Question about Bright spots from HIDs
Discussion in 'Lighting' started by sagebum, Feb 10, 2010.
  1. Feb 10, 2010 at 8:11 PM
    sagebum
    sagebum [OP] Well-Known Member
    James
    Elk Grove (NorCal)
    07 DC 4x4 TRD OR white
    I installed DDM Tuning 35W Slim ballast HIDs and I'm still working on the aiming of them. I was wondering if these bright spots are normal.
    [​IMG] [​IMG] [​IMG]
  2. Feb 10, 2010 at 8:13 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    The HIDs in my tacoma do the same thing
    It's less noticeable on my BMW, but the oem 4300ks in it do the same. the Infiniti projectors are the cleanest, but even they have "bright spots"
  3. Feb 10, 2010 at 8:14 PM
    sagebum
    James
    Elk Grove (NorCal)
    Ohh, great, Thanks for the quick reply, much appreciated!
  4. Feb 10, 2010 at 8:14 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    If they arent in projector housings, yes thats normal.
  5. Feb 10, 2010 at 8:16 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Projectors have the same issue. Just much less noticeable.
  6. Feb 10, 2010 at 8:17 PM
    sagebum
    James
    Elk Grove (NorCal)
    Oh, yeah mine are still in the stock housings.
    Yeah I don't think I've ever noticed a bright spot while riding in other cars with projectors.
  7. Feb 10, 2010 at 8:19 PM
    dually
    dually Low and slow
    A LOT less.. thats what the projector cutoff is for...
  8. Feb 10, 2010 at 8:37 PM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    08 Tacoma TRD Dbl Cab 4x4 MT
    My jacked up HID's I had to modify my cutoff a little by putting some reflective tape (metal tape) on the HID "cutoff" to make it glare less. It worked out pretty nicely for a cheap quick fix.
  9. Feb 11, 2010 at 6:34 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ummm...no.:rolleyes:
  10. Feb 11, 2010 at 6:42 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Ummm yes.
  11. Feb 11, 2010 at 6:48 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    HID projectors have a uniform bowl, no sharp edges. who can this type of reflector produce the hot spots and terrible glare seen in the pics?! please, im dying to know...
  12. Feb 11, 2010 at 6:49 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Pics or it didn't happen. I would think if there are bright spots from a projector then there is something afoul with the lens.
  13. Feb 11, 2010 at 6:52 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Correct, there is uniform bowl. But there is still a bulb, a main emission of light... therefore there is no perfect dispersion of lumens. I tested this shit back in grad school. BLOWS MAH MIND!
  14. Feb 11, 2010 at 6:52 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Sigh.
  15. Feb 11, 2010 at 7:02 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    of course there is no perfect dispersion, but the crappy output pictured is no where near the non perfect dispersion in a HID projector.
  16. Feb 11, 2010 at 7:05 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Agreed. I never stated that HID was similar. I just said it still has the same issue, just alot less. Remeber ;)
    You and are on the same page. Haha. :p
