Question about wheel offset
Discussion in 'Wheels & Tires' started by TacM31, Mar 14, 2010.
  1. Mar 14, 2010 at 11:58 AM
    TacM31
    TacM31 [OP] Well-Known Member
    Tyler
    Houston, Texas
    '05 PreRunner Lifted
    6" Pro Comp Lift, aFe Magnum Force Intake, ATS Running Boards, Viper Alarm and Remote Start, RBP Grille, Custom Leather Seats, Flowmaster Super 44, Halo Projector Headlights, HIDs, Debadged, Aries Bull Bar, Bumper Plugs, 21" Stubby Antenna, Fog Lights Anytime Mod, Blacked Out Tacoma Badges
    I'm kinda new to the forum but I've been searching and reading topics about offset for quite awhile and I'm not sure I fully understand it.. I have an '05 Tacoma with a 6" Procomp lift and I'm looking to put some 20x9 wheels and 35x12.50 tires on it the problem is I've found two wheels I like and I've looked up the bolt patterns and they both fit in that regard but the both wheels came in a couple different offsets and I don't know what one to get or if they will even work on my truck..
    Basically the wheels I want come in the following offsets: 0, 12, 14, 30
    I assume all besides 0 are positive offsets and from what I've read I don't want those but then again I don't really know.
    Will the 0mm offset work on my truck? And will they be the best option? And last question will the fact that it's not a negative offset effect how far they stick out from the fenders? Or will the tire still stick out just from it being so wide?
    Thank you! Sorry if I asked too many questions haha.
  2. Mar 15, 2010 at 7:39 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    About halfway down this page is a chart that converts offset to backspacing.
    Most aftermarket wheels are around 4.5" backspacing. 285's (which are over and inch skinnier than what you are considering running) will still rub slightly on a 4.5 BS rim.
  3. Mar 15, 2010 at 7:44 PM
    rmerchant3
    rmerchant3 Insert nonsense here
    ^^^ Good info!
  4. Mar 15, 2010 at 7:52 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    Hopefully this pic shows up!
    From the looks of your pics it seems your wheels now may be a positive or 0 offset. Its hard to say but If you want your wheels to stick out a little further you would want a negative offset. And with a 6 inch lift I would think you want your wheels to stick out! Your wheels should be stamped on the back and it will tell you what you have on yours now.
  5. Mar 16, 2010 at 10:57 AM
    TacM31
    Tyler
    Houston, Texas
    okay thanks that helped. right after i posted this i found one of my wheels is made in a -12mm offset. and i was looking further at the charts on the companies website and it said with a lift 0 would still work with little rubbing. most likely im going to go with the -12mm offset. thats what discount tire recommended.
  6. Mar 16, 2010 at 1:00 PM
    ROCKSLINGER
    Robert
    Reno Nv
    yeah google your wheels and find the cheapest price and they will price match! thats what I did and got $100 off my wheels!
