Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Aug 3, 2017 at 9:31 AM
    #261
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    Boiii. Looks nice
    rlx02[QUOTED] likes this.
  2. Aug 3, 2017 at 9:45 AM
    #262
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Thanks! Really wants me to put on some 35"s though...
    nudavinci64 likes this.
  3. Aug 3, 2017 at 9:50 AM
    #263
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    LIFTS DO NOT CREATE MORE CLEARANCE FOR LARGER TIRES
    So much misinformation on this forum
  4. Aug 3, 2017 at 9:51 AM
    #264
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Sure they do!
  5. Aug 3, 2017 at 10:13 AM
    #265
    CanisLupus
    Stokesdale | NC
    If you're being serious, incorrect
  6. Aug 3, 2017 at 10:14 AM
    #266
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Damn, your troll meter must be working today. I'm bored at work and felt like messing with someone.
    EDIT: A lift does allow bigger tires at ride height though.
  7. Aug 3, 2017 at 10:36 AM
    #267
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Oh, the irony
  8. Aug 3, 2017 at 11:04 AM
    #268
    CanisLupus
    Stokesdale | NC
    Oh do tell me how lifts magically create more clearance for tires...as @EatSleepTacos said, yes they give some clearance at ride height, but I'm pretty sure we all don't drive on straight roads and never turn.
    Or maybe that's just me.
  9. Aug 3, 2017 at 11:14 AM
    #269
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    It's not magic , obviously. You just said it yourself, "they give some clearance". Yes, a lift alone will not guarantee you clear your tire. Caster, rim & tire spec, UCAs, & all that comes into play, and some may still need to CMC. But a suspension lift will increase the relation of your hub to fender. This gives you additional clearance from your plastics & fenders permanently.
    Nobody was saying a suspension lift will absolutely eliminate rubbing. Its pretty well known on these trucks that no reasonable amount of lift will allow you to clear 35's w/o cutting, for instance. But they do provide additional clearance, and you are spreading false information by saying suspension lifts don't help clear larger tires.
    blairrad and dre5491 like this.
  10. Aug 3, 2017 at 11:29 AM
    #270
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    :popcorn:
    nibrwr likes this.
  11. Aug 3, 2017 at 11:32 AM
    #271
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not true. You can hit your bumpstop on stock suspension and you can hit your bumpstop with a lift. In both instances, the tire is getting stuffed the same amount.
  12. Aug 3, 2017 at 11:35 AM
    #272
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    sorry to interrupt, how does the power feel with the 255s relative to stock size?
    doublethebass and EatSleepTacos like this.
  13. Aug 3, 2017 at 11:36 AM
    #273
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm running this size, and I personally didn't notice a difference. With that being said, I don't usually accelerate fast, so YMMV.
  14. Aug 3, 2017 at 11:41 AM
    #274
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Yeah, im trying to be more lethargic, i generally get between 18.5 and 20 depending on what im doing.
    EatSleepTacos[QUOTED] likes this.
  15. Aug 3, 2017 at 11:42 AM
    #275
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I also haven't seen much of a drop in MPG, even if they're heavy as shit. Maybe 1-2 at most, which isn't bad all things considered.
  16. Aug 3, 2017 at 11:49 AM
    #276
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    I never said anything about bumpstops or a condition where you're bottomed out. Of course your more likely to rub your wheel wells when bottomed out with a bigger tire, suspension can't correct this unless you modify your bumps. Generally speaking, when you do a lift, you raise your hub to fender which gives additional clearance of your plastics, especially when turning.
    Blanket statements like "lifting your truck doesn't help clear larger tires" is just incorrect. I do agree that for many people, lifting alone won't solve all rubbing when going with a bigger tire.
    rlx02 likes this.
  17. Aug 3, 2017 at 11:55 AM
    #277
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Gotcha. I was referencing you saying "...additional clearance from your plastics & fenders permanently." because nothing about it is permanent. I mentioned bumpstops because that's an easy to understand explanation that a stuffed tire is a stuffed tire, lift or not.
    mateo_roberto[QUOTED] likes this.
  18. Aug 3, 2017 at 12:01 PM
    #278
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Definitely. That is a good example of how rubbing will occur regardless of suspension lift alone.
    Don't know why I chose the word permanently, I'm better with numbers than words :thumbsup:
    EatSleepTacos likes this.
  19. Aug 3, 2017 at 1:22 PM
    #279
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I didn't notice any difference in power. The only thing I noticed was that it downshifted just a tad sooner, which made it feel more responsive. It feels like this truck was geared for 33"s.
    The general consensus though is that 33"s with 285 width will rob you of some power since they're heavier.
  20. Aug 3, 2017 at 2:41 PM
    #280
    upTOPOverland_Drew
    Drew
    Littleton, CO
    Okay, follow up question, for those running the ST Maxx, do you feel the tire wanders or is squirrelly on the highway? or any driving for that matter
