Question about 4LO & Diff Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eye one, Apr 14, 2008.
  1. Apr 14, 2008 at 10:33 AM
    eye one
    eye one [OP] Well-Known Member
    I put the truck in 4LO for the first time and heard a warning chime the entire time it was in 4LO. Thought that was strange (normal?) and then I went to activate the locker. The light blinked but it never engaged, tried from a stop first then crawled slow but the light just kept blinking while the 4LO indicator kept chiming. I read the light should be on steady when it's engaged but that never happened.
    What am I missing here? And yes I was on soft sand not pavement.
  2. Apr 14, 2008 at 10:54 AM
    eye one
    Forgot to add the vehicle was in neutral too, just never engaged.
  3. Apr 14, 2008 at 11:02 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    You got to be at a complete stop, and have the clutch pressed all the way to the floor. You have to go from 4 HI to 4 LO. You can't just go from 2 hi straight into 4LO. Try this, and after you get it working, come back to this post and give me a rep.
    --klown
  4. Apr 14, 2008 at 11:23 AM
    eye one
    -Was stopped
    -Auto Tranny (in nuetral)
    -Brakes applied
    It drove fine in 4HI, wanting to test the locker I put it in 4LO (sequence above) and just got a beep......... same beep if it weren't in Nuetral. Because in didn't get in 4LO the rear diff never engaged either.
    It seems like a sensor is faulty, the linkage is not right, or I am an idiot. (always possible) I have owned several 4X4 trucks/Jeeps and never had a problem with 4WD. Except the CJ7, had to rock that back and forth a little to get in and out of 4WD. This just confuses me.
  5. Apr 14, 2008 at 11:56 AM
    klown
    Lynchburg, VA
    Don't know what to tell you man, I didn't know you had an auto. Can you gimme a rep anyways since I tried to help you out?
  6. Apr 14, 2008 at 12:24 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    just so we're clear.... you drove it in 4hi. came to a complete stop, shifted to neutral, turned the knob to 4lo, put it back in drive and still got the chime?
  7. Apr 14, 2008 at 12:45 PM
    klown
    Lynchburg, VA
    If you did it in this sequence it shoulda worked like a charm, unless something is wrong.
  8. Apr 14, 2008 at 1:21 PM
    eye one
    Correct.
    I thought it was strange, hadn't used it before but the chime indicated something wasn't right. Put it in park, down to 2nd and tried all gears knowing it should be nuetral (only nuetral) to engage. Tried backing up (had to do that with the Jeep) and then back to nuetral but still nothing.
    I will try it again, later and see what's up. It's still under warranty. Once it's in LOW it should allow me to engage the rear diff right? I understand it takes a few (up to 5 secs) to lock............ that indicator would blink but not engage either I guess because 4LO didn't ingage.
  9. Apr 14, 2008 at 1:25 PM
    nd
    Nate
    Greenville, SC
    yeah, if you followed all those steps and it didnt work you may need to take a trip to the dealer.
    as far as the locker goes, i think you may have to already be in 4lo then shift into neutral again, hit the button, and shift back into drive while never leaving 4lo. i seem to remember that being how i got mine to lock but i could be wrong. i dont think you can engage the locker while engaging 4lo, i think its a seperate process. does anybody know?
  10. Apr 14, 2008 at 2:39 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    It shouldn't have any sequence. As long as the following conditions are met: 4LO, Locker button Depressed and under 5 mph.
    But I did the locker mod at 27 miles, so it's a bit foggy.
    I suspect the 4LO condition is affecting the locker, and the locker circuit is fine. Once you get the 4LO worked out, the locker will be fine. Thats what I get from the schematics anyway.
  11. Apr 14, 2008 at 2:42 PM
    nd
    Nate
    Greenville, SC
    i think he has to already be in 4lo for the locker to engage, which means he will have to put it in 4lo, then roll a few feet to get it engaged, then go back and put it in neutral again to engage the locker. does that make sense or am i way off?
  12. Apr 14, 2008 at 3:42 PM
    no_werries
    no_werries Well-Known Member
    Simcoe County, Ontario, Canada
    2005 4x4 reg cab Indigo Ink 5 speed
    CAI, 2 1/2" rear lift AAL, Ready Lift strut ext. & diff drop = 2 1/2" front lift, tweaked clutch, Magnaflo Muffler & Custom exhaust 265/75/16lt Nitto Terra Grappler 8ply on stock rims. Huskyliners
    Umm, not related to the locker, but the 4 lo, if its chimeing when you swithc to 4 lo it means that 4lo hasnt engaged, tryin puttin it in 4lo and driving forward, or reverse untill chiming stops, that means your in 4lo, then if u still can't engage locker I dont know what to tell ye, but I would start by getting it engaged in 4lo so that its not chiming!
  13. Apr 14, 2008 at 3:44 PM
    eye one
    4Lo didn't engage, hence the locker didn't engage.
    It's going in for the rear leaf TSB tommorow AM, I'll have them look at this too.
  14. Apr 14, 2008 at 4:00 PM
    no_werries
    ye ok thats what I was getting at, didnt know if u had firgured that being the problem, sux that you cant get 4lo to engage, buts its nice toyota has a chime, I had a 2004 f150 which wasnt engaging in 4lo and mine didnt chime, its just let me spin w/e up inside the transfer case, dont know exactly what happened but waranty covered it!
  15. Apr 14, 2008 at 4:10 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Have you been in 4 lo before this attempt?
    It seems like the actuator or whatever needs to break in just like the rest of the truck.
    I seem to remeber it taking mine a good long while to engage the first time, hard to remember was 6000 miles and a year ago.
    But a buddy just bought an 08 regular cab 4x4, and when he brought it by for a lesson on how the 4wd operate (his first 4x4) it took nearly three laps around the field to get 4lo to engage and dis-engage, but it wouked like a charm after that.
    Rock is back and forth a bit, then go back to neutral and try again.
    Yes, as already has been stated the locker will not engage unless 4 lo is engaged, so if you had not gotten 4lo to engage, then the locker would not engage either (in stock un-modded form that is)
    BTW, Toyota, your consumers seem to want the manual transfer case lever back!!!
  16. Apr 14, 2008 at 4:35 PM
    CrashTest
    CrashTest Member
    2008 Access Cab V6 MT TRD Offroad
    Bring Back The Shift Lever!!!!!!!
  17. Apr 14, 2008 at 8:04 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    ding ding ding.....the FJ has it, why not the Taco!!
    Another problem with the truck, the actuators seem to 'stick' if not used. I had similar problems with 4lo as well as with the locker. I have since done the locker mod and try to engage the locker at least once a month just to keep things moving.
    Next time you try to shift to 4lo, be sure to either open the door, or roll the window down, you will hear a noticeable click/engage sound when the transfer case shifts, same for the locker engaging. Sometimes you have to rock the truck back and forth for it to actually engage. Definitely be sure to bring it up with the dealer when you take it in....just don't mention the locker-mod to them :D
  18. Apr 15, 2008 at 6:37 AM
    eye one
    Well I tried it again, drove around some more and after a few minutes it finally locked in, shall I saw I was able to engage LO. The rear diff locker also worked. I bought it used, 8800 miles and doubt this feature was ever used before.
    Thanks for the advice of driving around, and yeah definitely strange. This is my 4th 4X4 and 1st without a lever. I miss the CJ7, it had to be man-handled in and out of gear while rocking the drivetrain back and forth.
