Pumping out front diff / drain plug stuck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bruno, Jun 19, 2012.
  1. Jun 19, 2012 at 1:07 PM
    Bruno
    Bruno [OP] Well-Known Member
    Bruno
    1996 4x4 V6 Xtra Cab 5spd
    1st Gen Fabtech Coilovers, Rear Add a Leaf, 33x12.5 BFG Mud Terrains, Deck Plate Mod
    First post here...been reading a ton this week and catching up on a bunch of deferred maintenance. Getting ready to move cross country from San Diego to Tampa Bay with mazda 626 in tow (towing for first time)
    Anyway, my front diff drain plug is F'd, its somewhat stripped and I can't remove it. Get back to that in a sec. But has anybody ever pumped out the front diff with a small hand pump? That way I can avoid taking it in to a shop and getting the diff plug removed for now.
    Also: What is the exact size for this drainplug? I did a search that revealed its a 12mm Hex...went to sears, bought one only to come home and find it doesn't fit...too big.
  2. Jun 19, 2012 at 1:25 PM
    Bruno
    Bruno
    Yeah, thought about that. I'll go take a look again and see what diameter hose I can fit if any.
  3. Jun 19, 2012 at 1:40 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Mine is a 10mm hex. Its tucked away pretty good, hard to believe that yours got messed up.
  4. Jun 19, 2012 at 1:51 PM
    Bruno
    Bruno
    10mm hex, k I'll try that thanks!
    Stripped as in probably the last time I tried changing the fluid a few years ago, I ran in to a similar problem and stripped it then.
    edit: Tried a 10mm hex, its stripped, no use. I'm gonna have to get somebody to weld a nut onto it and remove it. Pisses me off, bad design. The tranny, rear diff and tcase fill AND drain plugs are all the same size then they decide to make the front diff plugs internal hex??? Makes no sense.
    Anybody come up with a replacement for these plugs so I don't have to go through this again?
    PS: I fit the narrow tube that comes with a hand pump I bought and it gets in there pretty far...gonna try and pump the fluid out to change it. Will post results and pump/hose i used if successful.
  5. Jun 19, 2012 at 4:41 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    get the largest one and a hose to fit it.
  6. Jun 19, 2012 at 4:59 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    ^^^^ thats worth a try but the fluid is heavy, if the 10mm hex doesn't work and its already Fucked up I would try a chisel on the edges of the plug.
    If you are able to suck it out measure what comes out so you don't over fill it .
    There is another way to get that plug loose, I can't remember from mine how much room there is where the plug is located, but a good welder could take a nut the diameter of the plug and weld the center of the nut full to the differential plug.
  7. Jun 19, 2012 at 5:34 PM
    2004tacoprerunner
    2004tacoprerunner Well-Known Member
    byron, mn
    2004tacoprerunner
    hand pumping that thick gear oil is going to be a bitch. If you know someone with a mityvac fluid extractor run off a compressor it will make it a lot easier.
  8. Jun 19, 2012 at 6:30 PM
    Bruno
    Bruno
    So I ended up using this penzoil pump...
    Basically it sucked. Both literally and figuratively. But i got it to work. I used the "airline" hose that came with it as it was skinny enough to fit deep into the diff. After 20 minutes of pumping, I'm pretty sure I got all of the old diff fluid out. The pump was hardly efficient (air leaks), the syringes would've worked better for sure.
    It wouldv'e been nearly impossible to measure how much I got out, but I was able to pump in around 1.4 qts more or less.
    Saved me the hassle of other more involved options. Thanks all for the suggestions! Forum is awesome.
    Syringes are not a bad idea...eliminates the air sucking of cheap auto parts store pumps. If/When I do this again, I'll go this route.
    I'm hesitant to bang on it, last thing I want is to F up the diff threads. Welding a nut onto it is a great idea. When the time comes to really remove the current plug, I'm going to do this then REDO it with a new plug/nut. That way I dont have to worry about stripping in the future.
    Also, I was under the impression that fill plugs are strategically placed on their respective parts to prevent overfilling. IE; you know when your at capacity when fluid comes out of the fill plug. Could be wrong about this though.
    Total bitch. My friends aren't as mechanically inclined...doubt they can change their oil themselves. ;)
  9. Jun 19, 2012 at 6:48 PM
    2004tacoprerunner
    byron, mn
    2004tacoprerunner
    I used the mityvac hand powered unit many moons ago on my dodge dart sport . Yeah it was no fun at all.
    The diff housing had no drain plug. I had no choice then.
  10. Jun 19, 2012 at 6:55 PM
    tan4x4
    Rick
    Folsom, CA
    A few years ago, I set up a syphon on a Honda Civic tranny, whose drain plug was stuck. Used aquarium tubing that I was able to snake down thru the gears, via the fill hole, to the bottom. Took several hours for it all to syphon out.
  11. Jun 19, 2012 at 6:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Vice grips and a torch.
  12. Jun 20, 2012 at 4:20 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Hope you get enough gear oil back into the differential, overfull and seals leak.
  13. Jun 20, 2012 at 4:26 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It is set pretty flush. You won't get vise grips on it.
    It's not a bad design as long as you have the EXACTLY right sized tool. I had the same issue with mine. Fortunately, I have a welder and welded a cheap 10mm allen head socket to it for extraction. I got a new drain plug from Toyota and a really good tool to remove it now.
  14. Jun 20, 2012 at 4:27 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Nothing wrong with the chisel method, or with welding a bolt to it. Whichever works, just get a new one before hand, probably easiest to get a part number and order online or from your local dealer.
    Fill level with the bottom of the fill hole, correct.
