Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Jun 17, 2024 at 10:50 AM
    #3401
    slvrtaco11
    slvrtaco11 Well-Known Member
    SF bay area
    2018 TRD OFF ROAD AC
    tint, oem bed mat, CVC tune
    Great looking truck!
    BamaBillENC[QUOTED] likes this.
  2. Jun 17, 2024 at 11:14 AM
    #3402
    BamaBillENC
    BamaBillENC "It is what it is"
    Billy
    Eastern NC
    2022 Celestial Silver DCSB TRD OR 4x4 OTT
    Thanks @slvrtaco11, just started down the rabbit hole:spending:
    chefrover, Road_Warrior and Merling like this.
  3. Jun 17, 2024 at 11:29 AM
    #3403
    BamaBillENC
    Billy
    Eastern NC
    Stock were +25, so +1 is like a spacer...just a rub here or there when turning sharp and hitting a bump, just fender liner. I am down about 1.5 gal or so, maybe...next time I fill up I will check again, digital mpg to empty has never been right on my girl. I also dont feed her any corn , ever.
    Merling[QUOTED] likes this.
  4. Jun 17, 2024 at 11:35 AM
    #3404
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I have 1" wheel spacers. I like the look, didn't want to shell out $1k for wheels. Wheel spacers have nothing to do with fuel mileage, tire size does.
  5. Jun 17, 2024 at 11:44 AM
    #3405
    BamaBillENC
    Billy
    Eastern NC
    Agree, spacers can cause potential rubbin...I went from 265/75/16, to 255/85/16, that is the difference in mileage. I was reading it as if you were asking if there is a hit on mileage from tires, not spacers...love my taco, so gas mileage isnt a thing
    OldSchlPunk[QUOTED] likes this.
  6. Jun 19, 2024 at 9:00 PM
    #3406
    joms
    joms Well-Known Member
    2021 Super White Tacoma SR5 2wd
    Bone stock baby
    Sorry I know it’s an old post but on your second pic it seems like there is a dark spot on the UCA and possibly a rub mark? Just want to make sure before I pull the trigger on some skinnies
  7. Jun 20, 2024 at 12:12 PM
    #3407
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    multiply your miles by 1.06 to get an accurate total miles before dividing by gallons used.
    also a quick reference for speedo, up to about 45 mph indicated actual is about 2 mph faster, then up to about 75 it's 3 mph faster above that does it really matter.
  8. Aug 4, 2024 at 2:40 PM
    #3408
    beatadrum
    beatadrum Well-Known Member
    Jonathan
    Charleston, SC
    2023 Off Road 4x4 2004 SR5 DCSB
    Finally pulled the trigger on 255/85 KM3's and am very happy with how they handle daily driving and wet roads, averaging 18mpg. Stock Off Road suspension with minor trimming of the plastic.
  9. Aug 4, 2024 at 5:50 PM
    #3409
    BamaBillENC
    Billy
    Eastern NC
    Just put 5100's all around, top notch in front, 1" block in rear:anonymous:...many say lift don't do anything with rubbing, but now, have NO rubbing anywhere
  10. Aug 27, 2024 at 7:24 PM
    #3410
    scaley
    scaley Member
    2023 Black Tacoma TRD Off Road
    Overland Tailor Tune, Dobinsons MRRs and Icon RXTs with 33s, Redarc dual battery system, RCI sliders, rack, etc
    I'm about to pull the trigger on some Falken Wildpeak AT/4's in 255/85/16 on my stock OR rims, with plan to do UCAs and 2 inch lift later since it seems like these pizza cutters are fitting just fine.
    However, after reading almost all of this thread I curious if anyone has a picture of the Falken stuffed and at lock either direction up front. Just curious how bad / close the clearance is with stock suspension and if I'll be happy waiting through the winter to do the suspension lift and UCAs.
  11. Aug 27, 2024 at 9:43 PM
    #3411
    beatadrum
    Jonathan
    Charleston, SC
    you’ll rub just a tad at certain angles and worse over bumps, nothing a minor trim doesn’t solve
    scaley[QUOTED] likes this.
  12. Aug 28, 2024 at 3:56 PM
    #3412
    Taudelta
    Taudelta Well-Known Member
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Steelcraft Fortis front bumper, BodyArmor 4x4 rear bumper, LIft: Bilstein 5100+2885 OME coils, Icon RXT 3 stage. 255/85/16 wildpeak at4w
    Ive got trd OR on 2"lift bilstein +ome lift, I'm wondering do I need to get spacer for 255/85/16? Or it will be OK on stock OR rims?
  13. Aug 28, 2024 at 4:39 PM
    #3413
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Should be fine
    BC Hunter and Taudelta[QUOTED] like this.
  14. Aug 29, 2024 at 10:30 PM
    #3414
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Hi. im goingto install Falken and found that these tires have Load range C, i've got additional weight nearly 120lbs (bumpers) is it ok?
    chefrover likes this.
  15. Aug 29, 2024 at 11:15 PM
    #3415
    EvlFlash
    EvlFlash Well-Known Member
    Utah
    2023 Tacoma TRD OR 6MT
    It's not 255/85/16 but this is my 255/80/17 mounted on Method 701 17x8.5 wheels (0 offset).
    Dropped a strut and stuffed it, should clear the cab mount but a little cutting is needed. Didn't take a picture of it but it does rub on the fender liner at the front as well near the top. Don't know about the full front of a stock bumper since I have mine chopped up with a Greenlane bumper.
    th3clara and scaley[QUOTED] like this.
  16. Aug 29, 2024 at 11:36 PM
    #3416
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Another strange newbie question switching from 265/70/16 to 255/85/16 same rims, same offset - do I need another wheel alignment (last was made a month ago with suspension upgrade)? I heard that when you are moving to wider tires you need but no info about pizza cutters
  17. Aug 30, 2024 at 5:03 AM
    #3417
    Merling
    James
    NH
    c should be fine and yes to alignment imo
    BamaBillENC and BC Hunter like this.
  18. Aug 30, 2024 at 12:35 PM
    #3418
    scaley
    scaley Member
    This is exactly what I needed to see and hugely helpful! Thanks for taking the time to send the pics.
    EvlFlash[QUOTED] likes this.
  19. Sep 6, 2024 at 10:59 AM
    #3419
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    What are the specs on your whees? I'm running 16x8 0 offset. Just curious if this would work for me. I also have 1.4" of lift up front.
  20. Sep 6, 2024 at 8:52 PM
    #3420
    Taudelta
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Done. Confirming no rubbing at all. Need to mention - rims are stock, suspension - NOT
    JDKred and BamaBillENC like this.
