Quality battery cable extension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Feb 22, 2019.
  1. Feb 23, 2019 at 3:53 AM
    cwdog
    cwdog Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Try any Interstate Battery location in the U.S.A..
  2. Feb 23, 2019 at 3:59 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Bolt it together and seal it up.
    Saeros likes this.
  3. Feb 23, 2019 at 4:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I say have new cables made the length you need .
    I have been making them for years
    A splice just adds another connection to cause problems since most people forget it is there .
    tirediron, shakerhood, EDDO and 2 others like this.
  4. Feb 23, 2019 at 8:06 AM
    cwdog
    Asheville, NC
    2017 Tacoma Limited
    And a splice is just another point of possible high resistance. Make the cable a home run like electictions do.
    tirediron likes this.
  5. Feb 23, 2019 at 8:31 AM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    You can get quality wire and lugs at most welding supply houses FWIW. If you decide to splice, be sure and use heat shrink on the splice.
  6. Feb 23, 2019 at 1:46 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    This is persuading me to start putting together a dual battery system instead of fooling around with this...
  7. Feb 24, 2019 at 10:04 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I think hes probably referring to taking the factory loom apart in order to get the factory cables out and then the new ones in. Yes its not complicated from an electrical point, but to do it right and have it look good like he said in the OP can take a lot of time. Especially if you're laying on the ground trying to get to everything rather than on a lift in a shop..
  8. Feb 24, 2019 at 10:09 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    What is causing you to have to add 5" to your cable?
    A dual battery setup is a good option if you are going to run a lot of accessories. But a dual battery setup is going to be A LOT more involved than just adding 5 inches to your battery cable.
  9. Feb 24, 2019 at 11:13 AM
    Rujack
    Ha, yes I know. I replaced my oe battery with a group 27M. The cables reach, but it’s messy to say the least.
    I’ve been wanting to add a second battery anyway so come family and I do get a ways out there. My accessories are minimal and I do t plan to add much, but want the assurance that a second battery offers. Currently just operating a fridge and ham and cb radios, but will be adding a little lighting and winch at some point, so now I’m thinking I’ll just go for it.
  10. Feb 24, 2019 at 11:17 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Don’t buy a crimping tool. Solder everything correctly and heat shrink wrap the terminal ends.
  11. Feb 24, 2019 at 11:18 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    With what you're running, a second battery wouldn't be a bad idea.
  12. Feb 24, 2019 at 11:22 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I can't disagree more with this.
    A quality crimping tool is a must doing a dual battery set up. Especially for someone who is not familiar with proper soldering.
    Crimped terminals and connections with quality crimpers and good marine grade (with glue) heat shrink is more than adequate to make good, solid, reliable connections.
    SR-71A, Wyoming09 and here4cake like this.
  13. Feb 24, 2019 at 11:25 AM
    JoeCOVA
    Joe
    Colorado Springs
    No one said that it wasn’t adequate.
    Crimping is a pain in the ass and significantly more work. Not only that but a soldered cable is simply stronger than a crimped one.
    It’s not hard to do either. Torch and rosin core solder, heat, melt, dunk, done.
  14. Feb 24, 2019 at 11:31 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    To each his own I guess. I think soldering is a pain in the ass and unreliable.
    here4cake and JoeCOVA[QUOTED] like this.
  15. Feb 24, 2019 at 11:32 AM
    #35
    JoeCOVA
    Joe
    Colorado Springs
    They both work fine, we just dislike eachothers methods! :)
  16. Feb 24, 2019 at 12:01 PM
    #36
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Weird thread. Advice is give and discounted numerous times and then the OP wants to go a totally different direction that is three times hard than what he wanted to originally do.
    Reminds me of people I have tried to help by trying to make them do the job but then you wind up getting suckered into doing it for them for which is probably their original intention.
    here4cake likes this.
  17. Feb 24, 2019 at 12:22 PM
    #37
    Rujack
    Useless post.
    “Omnipotent”
  18. Feb 24, 2019 at 12:40 PM
    #38
    here4cake
    here4cake Well-Known Member
    +1
    Solder will also crack and split in time. Proper crimps are more reliable.
    In certain applications, I crimp then get solder in there for best of both worlds.
    Dirtridercrf250 and Hootbro like this.
  19. Feb 24, 2019 at 12:48 PM
    #39
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    OMG...never use solder on battery cables.
    Get the *correct * size crimps and you're good.
    If you want to go anal (like me) you can use OFC cables.
  20. Feb 24, 2019 at 1:37 PM
    #40
    Wyoming09
    New Tripoli Pa
    Super Springs
    I will be glad to send you a piece of 2/0 welding cable with the lug please show me how you solder that on.
    I give you smaller wire under 8 AWG can be soldered anything above is crimped
    El Taco Diablo likes this.
