Push Button Switch Feeler
Discussion in 'Group Buys' started by TheNatural, May 1, 2014.
Would you buy an OEM style push switch for around $20?
Poll closed May 31, 2014.
  1. Yes! Light up ones please!
    59 vote(s)
    83.1%
  2. Yes! A non light up one, like in the picture
    3 vote(s)
    4.2%
  3. Depends on final price and/or reviews from other members
    8 vote(s)
    11.3%
  4. No, do not like/need/want
    1 vote(s)
    1.4%
Thread Status:
Not open for further replies.
  1. May 8, 2014 at 12:56 PM
    #41
    TheNatural
    TheNatural [OP] Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    The way the light up switches are wired is similar, but "upside down" to what you're describing. The bottom text has a separate led that wires into the rest of the dash dimmer lights and is always on. The top led is on when the circuit is closed.
    I like the little panel you put by the shifter. I'm planning on putting my compressor and locker switches there when I find room in the budget for that project.
  2. May 8, 2014 at 2:37 PM
    #42
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    Yup. I ended up using the oem fog light switches from an FJ for the switches on the left side of the dash, they have a secondary illumination bulb when the circuit is on, you would figure that they should all be like that...it's worth it but pricey.
  3. May 9, 2014 at 12:24 PM
    #43
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    UPDATE: I forked out the setup cost to have them make a custom sample. Hopefully soon I will be receiving an under AC size switch with a light up graphic. I ordered a Rock Lights switch, mostly because of self interest, but I'll take some pictures and show you guys what it looks like when it arrives. I'm sure the LED Light bar graphics, etc, will be of the same quality.
    EDIT: What colour LED's are you guys most interested in? I ordered the sample with green to match the OEM switches in my '12, but I think other years may have had different colours?
  4. May 9, 2014 at 2:17 PM
    #44
    luka
    Kailua, HI
    most of the previous years had orange on the left side. Might have found a way to change the bulb out with an LED, should know over the weekend.
  5. May 9, 2014 at 6:27 PM
    #45
    delesseria
    delesseria Active Member
    Tom
    Olympia
    14 TRD Off-Road Blue Ribbon
    ProEFX Heated Towing Mirrors, TRD cat-back exhaust, Snugtop Sport Hi-Liner, Hellwig EZ-990 Helper Springs, IGGYCORP LED pods
    Hi,
    I'd be interested in the smaller, under AC variety. Are these momentary switches, like what you might want to trigger a time-delay relay? I'm thinking of something like the heated mirror mod.
  6. May 9, 2014 at 6:46 PM
    #46
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Darn......"under A/C" not an option for my 05.....
  7. May 9, 2014 at 10:33 PM
    #47
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Have no fear, expanding product line is here! I'm in the process of designing a panel just like the one shown in post #40 of this thread, but for the under AC switches. I -was- just going to draw one up and 3D print it for myself so I could put some of these switches next to my cupholder, but once I do the hard part I may be able to produce them economically for others as well. I'm sure you could put the switch panel under your AC unit on your '05 and have an end result similar to a factory '12!
  8. May 12, 2014 at 3:23 PM
    #48
    luka
    Kailua, HI
    That dash trim piece is replaceable with the newer ones, there was a couple of threads about the swap with part numbers and costs.
  9. May 15, 2014 at 4:24 PM
    #49
    WisTaco
    WisTaco Bowhunter -)))----->
    Wisconsin
    Murdered 08
    TRD coi,TRD exhaust, Leer cap,WT floormats, Ironman Lift, LR UCA's, Ultra Rogue wheels, 255/75/17's. DYI mods 4x4 Illum switch & BLHM.
  10. May 15, 2014 at 4:35 PM
    #50
    hawks02
    hawks02 Active Member
    E.Washington
    2014 DCSB MGM TRD Sport & 1998 Tacoma Ext Cab
    Tinted Windows, 3M Clear Bra, WeatherTechs,
    Id be down for the LED light bar
  11. May 16, 2014 at 6:26 AM
    #51
    the glen
    the glen Well-Known Member
    Glen
    penisula
    2012 TRD Off-Road 6SP manual spruce mica Taco
    Icon 2.5 remote res. Coilovers front, icon 2.5 rem res shocks rear, deavers 10 pack leafspring rear. Light racing ouca. Cmc, avid light bar, bamf sliders weld on, grillcraft mx grill, bamf light bracket with lightforce 170's. Uws toolbox, oem bed mat, weathertechs f/r, hella airhorns, trd antenna, talegate mod, Clifford alarm, budbuilt full skid plate set. All pro rear bumper. Superbumps bumpstops. Bulldog lighting reverse led lights in bumper. Trd short throw shifter. Cobra cb, firestick 4' ant. Icon LCA skids. Bamf rear dif skid. Hi lift x-treme mounted with relentless rail mounts in bed. Full size method/bfg in bed. Crown performance ss/Kevlar brake lines. Power tank mounted in bed. Rigid d2s mounted on relentless hood mounts. H3R quick release fire extinguisher mounted to driver's seat. Redline hood struts.
    Any word yet on if/when we can order these switches? I really like these and I'm just about to mount up some d2s.
  12. May 16, 2014 at 6:34 AM
    #52
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    #52
  13. May 16, 2014 at 8:53 AM
    #53
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    My sample should be here any day now, then I'll have a review for you all. It sounds like there's tons of interest so I'll order a bunch as soon as I've verified the quality of the product.
    Thanks for the tip. I noticed that they don't have the graphical under AC size switches that many people seem interested in though. This could actually end up being a good thing, you guys have access to a larger selection and I can still supply the the customized ones you're after.
    #53
  14. May 16, 2014 at 4:14 PM
    #54
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    They do: http://www.ebay.com/itm/Push-switch...Parts_Accessories&hash=item3cdf13c155&vxp=mtr
    Still, their selection is rather limited, both in color and button faces. Having a custom option would be good!
    #54
  15. May 16, 2014 at 9:08 PM
    #55
    ripkinc
    ripkinc Well-Known Member
    balt
    11' DCLB SR5 Expedition in progress
    camper shell, LED enhancements, electrical mods, duel battery, rollin on general grabber at2's
    Definitely interested. My top would be led spots/flood, led bar, compressor,
  16. May 18, 2014 at 5:30 AM
    #56
    Gitmo
    Gitmo Well-Known Member
    Justin
    I'm in.
  17. May 27, 2014 at 7:39 PM
    #57
    WisTaco
    Wisconsin
    Murdered 08
    How's it coming OP, any anticipated dates yet?
  18. May 28, 2014 at 9:43 AM
    #58
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Bit of a snag. They made the graphic I wanted, but they messed up and put it on the wrong size switch. Waiting on them to redo it with the proper under AC switch. Quality looked good though.
  19. May 28, 2014 at 6:30 PM
    #59
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Hey OP, any chance your supplier can make the timed heated mirror switch like the highlander switch but maybe at a better price?
  20. Jun 3, 2014 at 5:28 AM
    #60
    Kendall01
    Kendall01 Member
    Kendall
    Greenwood SC
    07 Tacoma SR5 TRD
    lifted, 20" Enkei Wheels, Chrome Bull Bar
    Id be interested in a set of the lighted switches (Amber)
Thread Status:
