pvc valve
Discussion in 'Technical Chat' started by midder, Jun 11, 2010.
  1. Jun 11, 2010 at 12:02 PM
    midder
    midder [OP] New Member
    2007 Tacoma
    Can somebody tell me where the pcv valve is located on a 2007 Tacoma 6cyl w/ac. Thanks
  2. Jun 13, 2010 at 8:19 AM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    i dont have a pic. butt if you are standing in front of the truck with the hood open.look on the drivers side right above the last coil toward the back at the top of the valve cover .you will see a hose coming from the intake to the valve cover.your positive crankcase ventilation valve is screwed into the valve cover and that hose is clamped onto it.when you remove the hose it will look like a nipple sticking out. unscrew it, screw the new one in. put the hose and clamp on and done!you may have to remove the engine cover. mine is off already so im not sure. if you need pics ill get you some
