Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Feb 28, 2020 at 9:10 PM
    #2521
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Oh also, airing the tires fixed the bump steer.
    And... Shout-out to SimplyMuggle for the vinyl wheel kit!
    SimplyMuggle likes this.
  2. Mar 1, 2020 at 8:49 AM
    #2522
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Your mpg is going to be worse than the stock tire unless you installed the wormhole adapter on each tire and under your seat.
    Think about it for three seconds, the new tires are heavier and significantly taller than the oem. Your speedometer & odometer are totally off and effecting the mpg calc.....even if you log it the old way.
    Sweets likes this.
  3. Mar 1, 2020 at 9:08 AM
    #2523
    Sand_In_My_Taco
    NOR*CAL
    I don't disagree with you at all and understood that 100% going in. (MPG)
    But being unable to cruise at 65 w.o constantly downshifting wasnt expected.
    helix66[QUOTED] likes this.
  4. Mar 1, 2020 at 11:28 AM
    #2524
    helix66
    DPRC
    2017 DclB TRDor MgM
    I had that same issue with the oem tires and the taller, heavier 255s make it worse.
    So far I love the look, off-road traction and the extra ground clearance but the handling sucks compared to the oem.
    On my old pathfinder the jump from stock to 33x10.5x15 was great because that was the oem width on the higher models. For the taco we’re losing that half inch.
    Going to try 35 psi and I guess chalk it so I don’t wear unevenly.
  5. Mar 1, 2020 at 5:41 PM
    #2525
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Your new tires might be heavier, but they are effectively lengthening your gear ratio. Do the math. You are travelling further per rotation of the drivetrain (what the speedo/odo reads, not road speed) which means you're getting better mileage than indicated (it's also why you should correct your speedometer and why it reads slower than you're actually going after the change to these tires). After I switched, my MPG's indicated dropped ever so slightly, then rose back to where they were as I slowed down my driving style and decided that I didn't need to get up to speed as fast as I was before. After correcting for the ODO discrepancy, I have gained MPG's on the highway because I am turning less RPM at any given time, which means less engine losses due to pumping, which means greater MPG's. So, think about it for a few more seconds, and realize that you can totally gain MPG's with this change if you drive conservatively.
    Your engine will have to work harder going up hills, or when accelerating if and only if you try to match your previous rate of acceleration. Keep your foot out of the pedal and you will see your MPG's climb right back to where they were, and if you're really concerned about MPG's, slow down. These trucks are bricks and don't respond well to speed.
    Or, maybe MT's are just magical unicorns that fart into the intake and give extra MPG's. You decide.
    The autos are really geared long to be able to get good MPG's, especially the extremely long 5th and 6th overdrives. One side effect of this is that they were on the edge of driveable with the stock axle ratio. Now that the tire (and therefore overall gear ratio) is about 8% longer your truck has to cruise around at a lower RPM at any given speed which means it's making less torque and significantly less power, so it will frequently downshift to keep the engine from lugging. The most common solution for this is a regear (4.88's/5.29's) and/or tune. Being in a manual I've rarely noticed the engine letting me down on anything short of a literal mountain grade.
    enduringsnark likes this.
  6. Mar 1, 2020 at 6:22 PM
    #2526
    helix66
    DPRC
    2017 DclB TRDor MgM
    Yes larger circumference means longer distance traveled per rotation.
    Your speedo, odo and computer are calibrated for the oem tires.
    Either way do you really think adding more weight especially rolling mass to any vehicle could possibly help mpg?
    Go for 40s, your tank will fill it itself.
  7. Mar 1, 2020 at 6:39 PM
    #2527
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Weight wil not help. Extra gear ratio does. If you drive like a loon, the weight will hurt more than the ratio helps. If you drive slow, the ratio gain will help more than the weight hurts. I know this because I observed it, on my own vehicle. I can't say it'll hold true on 35's, 37's, or 40's.
    But hey, I'm lying about what I experienced I guess. :jerkoff:
  8. Mar 1, 2020 at 7:03 PM
    #2528
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Do you just do it by hand, or did you get your speedo recalibrated?
