Question for Suspension Gurus.....and anyone else :)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jproffer, Jul 9, 2020.
  1. Jul 9, 2020 at 9:29 AM
    jproffer
    jproffer [OP] Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    I'm looking to upgrade my suspension. Not necessarily lift, but maybe level. Right now I'm on stock coilovers and shocks and stock height, which of course means the truck takes a little bit of a nose dive. I'd like to bring the front up out of that nose dive, but keep the back relatively the same.
    So...
    Based on what I've seen, this is what I'm thinking...
    Bilstein 5100 all around and OME88x coils. The adjustable perch up front, obviously. Set the perch on the lowest notch....maybe...with OME 88.........4? 3? I'm sure there may be several combinations that would give about the same inch or so of "lift" to level it out. Maybe Low notch with 884?...second notch with 883? Believe me, I'm asking not telling lol...that's just where my mind went when I was thinking about it.
    So, question is which combination is best. No off-roading (other than the fact that I live in Illinois....and these roads....holy shit). Just every day driving...95%+ on pavement.
    Low notch + 884s?
    Second notch + 883s?
    Some other setup that I'm not experienced enough or smart enough to think of?
    Any thoughts appreciated.
  2. Jul 9, 2020 at 9:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do a search in “forums”, “suspension”
    caffeinated_medic likes this.
  3. Jul 9, 2020 at 9:37 AM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    ^^^^^^:thumbsup:
  4. Jul 9, 2020 at 9:38 AM
    caffeinated_medic
    caffeinated_medic Well-Known Member
    Virginia
    '08 TRD OffRoad PreRunner, '18 TRD OffRoad
    FWIW I'm going with 5100's with 885's, that's after spending a loooooong time reading threads in the suspension section. Marie at @HeadStrong Off-Road gave me alot of valuable input, as did a few TW members local to me. But hit up the suspension threads first, it will take some time.
    Look down the road (no pun intended) at what your end goal is with the truck - are you going to want armor, a cap, RTT, etc. that way you avoid having to buy twice.
    jproffer[OP] likes this.
  5. Jul 9, 2020 at 9:51 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Remember its your truck at the end of it all. Decide what you want to get out of it. Grocery getter, mall crawler (what most of us have haha) or if you want to go to the extreme. Then go from there. Do it right and do it once and trust me you will be much happier and better off.
  6. Jul 9, 2020 at 9:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you dont really want a lift or just a lil closer to level. 5100's all around, stock coils set at the .85 notch (1st notch up from the bottom) and call it done.
    TnShooter and jproffer[OP] like this.
  7. Jul 9, 2020 at 10:37 AM
    jproffer
    Jim
    Perryville, MO
    Hmmm, that would save the money on the coils, assuming my current coils are good...which I assume they are.
  8. Jul 9, 2020 at 10:39 AM
    jproffer
    Jim
    Perryville, MO
    I have searched, but there is a LOT of information to sift through lol. I'll go through it again with my present mindset (level, not lift) and see what happens.
    Thanks to all for comments and suggestions.
  9. Jul 9, 2020 at 12:34 PM
    nd4spdbh
    SoCal
    I dont think i have ever heard of OEM coils going bad, hell they dont really even settle at all like the aftermarket ones from OME / eibach etc.
  10. Jul 9, 2020 at 5:28 PM
    jproffer
    Jim
    Perryville, MO
    Misunderstanding.... Right now I have stock coils (unless stock is OME). I was looking at getting OME88x to get the 1-2" leveling lift.
  11. Jul 9, 2020 at 7:16 PM
    nd4spdbh
    SoCal
    OME = Old Man Emu
    OEM = Original Equipment manufacturer (the stock factory coils)
    So yeah, stock (aka OEM) coils dont tend to go bad.
  12. Jul 9, 2020 at 7:19 PM
    jproffer
    Jim
    Perryville, MO
    HAHAHA....I misread your post :) . Roger that....OEM is stock....OME is what I'm considering.
  13. Jul 9, 2020 at 7:21 PM
    caffeinated_medic
    Virginia
    Not the first time that’s happened, won’t be the last.
    Time to start a trend and just call OME “Emu’s”
    jproffer[QUOTED][OP] likes this.
  14. Jul 10, 2020 at 5:24 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Find a set of 3rd gen take offs. That give you an inch while leaving the perch on the lowest setting.
    I tow a boat, so I wanted to keep the take. Icon 3 leaf progressive aal with the overload leaf removed. That gave me 1.5" in the rear.
    I've got over 300k on my truck. I figured the front coils were getting soft by now, and found coils cheap in the 3rd gen marketplace.
