Quality battery cable extension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Feb 22, 2019.
  1. Feb 24, 2019 at 1:45 PM
    #41
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    stun gun likes this.
  2. Feb 24, 2019 at 1:51 PM
    #42
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I fill the cup with solder, dunk the cable in and crimp. Heat shrink over.
    shakerhood and JoeCOVA like this.
  3. Feb 24, 2019 at 1:57 PM
    #43
    JoeCOVA
    Joe
    Colorado Springs
    I wonder if they all think we are using an iron or something.
    stun gun[QUOTED] likes this.
  4. Feb 24, 2019 at 2:01 PM
    #44
    stun gun
    Aaronski
    Tacomas.
    I must live in the twilight zone. Crimps, no matter size, can wiggle free if you don’t address the cable twist, and even worse, harbor corrosion in the worst way. Solder is the lowest resistance and most corrosion free way to do it. Solder over crimp is the best way to go, especially in the salty states, and has never failed me in heavy industrial on highway applications. Definitely not using an iron lol.
    JoeCOVA[QUOTED] likes this.
  5. Feb 24, 2019 at 2:06 PM
    #45
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    ^ agree with that. Id be super nervous soldering stuff this big in the truck. I presume you'd need a big torch which is bound to melt or burn something else
  6. Feb 24, 2019 at 2:09 PM
    #46
    JoeCOVA
    Joe
    Colorado Springs
    Yup you need a torch (said in one of my first posts), I use a MAPP gas torch and you make your cables outside the truck then install. If you solder in the truck put a rag down to catch the overflow.
    shakerhood likes this.
  7. Feb 24, 2019 at 2:14 PM
    #47
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Put lug in vice. Get propane torch and heat lug. Fill 25% full with solder and then add wire. Continue to heat and add solder until it spills out.
    Honestly there is far too much stupidity going on in this thread. Solder vs. Crimp. I have large crimping tools and also do the solder method. Each has its place and this bullshit about which is stronger is laughable. To me the main advantage for solder is elimination of a corrosion point and a better connection electrically. Crimps when done correctly are pretty corrosion proof when I add shrink wrap over the connection but in high corrosion environments I will solder instead. If I worry about the lug pulling off of the wire I sometimes even crimp the soldered lug.
    I heard a comment last week that sums shit up. “The fucking internet has made everyone into an expert in knowing fuck all. If they actually knew something I would be out of a job.”
    Rujack[OP], shakerhood and JoeCOVA like this.
  8. Feb 24, 2019 at 2:16 PM
    #48
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Several years ago I was watching a YouTube video of a guy putting terminals on his jeep, torch right next to the battery, surprised it didn't explode.
  9. Feb 24, 2019 at 2:25 PM
    #49
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Nothing wrong with soldering, been doing industrial batteries for years this way. Nothing wrong with crimps either, just dunk the wire in solder then stick it in the crimp. A bit more resistance with crimp. I soldered a ring terminal to the extention I made, bolted it to the stock covered it up in Anchor heat shrink with built in glue.
  10. Feb 24, 2019 at 3:46 PM
    #50
    fullripbrian
    fullripbrian Well-Known Member
    Seattle sucks now.
    2017 SR Utility
