Question about which tires to buy.?
Discussion in 'Wheels & Tires' started by CristianTRD, Feb 5, 2011.
  1. Feb 5, 2011 at 2:17 PM
    CristianTRD
    CristianTRD [OP] Well-Known Member
    Cristian
    Texas
    08 PreRunner TRD
    Ok. I've been reading online and I'm trying to decide which size tires I want to buy. I like the look of the 285/75/16 but I've heard that the give you crappy gas mileage. I'm not a real extreme offroader so it wouldn't really benefit me to get them. It would only be for the looks. If the gas mileage is true about the tires and the cons outweigh the pros, I'll prolly go with 265/75/16.
    Can yall guys tell me the pros and cons of going with the 285/75/16.?
  2. Feb 5, 2011 at 2:19 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    The 285s are taller thus giving you more ground clearance and there also wider thus giving a little better traction in some cases and they look cooler...
  3. Feb 5, 2011 at 2:21 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Yeah. Do you know if they suck on gas mileage.?
  4. Feb 5, 2011 at 2:22 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Cons...
    Piss poor gas mileage, rubbing issues...
  5. Feb 5, 2011 at 2:23 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Yup... wider + heavier = worse MPG
  6. Feb 5, 2011 at 2:30 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    You need a lift for anything taller (or maybe also wider) than 265/75-16 to not have any rubbing...
  7. Feb 5, 2011 at 2:34 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Yeah. Would a 3'' lift be enough lift to fit them with some trimming.?
  8. Feb 5, 2011 at 2:36 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    yes
  9. Feb 5, 2011 at 2:37 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You'll need wheels with a greater back spacing and off set aswell or wheel spacers. 285s will rub on the UCAs
    4.5" Back Spacing with 0 Off Set is Ideal
  10. Feb 5, 2011 at 2:40 PM
    CristianTRD
    Cristian
    Texas
    08 PreRunner TRD
    Really don't have money for wheels. So I guess that answers my question. Probably going with 265/75/16. Thanks Colt and David.!
  11. Feb 5, 2011 at 2:41 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    FWIW...I'm running a 3" Lift with 265/75/16s...I think it looks great :D
