Question about differential fluid change.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatherof2, Sep 3, 2015.
  1. Sep 3, 2015 at 5:43 AM
    Fatherof2
    Fatherof2 [OP] Well-Known Member
    Massachusetts
    2004 DC TRD
    Hi Gang,
    I changed the fluid in my front and rear differential. I also did the transfer case at the same time.
    I used different fluid for the TC.
    I used the same hand pump for all 3. (i.e. I mixed a little bit of fluid I'm sure.)
    Is that OK?
    Thank you!
  2. Sep 3, 2015 at 9:35 AM
    NM Lance
    NM Lance Well-Known Member
    It won't hurt anything.
  3. Sep 3, 2015 at 9:36 AM
    Large
    Large Red
    you will be fine
  4. Sep 3, 2015 at 1:00 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Great!
    Thank you!!
  5. Sep 3, 2015 at 6:50 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    I was under the impression diffs and transfer case accept 75W-80? Am i wrong? Did u switch it up for a purpose?
  6. Sep 3, 2015 at 10:41 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    All you need is GL5 rated gear oil, it will say it's spec on the back of the bottle. You shouldn't have to use different gear oils, except in automatic transmissions.
  7. Sep 4, 2015 at 4:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What does your owners manual tell you??
    I don't know if they changed anything since, but my 2007 requires 75w-90.
  8. Sep 4, 2015 at 11:11 AM
    beavis87
    El Paso
    '10 Silver TRD OR
  9. Sep 18, 2015 at 8:43 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
