Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Feb 25, 2018 at 9:05 PM
    #1101
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    weight pulling the truck down
  2. Feb 25, 2018 at 11:30 PM
    #1102
    Cpngo
    Cpngo Well-Known Member
    CA
    2017 DCLB TRD OR 4x4
    Any one getting rubbing on the UCA? I cant get to full lock on either side now. Also so marking on my resi.
  3. Feb 26, 2018 at 4:37 AM
    #1103
    yellowdogpaddler
    yellowdogpaddler Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    Andrew, I just re-read your post. Was it only rubbing on your mudflap after you installed sliders, and after removing the mudflaps you solved that problem? Sorry I can't recall and am not able to jump to your build thread right now- are you on a stock suspension or is what you are describing on a lift?
  4. Feb 26, 2018 at 5:08 AM
    #1104
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    That was on stock suspension, I’m now lifted.
  5. Feb 26, 2018 at 5:16 AM
    #1105
    yellowdogpaddler
    doug
    2018 DCLB OR
    Did you keep the 255 or did you go to 285 with your lift?
  6. Feb 26, 2018 at 5:31 AM
    #1106
    Sandytaco14
    Andrew
    North al
    '17 trd offroad 4x4
    Nope tall skinnies are still in the truck
  7. Feb 26, 2018 at 5:32 AM
    #1107
    c4ifford
    c4ifford Active Member
    Gen3 TRD
    none yet
    This thread is really enthralling.
    So my statement/question:
    This seems like a valid option for not having to put a lift on a brand new truck, I bought the TRD offroad package, much for the same reason why I bought the Rubicon edition of my Jeep, I wanted the lockers, diffs, gearing and such that the offroad package gives you from the factory. However, you do end up replacing most of the suspension obviously if you want to run bigger tires. I have noticed whilst researching the best way to run '33s' on my taco that the suspension lifts are quite a bit more expensive then they are for Jeeps. That being said I think this 'skinny' option seems like a great way utilize what I think is a great stock suspension for the TRD.
    So now for my question for the group; what space/puck lifts would compliment running the skinny setup on a stock TRD Offroad suspension? Sorry if I missed that somewhere in the thread it's up to 56 pages currently.
  8. Feb 26, 2018 at 5:35 AM
    #1108
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Personally, I think the factory off road suspension would be best until you replace the factory components. You can get a decent lift for less than 1100. Use the factory until then.
    yellowdogpaddler likes this.
  9. Feb 26, 2018 at 5:35 AM
    #1109
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Also, welcome to TW!
  10. Feb 26, 2018 at 5:38 AM
    #1110
    yellowdogpaddler
    doug
    2018 DCLB OR
    Thanks. I am looking into which tires/suspension to go with for overlanding. The more research I do the further down the hole I go. Initially I was just considering what most guys run, 285/70/17. Then I started considering the cost and ease of having tires maintained and looking to purchase from a national distributor, I am moving in a few months. So that can/has put a limit on which tires I can purchase. After reading about performance on and off road along with fuel efficiency I am leaning towards the 255/85/16. Adding to the mix is if I swap out for an aftermarket wheel and now learning about offset/backspacing and lug and hub centric... This hole just keeps going and going
    Mabel and OH-_SNAP like this.
  11. Feb 26, 2018 at 5:38 AM
    #1111
    c4ifford
    Gen3 TRD
    none yet
    Well, I want to stay with the factory suspension, or as close to it as I can. Or just pull the trigger and spend 3 -5k for a good suspension.
    That's one thing I learned while building my Jeep, just make a decision and stick to it. The Jeep had 4 different amalgamations of lifts by the time it was 'done'.
    Toyotico and yellowdogpaddler like this.
  12. Feb 26, 2018 at 5:39 AM
    #1112
    c4ifford
    Gen3 TRD
    none yet
    Thanks, on my second tacoma now. This will be the first one that's actually going to be built though.
  13. Feb 26, 2018 at 5:40 AM
    #1113
    yellowdogpaddler
    doug
    2018 DCLB OR
    This is the direction I am leaning towards as well.
  14. Feb 26, 2018 at 5:43 AM
    #1114
    c4ifford
    Gen3 TRD
    none yet
    Yea, but even without rubbing the 33's look pretty stuffed on the truck. Wouldn't just throwing some 1" spacers go a long way it helping ?
  15. Feb 26, 2018 at 5:45 AM
    #1115
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I'm doing an overland build. I totaled my 2016 trd off-road on Jan 30th (hit a tree). My 2018 Tacoma is getting (5) 255 85 16 cooper st maxx on the way from discount tire. I also have an full OME kit (90021 shocks and 887 springs) and heavy dakars enroute from Headstrong offroad. Both of those items should be at my house in the next 2 days.
  16. Feb 26, 2018 at 5:48 AM
    #1116
    yellowdogpaddler
    doug
    2018 DCLB OR
    Some advice I was given by @Coot83 was to drive the truck for a while, learn what it can and can't do before spending money. The more I thought about this the more impact it has had. I have read on here about those who just purchased a particular part without considering their entire build and ended up having to swap out or "live with it". Putting a good set of tires now seems like the very first option in the build. Avoiding purchasing a cheap or expensive suspension decision until I know what my additional weight will help me decide what suspension will suit my needs.
    Coot83 likes this.
  17. Feb 26, 2018 at 5:48 AM
    #1117
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Ive found on my last truck (2016 trd offroad) that the tire I had (Maxxis 255 85 16) didn't rub at all. it was really stuffed, but didn't rub at full lock. that was on the street. So, maybe offroad itll rub a bit, but idk.
  18. Feb 26, 2018 at 5:49 AM
    #1118
    yellowdogpaddler
    doug
    2018 DCLB OR
    Would you share what price you got from Discount Tire for the Coopers?
  19. Feb 26, 2018 at 5:51 AM
    #1119
    c4ifford
    Gen3 TRD
    none yet
    Just say screw it and get 35's =)
  20. Feb 26, 2018 at 5:52 AM
    #1120
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I like tall and skinny, and I have no money for regear. If I was going to do 35s, Id do 37s.
