Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Aug 4, 2017 at 12:44 PM
    #301
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    He has a 2016
    Jibbs[OP] likes this.
  2. Aug 4, 2017 at 12:48 PM
    #302
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I'd be really curious to know what the issue ends up being if you figure it out @Camel89
  3. Aug 4, 2017 at 1:09 PM
    #303
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    Whoops. Scrolling through at work is dangerous lol. If that's the case besides wheels i don't know how that could be
    EatSleepTacos[QUOTED] likes this.
  4. Aug 4, 2017 at 1:16 PM
    #304
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    I think (I'll double check) that firestone got my alignment to 0 camber 0 toe and 3.something degrees caster with my stock UCA's. Or at least thats what the paper said. Drives great.
  5. Aug 4, 2017 at 1:16 PM
    #305
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Damn, that's impressive. Are you stock height?
  6. Aug 4, 2017 at 1:17 PM
    #306
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Yea, if anything I'm a little lower than stock due to the weight on the truck. Not sure if that affects it. 6112/5160s go on tomorrow though.
  7. Aug 4, 2017 at 1:19 PM
    #307
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahh, that makes more sense then. I kinda forgot this thread was about stock height suspension. Hopefully you can get good alignment numbers once you throw the lift on.
    mateo_roberto[QUOTED] likes this.
  8. Aug 4, 2017 at 1:21 PM
    #308
    rnicholls
    rnicholls Well-Known Member
    2016 TRD OR DCLB
    I am running aftermarket wheels with them however the offset is within 2 mm of stock. 17x8 10 offset.
  9. Aug 4, 2017 at 1:21 PM
    #309
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Yea, hoping they can squeeze out more than 2 dun-grees once the lift is in. Would have liked to get UCAs right out the gate, but after tires, wheels, leafs, coilovers, shocks...you see the way my bank account is set up...
    dre5491 likes this.
  10. Aug 4, 2017 at 1:22 PM
    #310
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm the same way. Rocking a ~3" lift in the front and was only able to get 1.56 degrees caster. Truck drives fine, but it's a little bit twitchy above 70mph.
    dre5491 likes this.
  11. Aug 4, 2017 at 1:23 PM
    #311
    rnicholls
    2016 TRD OR DCLB
    Feeling a little defeated. I hope my local place can make things work..
  12. Aug 4, 2017 at 1:26 PM
    #312
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    That stinks, I guess even a tiny bit of offset can mess with things. Hope they get you squared away
  13. Aug 4, 2017 at 1:27 PM
    #313
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Maybe call around? I'm sure you have thought of that already, but someone has to want your money.
  14. Aug 4, 2017 at 1:29 PM
    #314
    rnicholls
    2016 TRD OR DCLB
    So the original place was les schwab. And I asked them if they would retry it when the mud guard off and they refused. The only point it rubbed was full turn driver side. They tried to argue it was rubbing on metal. I told the local place I'd pay them to make it fit.
  15. Aug 4, 2017 at 1:33 PM
    #315
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So was it rubbing on the cab mount? And does this mean the mounted it on the wheel, put it on the truck, tested to see if it rubbed, THEN refused to let you drive it away? See if you can sign a disclamer saying you won't sue them or some shit.
    mateo_roberto likes this.
  16. Aug 4, 2017 at 1:34 PM
    #316
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    Sounds like a decent plan. I feel like if you call around, let the shop know in advance that you expect some clearance issues, and that you accept any/all liability for the consequences of clearance issues, you should be able to get them mounted hassle-free.
    Edit: I get mine mounted in like 3 hours on SCS F5's with 25mm offset. Discount Tire. Will give them the heads up that I expect them to rub, just so they don't go breakin' mah heart.
  17. Aug 4, 2017 at 1:36 PM
    #317
    rnicholls
    2016 TRD OR DCLB
    I offered to sign a liability form and they denied me. It was mounted and only rubbed at that full turn. They told me it was the rear part of the tire and I think without the mud flaps it would have worked.
  18. Aug 4, 2017 at 1:37 PM
    #318
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    God that's fucking annpying. They better not charge you a dime
  19. Aug 4, 2017 at 1:38 PM
    #319
    rnicholls
    2016 TRD OR DCLB
    No I didn't pay anything. I walked right into the shop and had them show me where the spot was and told them this size works on these trucks. Let's work on this together. No dice. So I told them I won't pay for any of it and they took the tires off the rims. Won't get my business again.
  20. Aug 4, 2017 at 1:39 PM
    #320
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Absolutely ridiculous. Sorry you're going through that.
