Question about wheel size???????
Discussion in '1st Gen. Tacomas (1995-2004)' started by dicarlo12181, Aug 3, 2010.
  1. Aug 3, 2010 at 5:38 PM
    dicarlo12181
    dicarlo12181 [OP] New Member
    Hi guys, I have a 2002 4-door prerunner and I just called 4wheelparts to order rims that I had been wanting for quite some time. I just called them and the sales rep told me that the rim won't fit on my truck. This is it
    http://www.4wheelparts.com/prodDetail.aspx?partNo=BRW900B586037
    Anyway, the guy said I won't be able to fit ANY aftermarket 15" rim on my truck because of the calipers. Is this true? I find it funny that no one has mentioned this to me in the past.
    Thanks, in advance, for your alls info!!!!
  2. Aug 3, 2010 at 5:39 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Ya I have heard people complain about this before, I have a 96 with 15's but I think when Toyota started making the newer style first gen's they got bigger calipurs.
  3. Aug 3, 2010 at 5:45 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    so get 16's?
  4. Aug 3, 2010 at 6:41 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    you can fit 15s on a first gen double cab...
    there are some wheels though that won't clear the ABS on first gens, so 4WP tends to do a blanket reply that 15s won't fit on a tacoma... it covers them in case there is an issue.. they don't have to take the wheels back cuz they officially disuaded you...
    if you really want the wheels in that size though, you could take a chance and order one to test fit...
    PROseur likes this.
  5. Aug 3, 2010 at 7:35 PM
    dicarlo12181
    but then the $ of the tires are 80 more per tire. Either way, I would rather have 15's.
  6. Dec 8, 2016 at 5:40 PM
    RKH
    RKH Member
    Randy
    96Tacoma
    Ford cobra rims and k&n filter
    Trying to determine "what offset" will work on my 96 Taco extended cab? I currently have 245/45 17s on it with the look I like, but don't know their offset? Also, I want to go to 18x9.5s but unsure if I would have issues (rubbing in front when I turn rubbing the inner fenders in the rear)?
    Any help would be greatly appreciated!!
  7. Dec 8, 2016 at 6:02 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Get 16x8 much better fit
  8. Dec 9, 2016 at 7:46 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    You can determine your back space of your wheel if you take it off and measure with a straight edge of sorts by laying it across the lip of the back of the wheel then put your tape against the flange where your lug holes are (center of wheel) then the measurement from the back of the center of the wheel to that straightstraight edge you layed across the lip of the wheel will be your BS...
