Question how can I remove paint from
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WolvPro, Dec 8, 2019.
  1. Dec 8, 2019 at 5:35 AM
    WolvPro
    WolvPro [OP] Member
    2009 Tacoma Prerunner 4x2
    6" inch lift, 2015 sport front clip swap
    I got my 08 Tacoma used. The bed in the truck a painter used it for work as there is about 4 different colors of leaked and splattered paint all on the sides of the bed inside and a lot on the floor pan of the bed. I have tried a pressure washer to it and it removes the thicker stuff but the left over white colors are like embedded. Is there anyone that can offer me a safe way to remove the paint without damaging the composite bed? I’m looking at like maybe a chemical I can spray or brush on then pressure wash off? Any advice would be appreciated thanks guys.
  2. Dec 8, 2019 at 5:39 AM
    doorsidedown
    doorsidedown Well-Known Member
  3. Dec 8, 2019 at 5:39 AM
    WolvPro
    WolvPro [OP] Member
    I’ll check it out. Thanks and anymore advice from others?
  4. Dec 8, 2019 at 5:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    My suggestion would be to put on a tonneau to hide the inside of the bed, then enjoy using the bed when needed with no concern for the normal wear and tear that will occur.
    TacomaUSA likes this.
  5. Dec 8, 2019 at 5:40 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How about going the other way and giving it a coat of bed liner.
    jungleman likes this.
  6. Dec 8, 2019 at 5:45 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    My wife spilled a gallon of paint in my other Tacoma. I thought it was water based so immediately tried to power wash it out while it was wet. It was il based and splatterd all over the bed. i ended up letting it dry and then power washing out the big stuff then I spray painted the sides with a good satin black paint and threw a bed mat on the floor and it looked all new again.
  7. Dec 8, 2019 at 6:04 AM
    DG92071
    DG92071 Well-Known Member
    I would try acetone and a brush. Or paint over it.
  8. Dec 8, 2019 at 6:17 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Try the least harsh chemicals first then move on. Start with bug and tar remover, goo gone, kerosene, etc. But be careful what you use doesn't harm the paint on your truck because there will probably be runoff from cleaning the bed- even if you are careful.
    I had good luck with bug and tar remover while cleaning off yellow line paint from the road. The cleaner worked better on the paint than the mudflaps bc the mudflaps are porous. I'm guessing you are having trouble inside the bed bc the polymer is porous. Try using a hard plastic scraper (ice scraper, window tint spatula, plastic scraper for cleaning dishes) or maybe even a nylon brush or razor blade.
    All that being said I would probably just live with it. I don't abuse my bed but I do use the hell out of it.
    +1 on the bed mat. One of the best things I bought for the truck.
    Goodluck OP
  9. Dec 8, 2019 at 6:27 AM
    WolvPro
    WolvPro [OP] Member
    Thanks guys for the comments! Love the site! I will try a few of these ideas and if I cant get it out them I will just flat black the sides and put a Mat in. Thanks guys!
  10. Dec 8, 2019 at 9:23 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If it’s water based paint a good steam machine should break it right down and wash it out.
    desertrunner24 likes this.
  11. Dec 8, 2019 at 9:24 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Find a local pressure washer company with heaters and let them blast it out. HOT water and 3500 PSI does wonders.
  12. Dec 8, 2019 at 9:25 AM
    gotoman1969
    Yep, the heat makes a huge difference.
  13. Dec 12, 2019 at 10:09 AM
    96carboard
    96carboard Well-Known Member
    I think paint STRIPPER should be fine on it, but test at an inconspicuous spot to make sure.
  14. Dec 12, 2019 at 10:10 AM
    96carboard
    Not meaningful since the bed is not made of plastic in the conventional sense.
    Its polyester fiberglass like a boat hull.
  15. Jan 6, 2020 at 3:43 PM
    WolvPro
    WolvPro [OP] Member
    Thanks for all of the replies! Its coming off but alot of elbow grease!
