Question on Jacking front end.
Discussion in 'Suspension' started by sac130e, Apr 22, 2011.
  1. Apr 22, 2011 at 7:43 AM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    About to do the front end shock/uca replacement and wondering about the best jacks to use and placement. I will have to go buy this stuff, but wondering where to get quality jack/stands.
    When you jack front, where does everyone place jack to lift front, or are you lifting one side at a time and placing on jack stands. I have no issues working on the truck, only concern is working under a supported truck.
    Want to ensure everything is stron and in correct position before I get under it.
    Thx
  2. Apr 22, 2011 at 7:55 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just jack the truck from the front cross member and place the jack stands at far forward on the frame as possible. Once you put the jack stands in place lower the floor jack to put the load on the jack stands you can leave a little pressure on the floor jack as well so that you have three support points. As for jacks and stands just a large floor jack and jack stands I would go with at least 3 ton models.
    Here is some shots of the jack stand placement.
  3. Apr 22, 2011 at 9:42 AM
    sac130e
    Scott
    Milton, FL.
    Thx, since it could be up there for 1-2 days (I like to take my time)
    Want to be sure no risk of falling. Who sells good jacks/stands (Lowes,
    Home depot..)
    Thx
  4. Apr 22, 2011 at 9:48 AM
    JLee
    Jerry
    Benicia, CA
    Sears I don't know about Lowes but the Husky ones at Home Depot are not the greatest Cosco has nice ones you might want to check there.
  5. Apr 22, 2011 at 9:52 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I put the stands the same place as J-Lee. As for stands I have 6ton harbor freight ones. They work great, very tall and I've never heard one bad thing about them. For a floor jack my dad has always had craftsman they always seem to leak, they work well though. Just make sure what you get is tall enough. I'm sitting at a little less then 2" of suspension lift and my tires give another 2" of clearance and the bottom of my frame is just over 17" to the ground.
  6. Apr 22, 2011 at 10:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I agree with the placement of those jack stands. If you are in Milton, FL the other option is (if you have someone who can pick you up) is to use the Auto Hobby Shop at Corry Station.
    I did my entire lift install there (I work quick-so it was just one day) but you can leave projects there usually. Unless this install is a reason/justification for you to buy the stuff.....Then ignore my suggestion.
  7. Apr 22, 2011 at 8:06 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I say 4 ton stands at least. The HF 6 ton ones are nice too, I'd go with them probably.
  8. Apr 22, 2011 at 8:15 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
  9. Apr 23, 2011 at 11:22 AM
    sac130e
    Scott
    Milton, FL.
    Wonder if I can rent the jack from local auto zone. Only plan to use this once,
    So no need to buy it to just let it sit and collect dust. Maybe pick it up at
    Wally world..use it and return it.
    Thx
  10. Apr 23, 2011 at 11:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    AUTO HOBBY SHOP @ CORRY STATION if you aren't trying to get equipment to keep.
    It'll cost you 30-50 dollars and you'll have everything you need.
  11. Apr 23, 2011 at 12:04 PM
    sac130e
    Scott
    Milton, FL.
    What/where is Corry Station? Don't want to drone to far for this stuff..thx
  12. Apr 23, 2011 at 12:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    640 Roberts Ave., Pensacola, FL 32511
    It's just a little northwest of NAS Pensacola. Corry is one of the annexes for the Navy Base and is where the Auto Hobby shop for the area resides.
    I didn't look at your military icon until just now where it says retired..but if you can get on base you can use the shop. Prevents you from having to buy stuff you don't plan on keeping.
