Question on Lighter Crank Pulley
Discussion in 'Technical Chat' started by tacoskim, Oct 1, 2008.
  1. Oct 1, 2008 at 2:42 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    does anyone know if a lighter (but same size) crank pulley is safe for a daily driver truck?? to me it sounds like since its the same size it will be a good investment, but i dont think in the long run if u want ur engine to last as long its not a good idea. am i wrong?
    whats ur guys thoughts??
  2. Oct 1, 2008 at 6:25 PM
    1-3-2-4 Squirrel Mincer
    Ithaca, NY
    06 Titan King Cab
    A.R.E. tonneau cover
    The size (diameter) of the crank damper will have a minimal effect on performance. The only real reason to make the pulley smaller is to underdrive the accessories (spin them slower) and to make it lighter.
    Will the new pulley adversely affect engine life? Could. I've used lightened crank pullies on two of my cars with good performance gains. However, I never owned the car long enough to see any real damage. There is one reason and one reason alone OEMs install crank dampers: crankshaft durability. If the engineers who designed that crankshaft weren't concerned with the life of the crank, they would have saved the money. Every crankshaft has a different resonant signature (I4's are different than V6, V8, H4, etc.). I can say that V6 engines are not an inherently smooth running engine.
    That being said, YMMV because it really depends on your drive cycle and expectations. If your driving doesn't involve running the engine at the crankshaft's natural frequency, you won't have much of a problem. Or, if you only plan on keeping the truck for a short amount of time, you probably won't have any issues. If you are concerned with either case, save your time and don't worry about the few ponies.
  3. Oct 1, 2008 at 7:25 PM
    tacoskim
    Los Angeles, CA
    Stock
    thanks 1234, im guessing its more of a gain for the manual folks to make up for the acceleration through gears 1 and 2. i was just looking for something to make up for my loss of back pressure. i plan on keeping this truck till a tacoma hybrid comes out :pray: so if its gonna ruin the engine in the long run then might not be a good idea
  4. Oct 2, 2008 at 4:45 AM
    Ithaca, NY
    06 Titan King Cab
    Like I said, there are no guarantees. But the info I provided on the dampers purpose is verifiable. Its a personal choice.
  5. Oct 26, 2008 at 6:30 PM
    Shanes56
    Shanes56 Sittinsic.com Vendor
    WI
    07 BSP X-Runner Sittin Sic
    Ask and I will tell you... Sittin Sic Drop Leafs and Coils
    This is a very good question but one thing to keep in mind is the 4.0L V6 1gr is internally balanced, so the notion of a harmonic balancer to keep the vibration from hitting certain frequencies is inaccurate concerning this motor being that the OEM crank pulley does not have a harmonic balancer. So there would be no need for worry :D
    Unless I completely misunderstood what 1-2-3-4 was referring to
  6. Oct 27, 2008 at 5:56 AM
    Ithaca, NY
    06 Titan King Cab
    Every engine sold today is internally balanced. That phrase may have been important 50 years ago, but not today. That is like saying your new truck comes with tires - it better!
    Concerning crank dampers, most if not all, engines today have them. I personally haven't looked at the V6's pulley, but my I4 has one...along with every other engine I've ever owned (except for my 83 GTI). If the crank pulley has a rubber layer impregnated between two masses, it is a harmonic balancer. Of course, if there really is no damper, you won't miss it by installing a lightweight pulley. It is possible you could aggravate cam chain wear, but I wouldn't bet money on it, especially in the short run. I'm betting it has one, though. V6 engines are harmonic nightmares.
