Quality TPS???
Discussion in 'Performance and Tuning' started by colo plainsman, Sep 13, 2013.
  1. Sep 13, 2013 at 5:02 PM
    colo plainsman
    colo plainsman [OP] Active Member
    Colorado
    01 double cab SR5 TRD 4wd
    So far I've gone through 3 within a year. Not sure if it's the quality of the part or some underlying issue. Any ideas or suggestions
  2. Sep 13, 2013 at 5:29 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    My suggestion is to offer more information, as that will help greatly to improve the quality of the responses you receive. ;)
    For example, a specific description of the symptoms of your failure, a picture of the failed part. With absolutely nothing to go on, it's easy for threads like this to become a mind reading guessing game of Charades.
  3. Sep 13, 2013 at 6:03 PM
    colo plainsman
    Colorado
    Good point. Thanks
    Well first failure was making it through a yellow light stepped on accelerator to make it through and check engine light came on. code was for the TPS sensor had it replaced with a TPS from advanced auto parts. The TPS lasted ten months. There was no change in the rpm's or idle.
    2nd) I was sitting at the drive through and the RPM's started dropping and would jump back up. Check engine light kicked on had that replaced. I was on the way to work so I had a garage take care of it not sure of the manufacture of the part. This TPS lasted 3 months.
    3rd) I was waiting again at a drive through looked down and check engine light was on again. There was no abnormality in the rpm's or idle. code read TPS again. had the garage replace it since it was under warranty. So I don't have a failed TPS since it was returned for another. this one has lasted a week and a half so far.
    I don't know if this is coincidence or not but it seems to be around the time I run BG-44K through a tank of gas.
  4. Sep 13, 2013 at 6:10 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I don't see how this would cause a TPS failure.
    It sounds like there might be something electrically wrong with your truck.
    But i have no idea.
    Sub'd for outcome.
  5. Sep 13, 2013 at 7:26 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Do you eat in your truck? Maybe your truck doesn't like when you eat in it. Especially fast food. Happened twice in a drive through? Seems fairly obvious to me, your trucks looking out for you.
  6. Sep 13, 2013 at 7:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    First mistake
    2nd mistake. They bought that part from Advance (or worse).
    Buy one from the dealer, or Camelback Toyota in Phoenix (best price).
  7. Sep 13, 2013 at 8:09 PM
    colo plainsman
    Colorado
    Yeah my first mistake was taking it to Firestone which was my only choice because it was a holiday and next door to work when the 1st one went out. They got the part from advanced auto parts. My blood pressure was about as high as my bill $328 when I pulled up how to change it on you tube.
    Yeah I should of got the sensor from dealership. But the sensor seems to crap out when I have to go to work go figure.
    Thanks for the advice on Camelback Toyota I'll have to check it out.
  8. Sep 13, 2013 at 8:12 PM
    colo plainsman
    Colorado
    You might have a very good point. I'll have to avoid them that might do the trick. LOL
