Qantas Pilots
Discussion in 'Off-Topic Discussion' started by MotoXFreeStyle61, Aug 9, 2008.
  1. Aug 9, 2008 at 4:17 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 [OP] Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    After every flight, Qantas pilots fill out a form, called a "gripesheet " , which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
    Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas' pilots (marked with a P); and the solutions recorded (marked with an S) by maintenance engineers.: By the way, Qantas is the only major airline that has never had an accident.
    P: Left inside main tire almost needs replacement.
    S: Almost replaced left inside main tire.:
    P: Test flight OK, except auto-land very rough. :
    S: Auto-land not installed on this aircraft.:
    P: Something loose in cockpit. :
    S: Something tightened in cockpit.:
    P: Dead bugs on windshield. :
    S: Live bugs on back-order.:
    P: Autopilot in altitude-hold mode produces a 200 feet per minute descent. :
    S: Cannot reproduce problem on ground.:
    P: Evidence of leak on right main landing gear. :
    S: Evidence removed.:
    P: DME volume unbelievably loud. :
    S: DME volume set to more believable level.:
    P: Friction locks cause throttle levers to stick. :
    S: That's what they're for.:
    P: IFF inoperative. :
    S: IFF always inoperative in OFF mode.:
    P: Suspected crack in windshield. :
    S: Suspect you're right.:
    P: Number 3 engine missing some times. :
    S: Engine found on right wing after brief search.:
    P: Aircraft handles funny. :
    S: Aircraft warned to straighten up, fly right, and be serious.:
    P: Target radar hums. :
    S: Reprogrammed target radar with lyrics.:
    P: Mouse in cockpit. :
    S: Cat installed.:
    P: Noise coming from under instrument panel sounds like a midget pounding on
    something with a hammer.:
    S: Took hammer away from midget.
  2. Aug 9, 2008 at 4:25 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  3. Aug 9, 2008 at 4:59 PM
    MotoXFreeStyle61
    San Antonio TX
    I want waiting for someone to blow holes in that.
  4. Aug 9, 2008 at 7:40 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  5. Aug 9, 2008 at 7:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    An exploded oxygen canister caused that hole, I'd classify that as an accident. Death would be called a tragedy.
  6. Aug 9, 2008 at 8:01 PM
    MotoXFreeStyle61
    San Antonio TX
    Although I don't doubt that. Investigations take forever on these things. We probably won't see a written conclusive report for several months.
  7. Aug 9, 2008 at 8:07 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    concur :thumbsup:
  8. Aug 9, 2008 at 8:46 PM
    L8Rmike
    L8Rmike Well-Known Member
    Goose Creek, SC
    08 White DC LB 4x4 sport
    I use to see the same kind of discrepancy list for military A/C. I remember reading one from a C-130 report:
    1, 2 and 4 engines leaking oil.
    Signed off as, with in limits, #3 engine not leaking enough.
