Question on 5100s w/ Eibach Springs
Discussion in 'Suspension' started by NumNutz, Feb 9, 2010.
  1. Feb 9, 2010 at 8:38 PM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I ordered my Eibach lift springs with 5100s set at .85".
    When redz and silver07taco went to install them they saw a problem with my coils hitting my sway bar. They also thought that U-bolts were too short to be used with my TSB AAL. So they said go buy a sway bar relocation plate and longer U-bolts.
    When I called ToyTec they said that I didn't need either. That the coils would fit just fine and that my stock U-bolts were long enough.
    What does everyone think?
  2. Feb 11, 2010 at 4:26 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    You're supposed to set the billys to 0" of lift...the stock setting.
  3. Feb 11, 2010 at 9:37 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    The rear TSB AAL didn't come with new U-bolts for me.
    I'm asking if I need new U-bolts and if I need a sway bar relocation plate.
    I know that it is safe to set my billys at .85".
  4. Feb 12, 2010 at 5:43 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    answer is NO.
  5. Feb 12, 2010 at 6:10 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Actually you may need to do the sway bar relocator. I had the same issues originally. Put them on and viola' no problems. When I installed my TSB's/plus AAL I also had to use longer u bolts. I got them from TruckSprings.com
  6. Feb 12, 2010 at 6:22 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Do you have experience with this specific kit?
    So you thought you might rub the sway bar but you ended up not?
    You got the TSB spring and an AAL spring? I'm just getting one spring, the AAL.
    If I got both parts, with shipping it's close to $100. I really want to get it done but rather not spend the money if I don't have to.
  7. Feb 12, 2010 at 8:52 AM
    badguybuster
    Michael
    I did rub the coils so my relocate was necessary. Oh, no. When I did the AAL on stock springs, I DID NOT need longer bolts.
  8. Feb 12, 2010 at 10:14 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Nick got a lift! Who is gonna take pics if you are driving your truck at Rausch?
  9. Feb 12, 2010 at 10:48 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I have 1.6" Eibach's, the 0.5" Toytec top plate spacer, and 5100's set at 0". Even though this setup technically should give me 2.375" of lift, it actually only gave me 2". The front is a hair higher than my rear TSB. My sway bar does not rub. However, my UCA's do hit the coil at full stretch.
    I'm getting 285's tomorrow, so next week I'm calling in sick a day and bumping my 5100's up to 0.85" which should put me up in the 2.75"-3" range. I also am adding a Wheeler's Off Road 1.5" AAL and a 2* shim. I had about 0.5" of thread showing at the bottom of my u-bolts. This would have been enough for the 0.375" thick leaf. It is not enough for the leaf and shim though so I have some new u-bolts coming too.
    Now of course I'm going to need UCA's too. Oh, the death spiral of modifications.:annoyed:
  10. Feb 12, 2010 at 12:09 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Okay so I do need a sway bar relocate plate.
    But I DON'T have the TSB spring. I only have the TSB AAL. So I don't need new U-bolts, or I do?
    I might do a green trail or two but it's still mostly a sand and snow truck. Not too into bashing a $20K truck on rocks and stuff.
    I DON'T have the TSB spring. I only have the TSB AAL from ToyTec. Are you saying that you think I do need new U-bolts?
  11. Feb 12, 2010 at 2:46 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Nick look under your truck at your u-bolts the u-bolts dont even come out the bottom of the bolt. I dont care what anyone has to say be safe and spend a little extra money.
  12. Feb 12, 2010 at 5:05 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I don't have a problem spending the extra money. Redz told me to post the question so I did. $100 bucks is $100 bucks though so I wanted to make sure I need it. I didn't realize my U-bolts were that short. I was so pissed I didn't have all the parts I needed I just took your word for it.
  13. Feb 12, 2010 at 6:23 PM
    silver07taco
    COIL
    Maryland
    Right on
  14. Feb 12, 2010 at 6:33 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    As long as you've torqued it properly and you have threads showing past the nuts, you're good. If you're adding something like a leaf (about 3/8" thick), you're going to want like a 1/2" of threads showing pre install.
  15. Jan 3, 2012 at 6:13 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    Front should be good to go with the sway bar and your coils. No need for the relocation bracket.
    Dont know about the leaf springs because I don't feel like thinking right now.
    Im not far from Cornell, let me know if you need help. I have the eibachs at .85 btw.
  16. Jan 4, 2012 at 6:09 AM
    seth22
    seth22 Member
    Montgomery AL
    09 White PreRunner,
    I just Installed this same setup and i didn't use the relocation bracket or longer u bolts. My truck rides fine.
