Question about billy 5100s and rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rosebud, Sep 19, 2009.
  1. Sep 19, 2009 at 6:04 PM
    rosebud
    rosebud [OP] Love that transmission!
    SE Texas
    2017 TRD OR
    Stock suspension, stock wheels, stock bumper, stock, stock, stock, dammit!
    These might be dumb questions, but yall know me. When I wanna know . . . :laugh:
    If I put billy 5100s on my truck, will it ride differently? I read that they are made for both on road and off.
    If I put 5100s on my truck, will it be lifted? If so, what sized rims can I go with if I put them on or will 5100s make a difference in how big I can go with rims?
    Rims -- My rims are stock 15s I think. If I want to go with plus size without doing any lifts, how big can I go? 16?
  2. Sep 19, 2009 at 6:15 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'm guessing you have a 6 lug Tacoma?
  3. Sep 19, 2009 at 6:19 PM
    rosebud
    SE Texas
    2017 TRD OR
    Well ? LOL! I will go look after dinner.
  4. Sep 19, 2009 at 6:20 PM
    Incognito
    VA
    Ok. :)
    If it's a 6 lug, it should have 6 lug nuts on the wheels.
  5. Sep 19, 2009 at 6:32 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    you would need new coils and leafs if u are not running a prerunner. rims are not an issue if you are gonna get 5100s its tires..... unless if you are getting G-Unit rims
  6. Sep 19, 2009 at 6:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im pretty sure they make 5100's for both the 5 lug mini's and the 6 luggers. they are a great shock........and depending on the setting you decide on...yes,they can lift the truck, but you can set the fronts on the stock setting also.
  7. Sep 19, 2009 at 6:43 PM
    rosebud
    SE Texas
    2017 TRD OR
    They do make them for both because I checked. :D
    BUT, my truck is a tacito, 5 lug. Do 5100s make sense on my truck? What would be the advantage to getting them on my 2wd stock truck?
    I want to go with bigger tires after I pay the truck off, probably as early as spring, and possibly want new rims, but I can't put a lift on it, and probably wouldn't anyway. So any recommendations on rim size and tire size?
  8. Sep 19, 2009 at 7:34 PM
    Chazmanian
    Chazmanian Well-Known Member
    Colorado
    Stocker
    Whats the stock tire size on a 2wd Taco?
    The 4x4 6 lug trucks dont like big tires without some big money to go with the deal to lift it correctly!
    Dunno bout your "Tacito" tho....
  9. Sep 19, 2009 at 7:50 PM
    rosebud
    SE Texas
    2017 TRD OR
    According to the tool, they are 215/70/15? I don't want to put huge rims and tires on, but can I go any bigger without having to make adjustments?
  10. Sep 19, 2009 at 7:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may be able to run a set of 16 inch wheels. im not totally sure about the back spacing and other specs of the 15 inch rim....but maybe check out some camry wheels....you may be able to fit them with no problems.
  11. Sep 19, 2009 at 8:30 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    You can install 235-75-R15 on your taco. I have them on my 5 lug. Any bigger and you will need to remove a plate bolted on the front wheel wells. With a lift you can run 31" tires without issues. Good luck!
    Even with the 235 tires (just a little bigger stock) I notice a power difference, much bigger than that and changing gears would be a good idea.
  12. Sep 19, 2009 at 8:34 PM
    lawnrevenge
    Southern California
    Ignore the nasty parking lot damage, but this photo is of my tires.[​IMG][​IMG]
  13. Sep 19, 2009 at 8:40 PM
    rosebud
    SE Texas
    2017 TRD OR
    Thanks! So I should really save the rim mod for the next truck unless I go with 15"?
  14. Sep 19, 2009 at 8:46 PM
    lawnrevenge
    Southern California
    You can get bigger rims, just smaller tires. Do you drive offroad or just on the street? IF your on the street you can put 16", or 17" without problems. Just make sure the offset is right. I don't know the numbers off the top of my head but a good rim shop will knif what will fit. You'd just get lower profile tires.
  15. Sep 19, 2009 at 8:51 PM
    rosebud
    SE Texas
    2017 TRD OR
    I mostly drive on the street, but I never have let the end of the concrete stop me if I wanted or needed to go somewhere. :p
    Well, I still have time. I will keep looking. So bigger rims but less beefy tires, and same sized rims but beefier tires, right?
  16. Sep 19, 2009 at 9:48 PM
    lawnrevenge
    Southern California
    You could go with 16" rims and beefier tires, just don't let the overall diameter exceed 29" or you'll need to remove the boxes I talked about before. There is a thread on it somewhere.
  17. Sep 19, 2009 at 9:53 PM
    rosebud
    SE Texas
    2017 TRD OR
    Thanks! I'll be sure to get with some pros when I get ready to buy, but it is good to know at least something about what I need and can get by with. I will definitely keep it under 29 total, and store my stock rims if I get new ones. ;)
