putting stockers bak on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmc31763, Jun 5, 2011.
  1. Jun 5, 2011 at 3:26 PM
    jmc31763
    jmc31763 [OP] Member
    ga
    lifted trd prerunner
    3 inch body lift,3 inch supsp lift,17x9 wheels and 295/70 nitto tires
    Hey guys i have an 09 tacoma with 3inch body and 3 inch sup lifts with 295/70 tires on 17x9 wheels.The tires scrub on the inner supports of the truck.does anyone knw how it would look if i put the stock wheels back on my 295s and would it not scrub then>anyone have any pics lifted on the stock wheels running 295/70s? thanks besides i think i like the stock look better with the bigger tires and lift
  2. Jun 5, 2011 at 3:33 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Whats the backspacing of your wheels?
    Putting the tires on the stock rims will make it scrub much worse.
    Did you chop your cab mounts yet?
  3. Jun 5, 2011 at 3:39 PM
    jmc31763
    ga
    not sure of the back spacing.but no havent chopped cab mounts.wasnt sure if i should mess with that.i had 285s on the stocks with 3inch sup then added the 3 inch body didnt scrub on the 285s so i fig it wouldnt on the 295s since i went up 3 more inches
  4. Jun 5, 2011 at 3:42 PM
    KPT
    09 Prerunner
    You had 285s on the stock rims and didn't rub on the uca, or the cab mounts, even at full lock, and with the suspension flexed? No wheel spacers?
    First thing you need to do is to find out the backspacing of your rims, that's the single most important thing to do know to avoid rubbing in the first place.
  5. Jun 5, 2011 at 3:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You are pretty much forced to if you offroad at all & are running anything larger than a 32" & don't want that frame rub ( I still don't get why they left that much metal hanging out there doing nothing, must be there for assembly line movement or ???)
  6. Jun 5, 2011 at 3:53 PM
    jmc31763
    ga
    yeah tell me about i used to have a 03 tacoma with just a body lift and ran 33x1250 on 15x10 wheels with barely any trimming.and kpt yeah 285s barely touch control arm when turning all the way but nothing like now
  7. Jun 5, 2011 at 4:05 PM
    KPT
    09 Prerunner
    Gotcha so you must have less backspacing on these new rims, which is good. I say just chop your cab mounts
  8. Jun 5, 2011 at 4:09 PM
    jmc31763
    ga
    well do u think i would scrub any worse than i did on the uca with my 285s if i just went bak with the stocks i mean i only went up one size in tire but 3 more inch n lift,I can live with a litt scub on uca turned all the way,i just think i would like the stock look better an i have the after markets sold as soon as they come off 2.just dont wanna scrub the same if i takem off.
  9. Jun 5, 2011 at 4:19 PM
    KPT
    09 Prerunner
    They will rub worse. No matter what you do, even if you get wheel spacers for the stockers, you are going to need to chop your cab mounts to run 295s
  10. Jun 6, 2011 at 3:22 PM
    jmc31763
    ga
    turns out i gotta have those wheel spacers for the stock wheels,what size do u do i need to get?
  11. Jun 6, 2011 at 3:25 PM
    KPT
    09 Prerunner
    Spidertrax 1.25", hubcentric
  12. Jun 6, 2011 at 3:36 PM
    jmc31763
    ga
    thanx bro
  13. Jun 6, 2011 at 3:49 PM
    jmc31763
    ga
    one more question,108mm center bore on the spacers work?
  14. Jun 6, 2011 at 4:16 PM
    KPT
    09 Prerunner
    I believe the Tacoma hubs are 106mm
  15. Jun 9, 2011 at 4:58 PM
    jmc31763
    ga
  16. Jun 13, 2011 at 6:22 PM
    jmc31763
    ga
    anyone have any tire bouncing and steering wheel shake after using wheel adapters?
  17. Jun 13, 2011 at 6:23 PM
    KPT
    09 Prerunner
    Are the wheel adapters hub-centric?
  18. Jun 13, 2011 at 6:39 PM
    jmc31763
    ga
  19. Jun 13, 2011 at 6:41 PM
    KPT
    09 Prerunner
    Hmmm first thing to check is that the wheels are still properly balanced....
  20. Jun 13, 2011 at 6:43 PM
    jmc31763
    ga
    yeah that was my thought to try 1st...havent takn it bak to the tire shop yet but thats my 1st stop...just was gettn some opinions in case that wasnt it
