Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Feb 15, 2018 at 5:07 AM
    #1001
    4x4sporttaco
    4x4sporttaco Member
    2017 white trd 4x4 sport
    I may have jumped the gun on your entire post, but besides the upgraded tires, did you have to do anything else?
    Your truck looks sick by the way!
  2. Feb 15, 2018 at 5:09 AM
    #1002
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    is my math formula correct to find out the actual mileage? For odometer: current miles/current revolutions per mile = actual miles/previous tire revolutions per mile For mpg: current mpg/current revolutions per mile = actual mpg/previous tire revolutions per mile. example odometer=64.3/610=72.1/610 or mpg=17.5/610=19.5/684
  3. Feb 15, 2018 at 5:09 AM
    #1003
    adk_tacoma
    Joe
    Waterford, NY
    who's truck?
  4. Feb 15, 2018 at 5:12 AM
    #1004
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just figure out the percentage difference in diameter (8% for me) then multiply the amount of miles I’ve driven in a tank by 1.08. That gives me my true miles.
    BC Hunter and Tocamo like this.
  5. Feb 15, 2018 at 5:20 AM
    #1005
    adk_tacoma
    Joe
    Waterford, NY
    We both come to the same answers using different formulas so are answers must be true.
    EatSleepTacos[QUOTED] likes this.
  6. Feb 15, 2018 at 6:52 AM
    #1006
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    So my tires are supposed to be here on Friday (DC Extreme Country 255/85-16). I would like to install them on Saturday, but the last of my lift components won't be here until Monday. I don't want to get an alignment until after I have the lift installed. Other than rubbing, I don't think there would be an issue waiting a week (2 max) before getting an alignment. My question is how many have had rubbing issues prior to getting an alignment?
    Stock TRDOR DCLB with stock wheels.
  7. Feb 15, 2018 at 7:04 AM
    #1007
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    See my posts a few above this- when I lifted the front end my UCAs started rubbing on the inside of the tires. You'll probably need to get spacers to accomodate that in the absence of wheels with less offset.
    I haven't gotten the spacers yet so I can't report on fender rubbing or any trimming/etc. I'll need to do.
  8. Feb 15, 2018 at 7:12 AM
    #1008
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    So I run Cooper ST's (255/85/16) on stock everything right now but I did just buy the PTR13-35150 - Bilstein TRD PRO kit (2015 Pro suspension) and now I am wondering if this is going to cause me a rubbing issue on the stock uca's. I believe this kit will increase the front for me by 1.25 to 1.50". I only ask because I read what @Jibbs said after installing a OME setup.
  9. Feb 15, 2018 at 8:31 AM
    #1009
    Jon8251
    Jon
    Southern MD
    I'm looking at just doing the tires for now. I received the PTR13-35150 Bilstein TRD PRO kit yesterday and my HS 3-leaf AAL will be in on Monday. I will hold off on installing the suspension while I learn more about the lift and it's affect on the UCAs. So with that being said, how far out was everyone's alignment when going from stock to 255/85-16. Can I give it a few weeks while I'm sorting the suspension questions?
  10. Feb 15, 2018 at 8:44 AM
    #1010
    WNYTACO
    Looks like we have similar setups. I got my kit earlier this week. I am still debating what to do for the rear. I currently run airbags with daystar cradles but I do not want to rely on those for leveling me out all of the time....
  11. Feb 15, 2018 at 8:53 AM
    #1011
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Post 1055
    https://www.tacomaworld.com/threads/bilstein-6112.421995/page-53#post-16991045
    Post 1093 for taco pics
    Never had rubbing stock and post lift
  12. Feb 15, 2018 at 10:11 AM
    #1012
    Jon8251
    Jon
    Southern MD
  13. Feb 15, 2018 at 10:20 AM
    #1013
    Jon8251
    Jon
    Southern MD
  14. Feb 15, 2018 at 10:23 AM
    #1014
    Jon8251
    Jon
    Southern MD
    I went with the progressive AAL to maintain as much ride quality as I could without buying a whole leaf pack. I don't haul anything much with this truck so I am not as concerned with sagging as some are.
  15. Feb 15, 2018 at 10:24 AM
    #1015
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    He's running aftermarket UCAs too, I wonder if they are narrower than stock. Curious if he was actually on stock wheels when he lifted too, because I see he isn't now, and even half an inch less offset than the stock OR wheels would probably clear the UCA. As it is, I'm only rubbing when my suspension actually articulates.
    I also removed my sway bar when I did the suspension, I am vaguely curious if that has anything to do with it.
    oscolivar1 likes this.
  16. Feb 15, 2018 at 11:07 AM
    #1016
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I changed my UCA to fix my alignment....I didn't feel like going to the shop every month for an alignment. I like my MPG...
  17. Feb 15, 2018 at 11:10 AM
    #1017
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    I've been running the TRD FJ team trails since I bought the truck. It came off my old taco.
  18. Feb 15, 2018 at 12:40 PM
    #1018
    Commocean
    Commocean Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    Is the only reason a 265/70/17 is the largest tire you can install on a stock suspension/wheels because of the upper control arm? Does the skinnier tire allow you to go taller because it's less wide than a 265/70?
    BC Hunter likes this.
  19. Feb 15, 2018 at 1:40 PM
    #1019
    Jon8251
    Jon
    Southern MD
    OK. So those are 16x8 rather than the 16x7 of the stock OR rims. I'm not sure of the other dimensions (BS, OS, etc...) but that may be the fly in the ointment.
  20. Feb 15, 2018 at 3:40 PM
    #1020
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    No the team trails are 16x7.5 +15mm OS
