Question for ProComp
Discussion in 'Suspension' started by FLAtacoma05, Mar 25, 2010.
  1. Mar 25, 2010 at 9:56 AM
    FLAtacoma05
    FLAtacoma05 [OP] Well-Known Member
    Wes
    Crestview, FL
    2005 BSP Prerunner DBL Cab
    toytec spacers body lift 315/75/16
    If i get the ProComp 6" kit witht the COs can i adjust them to give me more then 6" in the front?
    or should i build a 6" kit with spindles and COs and UCAs?
  2. Mar 25, 2010 at 6:56 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    well if you use spindles and a coilover, your going to have more ground clearance than if you use a drop bracket kit. one thing to consider is what you plan on using your truck for. if you of road alot then i would go with the spindles and coilovers. if your planning on just using this as a street truck then the drop bracket is an option. all in all pricing is going to be about the same. spindles 995+ coilovers 995+ 3inch leaf springs 395+ rear shocks 3-400 total is gonna be roughly 2600+, same as using a drop bracket with coilovers from procomp and 3k for fabtech. dont quote me on prices those are just numbers that i remember from when i was looking around.
  3. Mar 25, 2010 at 8:02 PM
    FLAtacoma05
    Wes
    Crestview, FL
    but could you adj the COs on the rocomp to go higher than 6" total???
  4. Mar 25, 2010 at 9:00 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    i don't think so, and if you could it would ride like shit because you would have the coilovers jacked so high.
  5. Mar 25, 2010 at 9:14 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    for the coilover db the cheapest i found was 2350
  6. Mar 25, 2010 at 9:17 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    +100000000000000000 for the spindle idea. 6" dont give you more ground clearance whereas a spindle lift and even maxing out a coilover at 3" will give you 6.5"+ of actual clearance :) love my spindles and would definetly recommend to people to save for them instead of coilovers :D though idk why you need to really go above maybe 5", that will fit you some very nice tires
  7. Mar 26, 2010 at 8:44 AM
    FLAtacoma05
    Wes
    Crestview, FL
    this is tough... i can save about 500 with the kit or spend 500 more and do the spindle/CO lift
  8. Mar 26, 2010 at 8:46 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    yes you can get and a inch or so higher if you want with out the cv angle being to bad
  9. Mar 26, 2010 at 8:46 AM
    bajamoon
    STEVE
    Whittier
    ya about 2000 for spindle/coilover lift. but you will need to do something in the back to, it will be nose high
  10. Mar 26, 2010 at 8:47 AM
    FLAtacoma05
    Wes
    Crestview, FL
    i dont have to worry bout CVs im a prerunner
  11. Mar 26, 2010 at 8:47 AM
    FLAtacoma05
    Wes
    Crestview, FL
    I know its recomended to get UCAs, do i have to? which kind?
  12. Mar 26, 2010 at 8:48 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    ahh even better than you can go higher but the ride will not be the same with a set of uca's you could get some ride back im sure
  13. Mar 26, 2010 at 8:49 AM
    FLAtacoma05
    Wes
    Crestview, FL
    do i need drop brackets for a prerunner? i knowi dont need the cross member that comes with the procomp kit
  14. Mar 26, 2010 at 8:51 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
  15. Mar 26, 2010 at 8:52 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    no you need it you just dont need to cut the back frame cross member like a 4X4 does
  16. Mar 26, 2010 at 8:57 AM
    FLAtacoma05
    Wes
    Crestview, FL
    oh gotcha. thats a good price on those UCAs but i may go with LR to save a lil cash
  17. Mar 26, 2010 at 8:59 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    the light racing are pretty nice i have helped put a few in they have a nice big ball joint on them and should be fine with a procomp lift
  18. Mar 26, 2010 at 9:01 AM
    FLAtacoma05
    Wes
    Crestview, FL
    think im leaning towards the spindle/co lift. thatd be a better ride dont you think?
  19. Mar 26, 2010 at 9:02 AM
    FLAtacoma05
    Wes
    Crestview, FL
    more travel to so i could clear bigger tires
  20. Mar 26, 2010 at 9:03 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    never been in a spindle lifted truck but i would think it would be nice and kinda like stock with a prerunner i would go that way for sure
