down into a ramp, sometimes. This goes for snow sometimes as well.
    With sand you can usually wet it and it firms up.
    Airing down helps a lot to not get yourself stuck and to get the other person out. Just don't pop a bead in the mud, no fun.
    Oh and if you start digging in, just stop and fill in the holes, don't bury yourself trying to power out.
  8. Jun 24, 2012 at 9:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    fixed that for you:D
  9. Jun 24, 2012 at 9:45 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
  10. Jun 24, 2012 at 9:54 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    jeez 300 bucks aint to cheap the look real good though.
  11. Jun 24, 2012 at 10:00 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    golden rule. id want some one to help me and not charge 50 to 100 for a pull. so i do it and smile and if they can pay then they will offer if not my karma meter goes up; any way you look at it i win ;)
  12. Jun 24, 2012 at 10:08 PM
    MonkeyProof
    SoCal- SGV
    ive never accepted money for pulls or yanks or yanks..it's how i keep the trail karma flowing :D..and, that's just normal trail courtesy to help others out anyways :cookiemonster:
  13. Jun 24, 2012 at 10:28 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    your make a good point about the stuck person. :)
  14. Jun 24, 2012 at 10:35 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    on the beaches here there are tow vultures that wait at the soft spots. thats how they make their bread i guess. if the stuck beach tourist calls a tow truck to get them out there looking at a 120 to 200 dollar pull. i would except money if offered. because who am i to not allow the other person give blessings to hum they choice. yeah having good karma is better than the alternative.
  15. Jun 24, 2012 at 10:37 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I've got a set of fiberglass waffle boards, same concept as the max trax. Smittybilt makes a cheaper set FWIW.
    They work great though, a lot easier on the trucks and takes the risk out of it too.
  16. Jun 25, 2012 at 7:32 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    You guys put it in 1st when in 4lo, or just in drive?
  17. Jun 25, 2012 at 7:42 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    first /lo
  18. Jun 26, 2012 at 1:16 AM
    live4perfection
    Deep South Texas
    As always...you guys go above and beyond the question at hand...it's a beautiful thing you guys have going on here at TW! Thanks a bunch.
