Put 255/85/16s on stock OR wheels and suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jibbs, May 12, 2017.
  1. Feb 28, 2018 at 8:20 AM
    #1141
    Jon8251
    Jon8251 Well-Known Member
    Jon
    Southern MD
    2017 Quicksand DCLB Off-Road
    TRD Pro suspension HS Progressive AAL 255/85-16 DC Extreme Country TRD Pro grille Softopper Internal LEDs Other misc crap
    So is it pretty certain that stock mud flaps will need to be removed with this size?
  2. Feb 28, 2018 at 8:28 AM
    #1142
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Maybe your caster is too aggressive. +3.3 is very high, although that SHOULD move you away from the cab mount. Usually I only see 3+ when someone is running massive tires
  3. Feb 28, 2018 at 8:34 AM
    #1143
    Cpngo
    Cpngo Well-Known Member
    CA
    2017 DCLB TRD OR 4x4
    That's the thing, the tires aren't massive. They're 33", it's insane that 2 inches have basically turned my truck into a rubbing nightmare lol.
    Mr-Paul and vitistop like this.
  4. Feb 28, 2018 at 9:00 AM
    #1144
    Toyotico
    Toyotico Well-Known Member
    Jonny
    Cartersville, Georgia
    2017 Silver Tacoma 4x4 dclb
    I’m thinking the same thing dude. Let us know what you find out. I was planning a lift next up...
  5. Feb 28, 2018 at 9:17 AM
    #1145
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    285/75/16 or bigger requires a cmc or you will get rubbing
    vitistop likes this.
  6. Feb 28, 2018 at 9:21 AM
    #1146
    Cpngo
    CA
    Does this apply to the 255/85/16?
  7. Feb 28, 2018 at 9:33 AM
    #1147
    Sharpish
    Brian
    Perhaps a little more offset would fix it. Those wheels are +30 offset, very little. maybe 4 runner wheels at +15 or beadlocks at +10 or sema wheels at +4 would help push it away from the UCA and cab mount.
  8. Feb 28, 2018 at 9:35 AM
    #1148
    Sharpish
    Brian
    Visually it looks like the super high caster is pushing the wheel too far forward in the wheel well, did it rip off the front air dam mud flap? You can see with the naked eye that +3.3 caster you need more lift .
  9. Feb 28, 2018 at 9:39 AM
    #1149
    Cpngo
    CA
    Yeah, I was looking at wheels too, but at the same time if the spacers are essentially doing what wheels with more back space would do, it seems like I would still rub. No rub on plastic, just cab mount. Maybe i split the difference and get a thinner spacer?
  10. Feb 28, 2018 at 9:41 AM
    #1150
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    255/85/16 is taller than 285/75/16, but not as wide. Me personally I'd do a cmc, and not worry about rubbing, and if I went bigger later on it wouldn't be an issue.
    mikestaco17 likes this.
  11. Feb 28, 2018 at 9:48 AM
    #1151
    ivanza
    ivanza Well-Known Member
    Bay area, CA
    2017 MGM TRD OR MT
    Mobtown skids Fox 2.5 DSC OME heavy leaf
    does anyone have pics of how they trimed the plastic coming off the fender flares? Thats where mine rub right now? Also, do sparies fit these tires alright? I want to move my km2's on some steelie/sparies and run my stock tires back on the stock rims.
  12. Feb 28, 2018 at 10:01 AM
    #1152
    Jibbs
    Jibbs [OP] "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I am unclear on why you're rubbing there, is any part of your suspension modified? I can promise you that I've wheeled my truck *plenty* since putting 255s on and haven't rubbed, as have others in this thread. A minor lift of any sort will potentially cause you issues, as I learned when putting 886s on in preparation for my front bumper.
    Are you actually rubbing on the cab mount with the spacers? The wheels won't move towards the cab mount at any point so if you're clear of it lock to lock, it wont be an issue. You can see from my pictures that I was really close to it stock, and I never touched it.
    When I lifted the front I had to use spacers to clear my factory UCAs and 1.25" spidertrax got me what I needed without any rubbing issues on the street. Granted, I haven't taken them wheeling yet, and there may be a trouble spot where I'll have to use a heat gun and remold the front of the fender lining.
    That's more people in this thread than there are to count, and of those I know at least myself and @Sandytaco14 wheel our trucks and aren't exactly gentle on them, and we didn't have issues. As stated above, I'd love more information on your setup to see if we can figure out whats causing your issues.
    Nah, the whole point of this thread/size is that you don't have to do a bunch of shit to fit 255s like you do 285s
    nDub likes this.
  13. Feb 28, 2018 at 10:07 AM
    #1153
    Jon8251
    Jon
    Southern MD
    I installed a minor <2" lift on my truck and I am putting the 255s on as soon as I get my .75" spacers. I'm thinking the spacers will alleviate any issue I may have with the UCA but I am not sure of the rest of the potential spots. Where were you having troubles with rubbing after you put in your springs?
  14. Feb 28, 2018 at 10:10 AM
    #1154
    vitistop
    vitistop ig: twosie_silverback
    Vit
    Los Angeles
    2017 Silver Tacoma TRD OR
    Bilstein 6112 front, Bilstein 5100 rear, Dakars
    even with cmc, i still rub at certain angles.
  15. Feb 28, 2018 at 10:18 AM
    #1155
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I rubbed on the stock UCAs after the lift. I put 1.25 spidertrax on and solved it. I can't speak to any aftermarket UCAs.
    There is a place in the front of the fender well that I may run into issues while wheeling, but I haven't touched it on-road yet. The problem spot is an easy enough fix, it's just all the black plastic shit in front of the tire, and I can just heat that up and mold it forward if I need to
    Sandytaco14 likes this.
  16. Feb 28, 2018 at 10:20 AM
    #1156
    Sandytaco14
    Sandytaco14 IG: qstaco17
    Andrew
    North al
    '17 trd offroad 4x4
    Don’t believe us then shit lol. I went through a ton of shit and never rubbed on anything except mud flaps.
  17. Feb 28, 2018 at 10:25 AM
    #1157
    ivanza
    Bay area, CA
    2017 MGM TRD OR MT
    will changing from stock tires to these km2s throw off your alignment that much. I had 2.5 caster with stock tires after putting the fox coilovers and UCAs on.
  18. Feb 28, 2018 at 10:30 AM
    #1158
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I mean its possible right? The bigger tires do move the suspension components around, so if you put your fox stuff on with the stock tire size, it could very well be different. Alignments are pretty cheap anyway, probably worth checking out. If you wheel your truck look into the Firestone lifetime alignment. You *should* get alignments after offroading (I never do lol), and it's only like $150 or something.
  19. Feb 28, 2018 at 10:32 AM
    #1159
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    @Jibbs My understanding is there has to be something on this truck that is not stock. Correct?
  20. Feb 28, 2018 at 10:33 AM
    #1160
    ivanza
    Bay area, CA
    2017 MGM TRD OR MT
    Yeah thanks, I'll definitely get an alignment in the next few days. I don't mind chopping whatever to get it right. I just wanted to see some clean executions to follow. That little return flange on the fender flares that wraps into the wheel well is where i'm rubbing right now. And I saw a guys 285's on a 2nd gen where he'd trimmed that quite clean, didn't have my phone to get pics.
