Question about throwing in greasable bolts on Dakar leaf pack.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodsman117, Feb 27, 2019.
  1. Feb 27, 2019 at 12:18 AM
    woodsman117
    woodsman117 [OP] Well-Known Member
    2015 Barcelona Red TRD OR
    OME HD lift, HD Dakars, Duratraks, RCI IFS Skid
    Hey Team,
    Quick question. And tell me if I'm just being dumb here. Curious if it is at all possible to swap out forward and rear leaf spring bolts with grease-able bolts without entirely removing the leaf pack. I.E. leaving the U-bolts in place? Anyone done it?
    Cheers
    Norton likes this.
  2. Feb 27, 2019 at 5:35 AM
    96carboard
    96carboard Well-Known Member
    Grease won't do anything, except maybe keep the bolt from rusting.
    The leaf spring bushings don't pivot on the bolt. The metal tube through the bushing is locked to the truck's frame, the movement of the leaf is permitted by twisting the rubber. Lubricating it won't accomplish anything.
    OmahTako and pleetrd like this.
  3. Feb 27, 2019 at 8:18 PM
    woodsman117
    From the other threads I've read my understanding is the greasable bolts will allow the grease to make it's way out to in between the bushings and the frame mounts. Which is where alot of the noise comes from along with the leaf shims being dirty, which I plan on cleaning as well. Right now my temporary fix is silicone grease which works well for a time. My main question is if it is at all possible to swap the bolts without taking the u bolts off, thereby removing the leaf packs from the axle.
    lynyrd3 likes this.
  4. Feb 27, 2019 at 8:24 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Yeah you can swap the bolts out, I've done it on my truck with the leafs still on. You'll need to work the leafs back into position to line the bolts back up with the front/rear hangars and shackles.
    llamasmurf, la0d0g and Norton like this.
  5. Feb 27, 2019 at 8:31 PM
    woodsman117
    Word. Was it enough of a PITA to just warrant taking the packs off entirely? I've got HD Dakars so they're not the easiest things to manipulate.
  6. Feb 27, 2019 at 8:38 PM
    eon_blue
    Azusa, CA
    I think it's a lot easier than taking off the leafs, though even when you take off the leafs you still have to fight with them a bit to line them up...helps to have a sturdy pry bar on hand to help pry them into place.
    cruxofthebisquit likes this.
  7. Feb 27, 2019 at 8:39 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Sounds like it could become a pain in the ass that’s not worth attempting just to keep from removing 5 other bolts.
  8. Feb 27, 2019 at 8:40 PM
    eon_blue
    Azusa, CA
    I just did one bolt at a time which helped I think.
  9. Feb 27, 2019 at 9:02 PM
    woodsman117
    I think that's what I'll try and do and if it's not working I'll pull the u bolts off. Thanks for the beta. Damn Dakar's are painful to listen to haha. Second thing any of you gents have any other solutions/experience with fixing this squeak? Was gonna swap out the bushings/bolts with the Dobinson's bushings and greasable bolts then I was going to pry the leafs apart and clean/grease the spacers.
    lynyrd3 likes this.
  10. Feb 27, 2019 at 9:21 PM
    eon_blue
    Azusa, CA
    My fix for the Dakar squeak on my 1st gen was to swap them out for All Pro Expos lol.
  11. Feb 27, 2019 at 9:22 PM
    eon_blue
    Azusa, CA
    Greasable bolts will help if the squeaking is coming from the bushings , but Dakars are also known to squeak from the leafs themselves (any leaf pack is prone to that really). I've heard some have had good luck putting rubber liners between the leafs to eliminate the squeaking
    Norton likes this.
  12. Feb 27, 2019 at 9:41 PM
    woodsman117
    Yeah I've looked into that as well. Most of the squeaking seems to resolve when I hit the front bolts/bushings with lube so I'm hoping swapping the bolts with something that I can regularly grease fixes (most of) the problem.
  13. Feb 27, 2019 at 10:06 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    Turn up the radio
    QuicksandTaco and Norton like this.
  14. Feb 27, 2019 at 10:26 PM
    woodsman117
    Already got that approach covered :frusty:
  15. Feb 27, 2019 at 10:53 PM
    woodsman117
    Thanks again for the suggestions!
  16. Feb 28, 2019 at 5:43 AM
    badger
    badger Well-Known Member
    07 SR5
    My Allpros have teflon liners between the leafs. Even so, occasionally I just soak the whole mess in a penetrating preservative oil. I know the factory scheme for mounting leaf springs is to tighten the bolts and bind the rubber, but I quit doing that 30 years ago. I use nylock nuts on my leaf bolts and allow just enough play for the thing to operate as a loose pin. If you have longer than factory suspension travel, this allows the springs to move much better. In 30 years of hard wheeling, some of that on vehicles weighing over 9,000 lbs, I've never seen any downside.
  17. Feb 28, 2019 at 5:50 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    OP, which greaseable bolts are you looking at?
    I've done it and you absolutely have to remove the leaf packs to burn the bushings out and replace them (again depending on the kit used).
    angeldavid216 likes this.
  18. Feb 28, 2019 at 5:52 AM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    This seems like a winner for me, I'll be switching mine out tomorrow.
    https://www.tacomaworld.com/threads/change-the-front-bushings-in-your-dakars.479071/
    GHOST SHIP, Norton, ETXTacoma and 2 others like this.
  19. Feb 28, 2019 at 7:07 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, 16" TRD baja wheels, 265/75r16 BFG K02, 1.25" wheel spacers, TRD skid plate, N-Fab spare tire box mount.
    Like another user already said, the squeak comes from the leafs themselves moving slightly when flexing. Lubing the bolts and bushings does nothing, trust me lol.
    Jack up the truck one side at a time allowing the wheels to droop. This will separate the leafs enough to give them a shot of fluid film in between each leaf. Do this about every 4-6 months as needed and you shouldn't have a problem.
    lynyrd3 and spitdog like this.
  20. Feb 28, 2019 at 7:34 AM
    geekhouse23
    Interestingly, the leafs don't squeak for me. The bushing sleeve was rubbing on the front leaf spring mount and now they're quiet once I swapped the bushings
    lynyrd3 likes this.