  9. Mar 1, 2020 at 7:07 PM
    #2529
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Manually, confirmed by GPS and (unfortunately) also radar. Turns out it's easy to multiply by 1.08
    Lt. Dangle[QUOTED] likes this.
  10. Mar 1, 2020 at 7:14 PM
    #2530
    Lt. Dangle
    Ohio
    Right on.
  11. Mar 3, 2020 at 4:10 AM
    #2531
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    Does anyone have tall skinny tires with this eibach pro lift kit. I have the 255/85/16 Cooper's on mine and I am wondering what the actual total height is from ground to top xm antenna. Mine so far is at 64". I ask this because almost all the car washes and parking ramps around here are 70" max height and I would like to not go over that if possible. I do not have this kit yet but that will be the yay or nay factor. Thanks for any help.
    Stock 19 off road double cab long bed with Cooper's on.
  12. Mar 4, 2020 at 4:43 PM
    #2532
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Anyone mounting 255/85r16 on the 16” trd pro wheels? 16x7 +13 offset
  13. Mar 8, 2020 at 4:58 PM
    #2533
    BlancoTaco13
    BlancoTaco13 Active Member
    2017 White Tacoma TRD Off Road 4x4
    Has anyone had 265/75r16 ST Maxx’s and changed to 255/85r16 in the same tire? Any thoughts worth noting?
  14. Mar 16, 2020 at 7:58 PM
    #2534
    Shadetacoma17
    Shadetacoma17 Member
    Shade
    Tacoma
    how high does it sit after 33 on ?
  15. Mar 16, 2020 at 8:26 PM
    #2535
    trackdaybro
    trackdaybro Well-Known Member
    See my 265/75 -> 255/85 experience below.
    I also ran some ST Maxx in 255/85/16. As you know they’re surprisingly quiet for the tread aggressiveness, but so so heavy. I liked the KM2s more. Even though on pavement they rumbled the truck at off-idle speeds and they howled down the road, they performed awesome in the dirt. And imo look better. The ST Maxx ran small and didn’t look as cool as the KM2 :D
  16. Mar 17, 2020 at 4:17 AM
    #2536
    BlancoTaco13
    Here’s my dilemma with a true MT. I work with my truck (70% off road), but cover a lot of miles. I need a tire that can get ~50k miles and not cut my gas mileage too badly. I’m needing to run a taller tire than 265/75 without running 285/75. I want to run a different tire than ST Maxx next time around, but the options are so limited in this size.
  17. Mar 17, 2020 at 4:58 AM
    #2537
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    My buddy has them on TRD Pro wheels, which are currently mounted on my truck. We both have 255/85r16 Cooper ST Maxx tires but I have the stock Offroad wheels. We swapped tires to try to figure out why I have so much wander at highway speeds. On his drive home (~1 hour) after we swapped he realized immediately that his truck was wandering on the highway and I have noticed that my steering is much improved with the TRD Pro wheels with the +13mm offset instead of the Offroads +24mm offset.
    tacotoospicy[QUOTED] likes this.
  18. Mar 17, 2020 at 5:49 AM
    #2538
    trackdaybro
    This size tire and the weight you’re going to be jumping up to will definitely cut your gas mileage.. food for thought!
  19. Mar 17, 2020 at 6:08 AM
    #2539
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Courser CXT! I've got 25k miles thus far and lots of tread life to go, great offroad performance, and if you drive the speed limit and don't try to race between lights your MPG's will be just fine. I got ~17 MPG on my commute this morning doing 3mi city drive>20mi 75mph interstate>5mi city drive in a hurry to get to work. On the same commutes taking my time I get over 20, and have pushed 24-25 by going 60 rather than 70. They're fantastic tires I wish more people knew about.
    spentshells likes this.
  20. Mar 17, 2020 at 7:12 AM
    #2540
    tacotoospicy
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Interesting, that does make a lot more sense considering the offset. IMO the Trd pro wheels look better than the OR wheels
    not a chrome fan
