Question about slip yoke
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoRich352, Nov 20, 2017.
  1. Nov 21, 2017 at 12:14 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Some single cabs did in fact come with a one piece shaft sporting a DC joint and no support bearing as pictured. I don't know the years/trim packages that apply. The conventional 2 joint shafts were far more common.
    That being said, something is funny with the joint in the pics. I see an "OE" Koyo inside clip style on one end and an outside clip on the other (of the DC). I don't know/can't tell if this is a result of the inexperienced "mechanic" or what. An 01 most likely should be the outside clip style (both). There is only one known replacement for them (on extra and d-cabs). I am not positive that the single cab DC takes the same one as the ex-cabs.
    Random points,
    The Koyo joint in the pics is not the same number as an OE ex-cab inside clip style.
    Inside and outside style joints are not interchangeable.
    The likely way the OP's situation will be resolved is thru a driveline shop experienced with Toyota shafts.
    Parts houses frequently list the incorrect joints for the Taco DC.
    There are a few joints out there that are within a few thou of the correct size but still incorrect. This may be what the OP is seeing.
    Precision measurements of the original parts may be required for someone not familiar with the issue. These dimensions can be referenced in several manufacturer's catalogs. Dana/Spicer and Neapco are good as is Rockford Driveline. The latter being tho only known manufacturer of the outside clip style mentioned above.
    See here https://www.tacomaworld.com/threads/double-cardan-joint.273119/#post-6745013
    drr and cruiserguy like this.
  2. Nov 21, 2017 at 12:51 PM
    tacoma_2002
    tacoma_2002 Where We're Going We Don't Need Roads...
    Andrew
    Cotton Plant, Mississippi
    '02 Tacoma 4x4 TRD
    Correct.
    Some single cabs came with the double cardan joint as shown. Sounds to me like the front half of the shaft (cardan joint end) is fine. I'll bet he dropped some needle bearings out of one of the caps on the rear.
  3. Nov 21, 2017 at 3:17 PM
    TacoRich352
    TacoRich352 [OP] Active Member
    Christopher
    '01 Tacoma sr5
    3" suspension lift on 265/75's
    So the cardan joint is fine but after two new u-joints in the rear there is still play in the joint. I have to leave it overnight yet again. Should i tell him to just take it to a speciality shop to do it.
  4. Nov 21, 2017 at 3:52 PM
    tacoma_2002
    Andrew
    '02 Tacoma 4x4 TRD
    Where is the slack? Is it in the cap to yoke mating surface or in the joint itself?
  5. Nov 21, 2017 at 3:55 PM
    TacoRich352
    Christopher
    '01 Tacoma sr5
    In the u-joint itself
  6. Nov 21, 2017 at 4:06 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yes.
    Who is this guy you have working on it? A pro mechanic, or a friend who said he knows how to wrench?
    Have you considered getting one from a wrecking yard?
    wilcam47 likes this.
  7. Nov 21, 2017 at 4:09 PM
    TacoRich352
    Christopher
    '01 Tacoma sr5
    It's at a shop i have used for years and i trusted the guy wholeheartedly but i feel like this past year he is started to slip. I most likely will not be using him ever again. I'm going to suggest taking it to a specialist or getting another ds to him in the morning.
  8. Nov 21, 2017 at 4:34 PM
    jbrandt
    Justin
    You hate loosing a trusted mechanic. Maybe just drivelines aren't his bag?
    Although those previous pics you posted (the filthy floor) make me wonder if you're not making a good decision by going elsewhere.
  9. Nov 21, 2017 at 4:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    A good mechanic would be doing this on a workbench. Not even I would do it on the floor in oil lol
  10. Nov 21, 2017 at 5:36 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I dont see how you can get slack in NEW u-joints unless the needle bearings fell out when he was putting them in...
    tacoma_2002 likes this.
  11. Nov 21, 2017 at 7:42 PM
    tacoma_2002
    Andrew
    '02 Tacoma 4x4 TRD
    This or the joint isn’t wide enough cap-cap.
  12. Nov 22, 2017 at 7:47 AM
    TacoRich352
    Christopher
    '01 Tacoma sr5
    So im trying to go through toyota to make sure iget the correct size u-joints. On the phone with them i gave them the vin # and they said that all three they have are the same. I don't see how that's right and they are $60 each, i don't want to spend $180 on the wrong $#!+.
  13. Nov 22, 2017 at 8:39 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I'd call and quiz a local driveline shop.
  14. Nov 22, 2017 at 8:40 AM
    anthony250f
    Anthony
    San Diego, CA
    Yup....driveline shop would have gotten it done the first time
