Question about Dakar leaf springs
Discussion in 'Suspension' started by taco_man, Nov 3, 2010.
  1. Nov 3, 2010 at 7:09 AM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    I just got them in last night and they only have bushings on one side. My first question is do I need to buy another set of bushings for the other end of the leaf? And which side is the front of the leaf springs?
  2. Nov 3, 2010 at 7:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you get them from Wheelers? What's the part number?
  3. Nov 3, 2010 at 7:36 AM
    taco_man
    Austin
    Houston
    09 texas edition
    SKU:* APO-4505T-OME-CS047R
    I bought it from poly performance
  4. Nov 3, 2010 at 7:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ok. Wheelers says you need this bushing set. Maybe Poly Performance didn't tell you?
  5. Nov 3, 2010 at 8:26 AM
    taco_man
    Austin
    Houston
    09 texas edition
    Just bought the bushings. Any idea which side is which on the springs? I don't want to be installing these things backwards
  6. Nov 3, 2010 at 8:32 AM
    98tacoma27
    Ben
    Not Beech Creek
  7. Nov 3, 2010 at 8:36 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    The end without the bushing go towards the front.
  8. Nov 3, 2010 at 8:36 AM
    taco_man
    Austin
    Houston
    09 texas edition
    Thanks for the help
  9. Nov 3, 2010 at 8:39 AM
    JDMcQ
    I just used that to pull it back into place, I was by myself, but it likely would have helped on yours as well.
  10. Nov 3, 2010 at 9:32 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That could read ambiguous.
    That is, the end into which you MUST MANUALLY INSERT the bushings goes to the BACK.
    Also, don't forget to lube the bushings before putting them in. If they didn't send you a pack of lube, you can use vaseline. Don't use the axle grease you'd use for lubing your chasis/shooting into your zerks, that'll deteriorate the rubber.
  11. Nov 3, 2010 at 9:35 AM
    JDMcQ
    You are correct. However, if you have Urethane bushings the chassis grease will be fine.
  12. Nov 3, 2010 at 11:02 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The end of the spring that has a factory style bushing already pressed into it goes toward the front of the vehicle.
