putting T badge back on grillcraft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tio Pepe, Jan 29, 2010.
  1. Jan 29, 2010 at 8:59 AM
    Tio Pepe
    Tio Pepe [OP] Well-Known Member
    eastexas
    2009 4x4-Dbl Cab, Long Bed, SR5, SUPERCHARGED
    TRD installed Supercharger, Air Intake, & Exhaust. 3" lift with OME 885's & OME AAL. JBA shorty headers
    So I got the grillcraft grill installed and love it, but I want to put the Toyota "T" badge back on, and have some questions for the TW experts.
    First, I want to paint the Badge to match the truck (silver streak) instead of the chrome. I ordered color matched spray paint for this. I am planning on sanding it like crazy, spraying adhesion promoter, then painting it. This should work, right?
    Second, and this is my big issue. Whats the best way to re-attach the badge to the Grillcraft Grille? I have the black steel mesh one. The T badge has three tabs on it where it snapped into the factory grill, and it is sort of hollowed out behind it. My thought was to cut the tabs offs, and put in some sort of filler so that it is solid and flat on the back. Then use 3m tape. I dont know the best kind of "filler" for the back, and I dont know if 3m tape is best choice going onto that mesh grill. Will this work? Any better ideas?
  2. Jan 29, 2010 at 9:02 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    the 3m stuff is the best. you could use a queck set "instant epoxy", the kind that comes in that dual syringe (sp) kind of thing. i'd cut the tabs, fill, and sand down the filler before paint though.
  3. Jan 29, 2010 at 9:05 AM
    Tio Pepe
    eastexas
    Good idea. What should I use for the "filler" ?
  4. Jan 29, 2010 at 9:07 AM
    Red Razor
    Red Razor Well-Known Member
    Greensburg PA
    06 TRD Sport 4X4
    Could you JB weld in some pieces of all thread to the back of the emblem and use nuts on the inside of the grill?
  5. Jan 29, 2010 at 9:11 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Gorrilla Glue works to. Did that for the R/T emblem on my dakota
  6. Jan 29, 2010 at 9:12 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  7. Jan 29, 2010 at 9:45 AM
    Tio Pepe
    eastexas
    So i can just take that epoxy to fill the back and then once it dries (and ive sanded and painted) then I can use the 3m tape on it to stick on the grill? You guys rock.
  8. Jan 29, 2010 at 9:50 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's just that easy....and the epuxy is so easy to work with, you may not even need to sand. and just a tip, if you wear a set of latex gloves with the epoxy, oyu can just apply it with your fingers, and get the perfect amount and then smooth it out.
  9. Jan 29, 2010 at 9:55 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    you shouldnt need to sand down the emblem itself. i just repainted all my badges black and just cleaned them really well and used the adhesion promoter. everything is fine with them
