Question about lift kits
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hondarider77f, Feb 8, 2012.
  1. Feb 8, 2012 at 9:55 AM
    Hondarider77f
    Hondarider77f [OP] New Member
    Evan
    Richmond, VA
    97 Tacome 4x4
    So, Im getting my dads truck soon, and its a 1997 tacoma, i want to lift it a little with some 31.5 bfg allterains, i think 3" sounds good, and i found two different lift kits, and I dont understand the difference between them other than the price;)
    Could someone explain the difference between these two? any reccomendations?
    http://www.autoanything.com/suspension-systems/75A5964A0A0.aspx
    Thanks
  2. Feb 8, 2012 at 11:18 AM
    adt0423
    adt0423 Well-Known Member
    Alex
    Harrisonburg, VA
    1997 Tacoma 4x4 ext cab. 2021 TRD Off Road AG DCSB
    1997 - 2 in level kit, 31" tires, aluminum tool box.
  3. Feb 8, 2012 at 11:48 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I'm not going to be a dick and yell 'searchbar' at you, but there's heaps and heaps of information on the 1st gen forum about different lifts. Common themes, though, are:
    -NO block/spacer lifts
    -NO body lifts
    -Eibach/Bilstein5100s (as said above)
    -Old Man Emu (ARB's suspension)
    -King/Icon/SAW coilovers (pricey)
    Rear stuff:
    -Add-a-leaf (AAL)
    -New lift springs (OME Dakar/Wheeler 5pk/etc)
    -Lift shackles
    But take a long look around this forum for more information and watch out...you might catch the 'mod bug' pretty badly from us!
  4. Feb 8, 2012 at 12:04 PM
    JoshM
    JoshM Active Member
    Franklin, TN
    1998 RCSB 4x4
  5. Feb 8, 2012 at 1:25 PM
    adt0423
    Alex
    Harrisonburg, VA
    That's a real understatement. You'll search here, find the lift you want, and be hooked. haha game over.[​IMG]
  6. Feb 8, 2012 at 2:28 PM
    Hondarider77f
    Evan
    Richmond, VA
    97 Tacome 4x4
    okay, okay, hold on a second, I wanted a body lift most likely, is there a reason why I should pay more to get a suspension lift, all Im gonna do is use it as a daily driver and occasionally go through a little mud (and I mean little).
  7. Feb 8, 2012 at 2:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    3" body lifts can make your truck dangerous to drive, and be a damage multiplier should you get into an accident.
  8. Feb 8, 2012 at 2:53 PM
    adt0423
    Alex
    Harrisonburg, VA
    they also wear down parts on your truck faster than if it was stock or had a suspencion lift. they are cheap yes but they will cost you more money in the long run. like STLharry said no block/spacer lifts no body lifts.
  9. Feb 8, 2012 at 3:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :laughing:
    bad idea man.
    BLs are cheap for a reason. They take away from the trucks stability and safety and reliability. Suspension lifts are the best way to go as you are upgrading the actually amount of travel your truck can flex. BL don't do anything but cause problems later down the road.
    Im running the Eibach/5100 combo up front.
    Do some looking around and searching. You'll get an idea.
  10. Feb 8, 2012 at 5:21 PM
    Hondarider77f
    Evan
    Richmond, VA
    97 Tacome 4x4
    thanks guys, i think Ill hold off on a lift for now, but when i put some new tires on it, Ill put up some pics, and IF i lift it, ill definitely put some pics up....its lavendar steel (OOOOHHH)(i always made fun of my dad for that, now its gonna be mine :/)
  11. Feb 8, 2012 at 9:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Whats wrong with that color?
  12. Feb 9, 2012 at 5:48 AM
    Hondarider77f
    Evan
    Richmond, VA
    97 Tacome 4x4
    Nothing, my dad just got made fun of (because he works at a toyota dealership) for it being "perrywinkle blue"....i didnt come up with it, but I thought it was funny
