Pulling the boat with open diff 2WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Jun 19, 2012.
  1. Jun 19, 2012 at 5:46 AM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    My truck is an '08 Prerunner DCSB 4.0 with LT265/75r16 BFG A/T's. As I've previously stated I was considering having the dealership ($1100: OEM LSD diff) or 4 Wheel Parts ($900: Detroit True Trac LSD) eliminate the open rear diff I currently have. However, With these tires I can't even peal out from a standstill at a traffic light and I can power brake but its hard to break them loose. I dont normally do that but I was testing its traction.
    I towed my dad-in-laws 21' foot boat a few nights ago. (It weighs 4650 with trailer with its tandem axle trailer. My truck weighs 4250. I had them weighed at a truck scale place in Miami). I dropped the boat at the ramp behind Parrot Jungle which is pretty steep. When I took the boat out later that night it was low tide. The truck pulled it out with little effort. Not even a tire squeal. I had to lower the boat back into the water 2 more times because the boat didn't mount on the trailer correctly and by this time the ramp is wet yet I still had ABSOLUTELY no tire spin coming out. I have been on a couple of light dirt road trails in Miami (with standing water on them & light mud and have not had an issue). I'm not going to do hardcore mudding or rock trails. In your opinion. Does the use that I give my truck justify the expense? BTW, not just the expense but I worry about messing with my truck since it is trouble free. Please give me your opinion. THANKS! :)
  2. Jun 19, 2012 at 5:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, and please do not take your truck to 4WP...ever.
  3. Jun 19, 2012 at 6:01 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Sounds like you don't really need it. It's the slick boat ramps you gotta watch out for. I have never needed to use the ALSD in my taco.
    Just an example of why it wouldn't really help...pardon the rest of the video...
    http://www.youtube.com/watch?v=q-rQTHMVAuw&sns=em
    Do you really wanna spend $1100 on something you don't really need?
  4. Jun 19, 2012 at 6:03 AM
    medic2230
    Murph
    Bama! Roll Tide
    No you don't need it.
  5. Jun 19, 2012 at 6:03 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    I bought my rims from there. They even mounted and balanced the tires...then again, I wouldn't let them do anything more mechanically challenged than that...and even then I had to take it to Tires Plus and have it redone.
  6. Jun 19, 2012 at 6:19 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I would get a ARB Locker before spending $1100 on a LSD in a heartbeat. That said, neither option you mentioned is worth considering.
  7. Jun 19, 2012 at 6:34 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I bet you anything the ALSD would make it thru the test section in the video- When I first launched my skiff with the Tacoma when it was brand new, as soon as I tried to pull off the ramp, the tires just starting spinning, and the truck just keeps sliding back torwards the water with every attempt. Keep in mind its a 5 spd manual. Freaking out thinking my new truck is about to go under, with the rear tires just in the water, I remembered reading about the ALSD feature, hit the button and the truck crawls off the ramp without a single wheel spin. It was like I was locked on all 4! I am not saying its like having 4x4, but in this type of situation I am a believer.
    That being said, a locker may be nice to have if you deal with tough ramps at times.
  8. Jun 19, 2012 at 10:23 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I keep hearing bad things about 4WP! I could see maybe 1 or 2 unsatisfied customers but when it's as bad as I've been hearing, well, thats good enough for me. Thanks for the heads up folks.
  9. Jun 19, 2012 at 10:36 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    you can see that the LSD did help the truck a bit. the open diff just rolled back like noting. the LSD almost made it.
    I'm not knocking LSD...it is a great thing to have...just not for $1100. If hes that concerned, he night as well spring for a locker...
