question about tires and alignment
Discussion in 'Wheels & Tires' started by paidfor, Jan 27, 2010.
  1. Jan 27, 2010 at 10:12 AM
    paidfor
    paidfor [OP] Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I am lifting my truck 1.6 in in the front this weekend. I will be driving about 100 miles back to my home town after the lift.
    I have tires on there now that only have 10k miles on them. I will not be able to get an alignment till I get back to my home town. I know it would be better to get an alignment real quick with few miles.
    What can I expect with the tire wear driving 100 miles? It is going to destroy the tires doing this?
  2. Jan 27, 2010 at 10:16 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    Unless you really jack up your alignment while installing your lift which i don't think you will being that you aren't going that high, you'll be fine. Just take a look at your tires from the front after you install your lift and just make sure they aren't too far in or out. you should be fine, but of course sooner is always better.
  3. Jan 27, 2010 at 10:16 AM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    you should be fine. I did the Bilstein 1.75" lift up front and drove around for a while before getting it aligned. Unless you look at your tires up front and they look something like this \ /
    then def. get it aligned before heading out, but you should be fine.
  4. Jan 27, 2010 at 10:17 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I probably had about 100 miles on mine before I aligned it, granted it was in town driving. It certainly isn't recommended but it didn't hurt anything on mine nor was there any visible wear on the tires.
  5. Jan 27, 2010 at 11:23 AM
    paidfor
    Austin, TX
    2013 TRD OR 4x4
    thanks for all of the quick responses.
    I feel better now about driving it home without an alignment. I will sure check it out before I start the drive home though.
    thanks again.
