Putting automatic transmission in neutral when stopped?
Discussion in '4 Cylinder' started by paid4c4, Dec 15, 2012.
  1. Dec 15, 2012 at 8:10 PM
    paid4c4
    paid4c4 [OP] Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    Any thoughts about putting the transmission in neutral when stopped at traffic lights or while stuck in traffic. I do sometimes when I see traffic is going to be stopped for a while or at a really long lights. Does this save gas and cause the transmission to run cooler?
    Bill
  2. Dec 15, 2012 at 8:14 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Doesn't save gas.
    Might run a little cooler since you aren't slipping the TC, but the tradeoff is increased wear on the clutch packs from the disengagement and re-engagement.
    Manual trans is a different story.
    Holding your foot on the clutch when at a stop causes the crankshaft to ride forward in the bearings and alters the wear pattern.
  3. Dec 15, 2012 at 8:14 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    yea, i wouldnt do it. :notsure:
  4. Dec 15, 2012 at 8:17 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    if i’m stuck in traffic for a long time i will put it in park.
  5. Dec 15, 2012 at 10:19 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not just the trans, but it loads and unloads the other parts of your driveline (such as U joints) unnecessarily. If you know you're stopped for 5 minutes, just put it in park.
  6. Dec 16, 2012 at 6:41 AM
    dragonballz
    dragonballz Member
    http://www.youtube.com/watch?v=3KPF4NPrz2Q
    This guy is showing fuel consumption in his Civic using the Scan Gauge. At idle, in neutral it is using less fuel than if he kept it in drive. It is 0.9 Liters per hour in neutral. 1.15 Liters per hour in Drive.
    I have no idea if it has the same effect in the Tacomas.
    Hi guys. already learned alot about the tacomas. Going to do the tailgate hose clamp thingy later on.
  7. Dec 16, 2012 at 6:50 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I would assume the fuel consumption would be the same for nuetral and park....?
  8. Dec 16, 2012 at 6:55 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Sounds like someone should have bought a stick :D
  9. Dec 16, 2012 at 12:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    0.25 LPH
    That's 8.43 Ounces per hour.
    15 hours of idling to make a difference of 1 gallon.
    5 hour trip at 30mph avg, 1 hour of that is idling.
    Baseline 25mpg (normal driving, leave trans in drive)
    5x30=150 miles
    150/25 = 6 gallons used
    Same trip, shift to neutral, 5.934 gallons used
    150/5.934 = 25.28mpg
    Like I said... no impact on fuel economy. That is statistically insignificant, and is assuming a full hour of idling on a 5 hour trip of 150 miles.
  10. Dec 16, 2012 at 1:33 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    It won't do you any good. The fuel saved is so minimal that it's not worth mentioning.
  11. Dec 16, 2012 at 5:32 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    At a red light I just hold the truck with the brake. If it's taking several turns of the light to get through an intersection I put the transmission in neutral or park, just so I can move my feet around. If traffic's at a real standstill I shut the engine off.
  12. Dec 16, 2012 at 5:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Just leave it in gear and enjoy the ride. [​IMG]
