Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Sep 9, 2020 at 8:59 AM
    #2841
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    It's nowhere close to the diff. IIRC the guys with clearance issues have long-beds.
  2. Sep 9, 2020 at 9:00 AM
    #2842
    E.J.
    Josh
    NWA
    My diff is so clean because I just changed the gear oil.
  3. Sep 9, 2020 at 9:01 AM
    #2843
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    good to know doesnt make since you would thing the long bed would have more room
  4. Sep 10, 2020 at 8:14 AM
    #2844
    chipcall61
    chipcall61 Well-Known Member
    North Carolina
    2017 Toyota Tacoma TRD Offroad
    2" OME Bilstein Lift Cooper ST MAXX 255 85R16 TRD Pro Grill OME Bedmat Weathertech Liners all around
    I bought the Cooper ST MAXXs in 255/85R16 for my stock OR wheels and have been thrilled with the look and performance. They fit up perfectly with no rubbing with a 2" lift. I'm not really an off-roader, but they've always gotten me where I needed when out duck hunting and that can be some awfully soupy terrain. The only negative is they get louder more they get worn and only last around 45K miles. I'm down to 2/32nds and will most likely go the same route.
  5. Sep 10, 2020 at 1:42 PM
    #2845
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Stock OR suspension.
    Fit in Cooper Discoverer ST MAXX 255/85R16 on 4 ProComp 69 Series 16x8" with -12mm offset.
    didn't take into consideration that the offset actually mades a difference and the 30mm difference between the OEM rim offset and the -12mm i have now caused me to start rubbing a lot more that anticipated. But i see why offsets are important.
    Ended up;
    • folding the pinch welds over
    • cutting the rear portion of the inner fender.
    • Softening the inner fenders with a heat gun and holding it in place while splashing water to force the plastic to its new mold location.
    drove 5kms without the front mudflaps and a lot of dirt got flung onto the body in the front and wasn't too pleased about it.
    Modified the OEM mudflaps by cutting a large portion of the middle / inner section of it so the tires wont rub. Also added a stainless steel bolt to the underside OEM mudflap mounting location. This holds/ pinches the rear half of the inner fender against the pinch weld/ cab itself and gives me a bit more room to play with. Outside of the mudflaps are still solid while the inner portion of it is a bit loose.
    Anyone recommend any front mudflap designs (prefer DIY)?
    Kaptain_02 likes this.
  6. Sep 11, 2020 at 5:51 AM
    #2846
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    Could you do me a huge favor the next time you have a tape measure and are by your truck. Would you be able to measure the actual height up to the top of xm antenna. I would like to know before I get some lift put on more than the coops. Parking ramps are a bitch for higher trucks
    Shveet likes this.
  7. Sep 14, 2020 at 9:55 AM
    #2847
    BLK_TRD
    BLK_TRD Well-Known Member
    Chad
    Pennsylvania
    2021 RAV4 XSE Hybrid. 2019 Black TRD OR DCSB *Sold
    Looks great! I've been eyeing these tires for awhile now. How are you liking them so far?
  8. Sep 15, 2020 at 7:49 PM
    #2848
    BurntChickenNugget
    BurntChickenNugget Well-Known Member
    Eric
    2017 Tacoma TRD
    Has anyone found mud guards they can run on stock wheels and suspension without rubbing in this size?
    Shveet likes this.
  9. Sep 15, 2020 at 10:02 PM
    #2849
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
  10. Sep 15, 2020 at 11:19 PM
    #2850
    BurntChickenNugget
    Eric
    2017 Tacoma TRD
  11. Sep 17, 2020 at 10:48 AM
    #2851
    slomaro
    slomaro Well-Known Member
    2018 TRD OR
    Alright I finally sucked it up and ordered my tires. The Toyota dealer up here got me the best price :confused: install isn't until Oct 8th though. Hopefully the S/T Maxx will be alright in some northern MI Nov and Dec snow.
    Shveet likes this.
  12. Sep 17, 2020 at 11:16 AM
    #2852
    Kaptain_02
    Kaptain_02 2019 OR
    Nice. I have the same wheels and have been prepping for the same tires on stock OR suspension, actually.
    I've already CMC'd, folded over the pinch welds, took the heat gun to the plastic and pushed it back as far as possible, and some slight trimming. Definitely confident that I'll be fine now
    Shveet[QUOTED] likes this.
  13. Sep 17, 2020 at 12:07 PM
    #2853
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Good thing you already did the CMC. part of my rubber catches the CMC and has worn down the paint to bare metal, not ecstatic about that since I was hoping to avoid needing to do CMC.... but C'est la Vie, next project to do.
    Other than that and not having access to a decent mud flap - I've not experienced any issues with the rims and tires (if you're wondering about the noise, it starts up around 75km/h but are quite up until then)
    Enjoy bud!
  14. Sep 17, 2020 at 12:11 PM
    #2854
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i waited about 4 weeks for my tires, Oct 8th from now is within a reasonable time frame.
    Buddy of mine up in the North (Thunder bay area) swears up and down that these are fantastic in the snow as dailies, claims better than most winters he had before. I'm trying mine for the first time this year and i'm sure they'll hold up just as well.
  15. Sep 17, 2020 at 1:03 PM
    #2855
    slomaro
    2018 TRD OR
    Yeah I'm not too worried, but I'm very excited to get rid of my Kuhmo Crugens. That's great to hear that they're pretty great in the snow, luckily I'm working from home anyways so I won't *need* to drive anywhere.
  16. Sep 19, 2020 at 7:16 AM
    #2856
    Hw523
    Hw523 Well-Known Member
    2020 Tacoma
    How big of a hit did your mpg take? Looking to put the st maxx's on my stock trdor that I daily drive.
  17. Sep 19, 2020 at 10:13 AM
    #2857
    BurntChickenNugget
    Eric
    2017 Tacoma TRD
    Just like a mile or so. Depends on how you drive. Don't forget it's a bigger tire so you'll have to do some math to figure out what you're actual milage is.
  18. Sep 21, 2020 at 11:12 PM
    #2858
    CUMMINGS 808
    CUMMINGS 808 Well-Known Member
    Preston
    Waianae, HI
    2019 SW DCSB OR 4x4 MT
    Bilstein 5100’s, Baja Designs yellow fogs, MESO Customs Smoked Turn Signals, Prinsu Roof Racks
    Anybody running M/T on OR stocks with 1 1/4” spacers? I wanna see the stance
  19. Sep 23, 2020 at 2:44 PM
    #2859
    Hw523
    2020 Tacoma
    Love it! Maybe lost 1mpg and its a little more sluggish, not like it was ever quick anyways. Only rubs a little on the flaps.
  20. Sep 23, 2020 at 2:50 PM
    #2860
    jschwerdtfeger
    jschwerdtfeger Well-Known Member
    Jeff
    Santa Cruz, CA
    2020 Tacoma DLCB TRD Off Road
    Fox 2.5/2.0, Deaver Expo Stage I
    What bar are you running to mount those lights?
