Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Jan 14, 2018 at 4:45 PM
    #841
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    I think that's the job of any tire. Inspire enough confidence to bring out any fun loving drivers inner jackass. It sure doesn't take much for my jackass to come out screaming
    dre5491 likes this.
  2. Jan 17, 2018 at 6:22 AM
    #842
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Forgive me if this is a stupid question, but do the trds have different control arms or are there just better shocks to make the height difference? What exactly is different in their front suspension?
  3. Jan 17, 2018 at 6:28 AM
    #843
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    The front shocks on the Offroads are basically bilstein 4600s
  4. Jan 17, 2018 at 7:09 AM
    #844
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Control arms are the same
  5. Jan 17, 2018 at 8:17 AM
    #845
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I think the TRD has the same ride height as the SR5, limited, etc. The suspension is the same aside from the shocks. Springs give lift.
    The PRO has a coilover setup that gives it the inch or two of lift from the factory.
    dre5491 likes this.
  6. Jan 17, 2018 at 8:46 AM
    #846
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    1” but yes
  7. Jan 17, 2018 at 12:26 PM
    #847
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Anyone running the Toyo's in this size?
    BC Hunter and mikestaco17 like this.
  8. Jan 17, 2018 at 12:53 PM
    #848
    Sharpish
    Brian
    The 255/80r17 toyo at2 is a good tire and only 50 lbs for Eload true 33
    tundraconvert and IronPeak like this.
  9. Jan 17, 2018 at 1:57 PM
    #849
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I talked to @LadyRed . She's the only person I know is that runs the toyo MT. It's the biggest tire in its class 33.4 or 5 iirc.
    mikestaco17, 61ragtop and LadyRed like this.
  10. Jan 17, 2018 at 2:04 PM
    #850
    Woodrow F Call
    Colorful Colorado
    I was curious if they had issues with rubbing.
    BC Hunter likes this.
  11. Jan 17, 2018 at 2:26 PM
    #851
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    These are quotes from her when I PM'd her.
    I did have to trim someplastic, which I had to do anyways for the CBI bumper I put in. They rub slightly on the cab mount (no rubbing on UCA or LCA) on the front drivers at full lock in reverse. I alleviated all other rubbing by having an alignment done with as much caster possible.
    She's running 3.3-3.4 of castor
  12. Jan 19, 2018 at 7:49 AM
    #852
    Woodrow F Call
    Colorful Colorado
    Thanks.
  13. Jan 19, 2018 at 7:56 AM
    #853
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    Well now that I have 600 miles on my Cooper Discoverer S/T's I thought I would give another update. Since I had them mounted we got 15" of snow which also had ice with it. The tires handled great. I can't say weather they handle better than the stock ones (Which I thought handled well in those conditions) when they were new but they sure didn't handle worse. I am currently running 36psi when cold all around which seems to be working for now. As for road noise they are still loader compared to the stock and I have since gotten use to it. The real test was to see if my wife mentioned anything about it and so far she hasn't which is amazing as she usually picks up on that sort of stuff. I am a happy customer so far.
  14. Jan 19, 2018 at 8:02 AM
    #854
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    But she has aftermarket wheels I’m fairly certain correct @LadyRed
    Edit: just confirmed she has ray10s
    xxtavixx likes this.
  15. Jan 19, 2018 at 8:09 AM
    #855
    Woodrow F Call
    Colorful Colorado
    Offset?
  16. Jan 19, 2018 at 8:18 AM
    #856
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    LadyRed likes this.
  17. Jan 19, 2018 at 8:32 AM
    #857
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    I am sure its been covered somewhere else - but is there a comparison list of the different pizza cutter size options with tire weight?
    mikestaco17 likes this.
  18. Jan 19, 2018 at 8:39 AM
    #858
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    Nope maybe not a bad idea though?
  19. Jan 19, 2018 at 8:53 AM
    #859
    LadyRed
    LadyRed Making all the right wrong turns
    Leah
    Florida/Mississippi
    2016 4x4 TRD OR DCSB
    OME Lift Total Chaos UCA SCS Ray 10s
    Someone has definitely put that together in a thread on here. I stumbled upon it once - I will see if I can dig it up. They're are not a lot of options out there. I think the Toyo Open Country M/Ts are the heaviest and tallest of the class.
    BC Hunter, mikestaco17 and 61ragtop like this.
  20. Jan 19, 2018 at 8:59 AM
    #860
    LadyRed
    Leah
    Florida/Mississippi
