Puppypunters idea hole
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Puppypunter, Mar 9, 2021.
  1. Apr 17, 2021 at 7:20 PM
    #141
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    Damn, trucknutz lights actually exist.... That's enough internet for today.... :rofl:
    tonered, barf and Shellshock like this.
  2. Apr 17, 2021 at 7:34 PM
    #142
    Puppypunter
    Johnny
    2019 Black SR
    OK, so these ones aren't anything really fancy. They are a harness for hooking up VLED switchbacks on an SR/SR5 without using the wedge adaptors or the resistor tee. Nothing too fancy there, just trying to minimize the rats nest behind the headlights. What does make these unique though is the fact that you can plug the Diode Dynamics halos straight into them. The halos will then mirror what the DRL/Turn is doing. Solid white DRL, flashing amber turns. And then when the parking DRL is turned off because the headlights are on, they will dim down. Made these for @Mudrucker
  3. Apr 18, 2021 at 6:35 AM
    #143
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Need some help determining where to tap into the centre console for 12v input for my shift knob illumination in 2019+ Tacomas that have USB instead of the 12v accessory jack.
  4. Apr 18, 2021 at 6:40 AM
    #144
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Kmorgan3 has a few T harness options for in cab illumination. The closest one to the shifter would be off climate controls or 4x4 selector. He also has one for the cargo light rocker.
    Ah, he is on your thread already.
    12v for USB is not the same as illumination + and PWM - feeds. I don’t think there are any good options for dash illumination other than the door lock/window switches once you are outside of the dash itself.
  5. Apr 18, 2021 at 6:45 AM
    #145
    oostroma
    oostroma (Boomer)
    Ontario
    I would like a simple T tap solution for customers with certainty an option to purchase a T harness if they so choose. I know a T harness is a more elegant solution but I would like to keep it simple for customers.
  6. Apr 18, 2021 at 7:51 AM
    #146
    caribe makaira
    Caribbean, Puerto Rico
    Simple creates complacency. You are introducing a high probability of wire severing with such thin gauge wire and vehicle movement, but as the song goes: "play at you're own risk."
  7. Apr 18, 2021 at 8:32 AM
    #147
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Just found this thread and wanted to drop in what’s I’ve mildly researched on TW (mostly by asking questions).
    I’d be really interested in a cornering light harness that triggers on blinkers. I’d like to install some focused LEDs that can light up side streets when turning at night. Night vision isn’t what it used to be and I’m only slightly embarrassed to admit it.
    I assume there might be two lengths; one to host lights near the grille, and one to host existing ditch lights. For the ditch lights, it might need to play nice with an existing power circuit.
  8. Apr 18, 2021 at 10:22 AM
    #148
    caribe makaira
    Turn signal spot lights.... anyone, Bueller, Bueller
    Headlight Stalk Breakout Harness
  9. Apr 18, 2021 at 10:50 AM
    #149
    Puppypunter
    Johnny
    2019 Black SR
  10. Apr 18, 2021 at 10:53 AM
    #150
    caribe makaira
  11. Apr 18, 2021 at 10:56 AM
    #151
    Puppypunter
    Johnny
    2019 Black SR
    Also, on this one. I could do it with a delay relay. Nothing wrong with Caribes, it works beautifully I am sure. But if you want something fairly plug and play, I could do that. We could grab the turn from the rear, power from the battery. Make the lead as long as you'd like for where ever you want to mount them. Could be made to handle 5A each side, which should get you plenty of cornering light easy enough. Can do 10 amps too if you really wanted, but that just seems excessive even to me.
  12. Apr 18, 2021 at 10:57 AM
    #152
    Puppypunter
    Johnny
    2019 Black SR
    Can this one do DRL? Didn't see that listed as an option.
  13. Apr 18, 2021 at 10:57 AM
    #153
    caribe makaira
    A flashing curb lamp?:rofl::rofl::rofl:
  14. Apr 18, 2021 at 11:01 AM
    #154
    caribe makaira
    Do DRL?...explain what you'd like that circuit tap to do...
  15. Apr 18, 2021 at 11:02 AM
    #155
    Puppypunter
    Johnny
    2019 Black SR
    Wouldn't flash. Delay relay, not just a relay. Basically takes a timer, a relay, and the diodes an combines then in a neat, small package a little smaller than a micro relay. Can also be programmed to leave the curb lamp on for a specified time after turn signal is turned off too if you wanted.
  16. Apr 18, 2021 at 11:04 AM
    #156
    Puppypunter
    Johnny
    2019 Black SR
    Close a ground circuit when the stalk is switched to DRL. Like the 13 pin one can. Like it does for all of the other functions listed. DRL is not listed, so I am not sure if it was oversite or incapability?
  17. Apr 18, 2021 at 11:10 AM
    #157
    caribe makaira
    So you'd make more expensive by adding a timed relay...
  18. Apr 18, 2021 at 11:12 AM
    #158
    Puppypunter
    Johnny
    2019 Black SR
    I can buy 2 timers for $34.... $34<35 :)
  19. Apr 18, 2021 at 11:12 AM
    #159
    caribe makaira
    Well it's not listed due to it not being a true on or off tap. The added circuit would be ON with the DRL but to turn it off all lights would be off also.
  20. Apr 18, 2021 at 11:13 AM
    #160
    caribe makaira
    You can get a Denso or Matsushita or Panasonic 4 pin for $5.00
