Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Jan 11, 2018 at 7:42 AM
    #801
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    Well this is before it is on a rim which will change the width of it. I will take another measurement after they are on.
  2. Jan 11, 2018 at 7:48 AM
    #802
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    The stock 16" look to be around 8.25+/- tread width. FYI
  3. Jan 11, 2018 at 8:57 AM
    #803
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I understand all that but I would have thought the section width/tread width difference wouldn't be upwards of 1.5 inches on each side. If a stock 265 has a tread width of 8.25 then a 255 should be a cm difference, less than half an inch.
  4. Jan 11, 2018 at 9:27 AM
    #804
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Tread width will change somewhat when the tire is mounted and inflated, too. People underestimate how much a tire changes shape before and after it's pressurized. :notsure:
    speedtre likes this.
  5. Jan 11, 2018 at 9:43 AM
    #805
    Sharpish
    Brian
    Fair enough thanks for giving me the 411.
    Looking forward to seeing how those bad boys look on the truck. I've always been a fan of the tall/skinny military/tractor look.
  6. Jan 11, 2018 at 12:24 PM
    #806
    WNYTACO
    Here it is. No rubbing so far just doing normal driving. I will now see what happens with th mud flaps installed....
    SpeySquatch, RocTaco, nDub and 3 others like this.
  7. Jan 11, 2018 at 12:26 PM
    #807
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    The flaps will probably rub.
    WNYTACO likes this.
  8. Jan 11, 2018 at 12:26 PM
    #808
    Miller1103
    Miller1103 Well-Known Member
    2017 trd or dc quickaand
    Looks good. The rear mud flaps are fine. My front I thought was fine until it flexed and than they would catch the tires. St max tho
    WNYTACO[QUOTED] likes this.
  9. Jan 11, 2018 at 12:33 PM
    #809
    WNYTACO
    They certainly are pizza cutters but I like the look. They of course are noisier than the stock tires so we will see if that gets worse or better. Right now there is 42psi in each tire which I am not sure if that is good or bad for now. I measured before and after and gained about 2 1/4 inches in the front and I am not sure about in the back as I have airbags back there and had taken some air out of them before measuring.
  10. Jan 11, 2018 at 12:39 PM
    #810
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    My old STs got louder as I added mileage. Similar to what I’ve read the Duratracs do.
    I liked the STMaxx better for my used, but the ST was still an awesome tire though.
  11. Jan 11, 2018 at 12:53 PM
    #811
    MacCTD
    MacCTD Active Member
    '10 Tundra CM
    Looks great, thanks for posting the pictures and info!
  12. Jan 11, 2018 at 1:02 PM
    #812
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Wut. Did you go from stock to 33's? How the crap did you get more than an inch and change?
  13. Jan 11, 2018 at 1:12 PM
    #813
    WNYTACO
    Good call on that I was off by an inch. 34 1/2 to 35 3/4! I had to go back and remeasure. For some reason I had 36 3/4 in my head!!
  14. Jan 11, 2018 at 1:15 PM
    #814
    Sharpish
    Brian
    Can you please post one pic of the back of the truck looking at the tailgate with the whole truck and tires visible?
  15. Jan 11, 2018 at 1:16 PM
    #815
    WNYTACO
    Thanks for the heads up. These really were the only choice for me if I wanted to keep the weight of the tires down in this size.
  16. Jan 11, 2018 at 1:23 PM
    #816
    backcountryj
    Jonathan
    GA
    Yea they get hefty at that size.
    I’m considering the Mastercraft CXT in the same size, but I can’t find many reviews.
  17. Jan 11, 2018 at 1:52 PM
    #817
    WNYTACO
    Is this what you wanted?
    BassAckwards likes this.
  18. Jan 11, 2018 at 1:55 PM
    #818
    Sharpish
    Brian
    perfect, thanks!
  19. Jan 11, 2018 at 2:03 PM
    #819
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    Thank you for this. I usually buy snow tires and rims for my vehicles but that was before I had tpms in rims. I don't wanna deal with that. I want an all season tire that is not bad in the snow. I like what I had been reading about the cooper ST MAXX so far in snow. No one was talking about icey stuff.
    Also I was really impressed with the factory goodyears in the snow so I'd really be kicking myself if I bought something else that wasn't as good.
  20. Jan 11, 2018 at 2:12 PM
    #820
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    This is what went through my mind when I saw Super Tuner.
    stevotivo12[QUOTED] likes this.
