Question about squeaking in front end
Discussion in '1st Gen. Tacomas (1995-2004)' started by josh.., Oct 28, 2009.
  1. Oct 28, 2009 at 6:22 PM
    josh..
    josh.. [OP] Well-Known Member
    Sarasota, Florida
    '02 SR5 V6 4x4 Double Cab
    K&N drop-in air filter, body lift.
    This is my first truck, so I'm not completely fluent in all of the different parts and everything yet, but I'm having a weird squeak coming from the front end. That's where it seems to be coming from at least. Only happens when I'm driving over uneven pavement, cracks in the road, or small speed bumps. Anything big and it doesn't seem to do it really. I'm not sure where to look or what to check, but any advice would be very helpful.
  2. Nov 18, 2013 at 9:25 AM
    BrandonDean
    BrandonDean Member
    I may have found the issue to the front end squeaking. (time will tell) When the hood is open and you bounce the truck you cant hear a thing the second i closed the hood the noise came right back. Couldn't find where anything was scratching until we looked at the hood latch. Paint was being scrapped off the bottom of the hook so my guess is that is was metal to metal noise from the front. After adding some lube i have not heard it in now 24hrs. Im sure when it dries again it will come right back so ill need to figure out a way to adjust it or see if toyota knows how to adjust the latch. Ill be back if it ends up not being the solution.
  3. Nov 18, 2013 at 12:33 PM
    low boy
    low boy 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    hmmm, if it is the latch cool, you found it. but if not try spraying some WD40 on the shocks housing at the top really well. i had something similar and that fixed mine, and just rinse and repeat as needed. hope this helps.
  4. Nov 18, 2013 at 2:01 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    wow. Dusting off a four year old post. crazy!
