Question for the guys who launch boats
Discussion in 'Towing' started by Fishtac0, Jun 30, 2015.
  1. Jun 30, 2015 at 8:53 AM
    Fishtac0
    Fishtac0 [OP] Member
    2015 or
    So I just bought a 2015 off-road 4x4. Waited till I put about 2000 miles before towing. I tow a 16ft bass tracker to the ramp and back about 8 miles round trip. He's my question when I launch the boat pull the trailer out( no boat on trailer) truck pulls out fine. Now when pulling the boat out of the water on the trailer putting the truck in drive truck wants to roll back a little (automatic trans) and stepping on the gas makes the traction control kick in( light starts blinking) (and not pounding on the gas either) I can hear a grinding effect when the transmisson is first starting to engage. Anyone else have this problem? And forgot to add there is a incline on the ramp too. Tia tacoma world
  2. Jun 30, 2015 at 8:58 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Put it in 4lo:notsure:
    much easier on the truck
  3. Jun 30, 2015 at 8:59 AM
    Ugly Betty
    mark
    TX
    And I always start giving it a lil gas while ebrake is still on then pop the ebrake
  4. Jun 30, 2015 at 8:59 AM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    Yep
  5. Jun 30, 2015 at 9:00 AM
    S and J
    S and J Well-Known Member
    Scott
    Las Vegas
    2015 AC SR5 Off Road Package
    I've never had a problem. I use 2wd in 4 and it pulls right out
  6. Jun 30, 2015 at 9:02 AM
    Fishtac0
    2015 or
    I have an 89 pickup I pull the same boat out in in 2wd I don't see why I would need to go in 4lo the incline isn't that bad. But I'll try and see next time.
  7. Jun 30, 2015 at 9:03 AM
    Houston
    Houston Well-Known Member
    Texas
    2015 MGM DCSB TRD Off-Road
    Off topic really quick, and stupid question but I noticed with my new '15 4x4 OR that break pedal has an audible squish sound when I push on it during normal driving, is that from this combination too? Again, sorry for the stupid off topic question.
  8. Jun 30, 2015 at 9:03 AM
    Fishtac0
    2015 or
    Thank you rock lobster didn't even think about that.
  9. Jun 30, 2015 at 9:04 AM
    Houston
    Texas
    Figured as much, thought I'd throw it out there any way. Thanks.
  10. Jun 30, 2015 at 9:05 AM
    Ugly Betty
    mark
    TX
    I dunno, is just what I do
    Fishtac0[QUOTED][OP] likes this.
  11. Jun 30, 2015 at 9:24 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The stock BFG Rugged Trail tires on current-gen TRD Off Road trucks are crap on everything except dry pavement.
    You can also turn off the throttle-limiting "feature" of the traction control system by pressing the VSC button once. The auto-LSD light will come on in the dash.
  12. Jun 30, 2015 at 9:42 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    No need whatsoever for 4 lo at an improved public boat ramp...pretty much ever. I have only needed 4 high occasionally in the dead of winter when a ramp is coated with ice or on steep, wet, unimproved loose cobble launches on a river. With an auto trans just put your left foot on the brake pedal, release the e-brake, and ease on the gas as you ease off the brake. Works the same with a manual trans except it's the e-brake that eases off as the throttle is increased. The rear dif breather mod is something to really consider doing if your ramps have a shallow slope and your rear dif takes a bath.
  13. Jun 30, 2015 at 9:48 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    its not a problem, its a built in feature of your truck doing its job. It scared the crap out of me the first time mine went off. The grinding noise/beeping made me think something broke.
  14. Jun 30, 2015 at 10:44 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Never spun a tire on any ramp with my Prerunner or current truck and I have a much heavier boat. I am guessing you are a little heavy on the throttle.
  15. Jun 30, 2015 at 12:18 PM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I've launched a 17.5ft bass boat, and a 20ft deep V fish and ski tracker using my Tacoma. I've never had an issue with anything. I use 2 wheel drive.
  16. Jun 30, 2015 at 2:00 PM
    2010TRDtaco
    2010TRDtaco Well-Known Member
    James
    Oklahoma, muskogee
    2012 TX baja DCSB AT barcelona red
    Warn winch, body armor rear bumper, 2x yellow top optima, color matched wheel bead, weather tech mats, ams oil everywhere, De-badged, hard wired radar detector, rear diff. breather extension, k+n, fog light any time, trailer wiring relocate, iridium plugs, LED grill marker lights,
    i always hold my brakes a little bit to keep from rolling back, and give it a little gas to get moving then let off the brakes .2
  17. Jun 30, 2015 at 2:54 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Not knowing what the launch looks like it's hard to know what's really happening but I regularly tow a boat and trailer that weighs ~1200lbs or so and what I do, like 2010TRDtaco, is to press the gas a little before letting off the brake to keep it from rolling. Some ramps are dirt and loose gravel so I throw it in 4wd HI and I am fine. I also use it as a time to exercise the 4wd lo and the locker sometimes too. Don't need it but it's a good excuse to use it.
  18. Jun 30, 2015 at 3:08 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    What? :notsure:
  19. Jun 30, 2015 at 3:10 PM
    S and J
    Scott
    Las Vegas
    That wasn't well thought out...I used 2wd in D and it's fine.... :anonymous:
  20. Jun 30, 2015 at 4:24 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    No worries :thumbsup:
