Question on offset and backspace
Discussion in 'Wheels & Tires' started by 10PreRunner, Mar 16, 2011.
  1. Mar 16, 2011 at 2:04 PM
    10PreRunner
    10PreRunner [OP] Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    The wheels I am looking at have a -6 offset. What does that mean related to the backspace. I know I want my wheels to stick out a little.
  2. Mar 17, 2011 at 5:46 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It depends what the width of the rim is. Backspacing is calculated using width and offset.
  3. Mar 17, 2011 at 8:00 PM
    10PreRunner
    Kevin
    Here are the specs of the wheels I have in mind. Tell me what you think and how much you thing they will stick out. Thank you for your help. Nice truck by the way.
    16x8 with a -6 offset. Thats all it says.
  4. Mar 17, 2011 at 8:01 PM
    KPT
    09 Prerunner
    Thanks.
    Those are 4.25" backspaced (stock is 5.5") They are also 1" wider than your stock rims. So they will stick out a total of 2.25" further than your stock rims do.
  5. Mar 17, 2011 at 8:05 PM
    10PreRunner
    Kevin
    How much do your stick out. Yours is what I think I want
  6. Mar 17, 2011 at 8:06 PM
    KPT
    09 Prerunner
    Mine are 18x9"s with 5.4" backspacing. So they stick out 2.1" more than stock.
  7. Mar 17, 2011 at 8:14 PM
    10PreRunner
    Kevin
    Ok one more question and then I will leave you alone. 16x8 3 5/8 backspacing and -22 offset. And then 16x8 4 7/16 backspacing and 0 offset. How much will those stick out? I promise thats it.
  8. Mar 17, 2011 at 8:16 PM
    KPT
    09 Prerunner
    The first ones will stick out a bit over 3" from stock, which will likely be too much, and could cause the outside of the tires to scrub while turning.
    Second ones will stick out 2" more than stock, and are the ideal specs to run 33's on.
  9. Mar 19, 2011 at 10:54 AM
    802YOTA
    802YOTA Well-Known Member
    Scotty
    Vermont
    03 Tacoma SR5 TRD
    LEAF SPRUNG SAS, 5" inch springs 5" shackles. Tacoma HIGH STEER, CHERRY BOMB 3" Straight pipe, TRIPLE CASES, 5.29s, (yeah she crawls) LOCKED FRONT AND REAR, Custom square stock front driveshaft 13" slip(been there for a year and hasnt failed yet.), Ruff Stuff 8 inch Perches, 2" RB body lift, K&N intake, Zoom high performance Kevlar clutch, herculined flares and rockers, trail gear rock sliders, rock lights.
    OK i got one for you if you dont mind answering it? 16x8 4.25 backspacing and 285's vs 265's with the tires stick out 1" farther than the wheels? for a total of 3.25"s?
  10. Mar 19, 2011 at 11:09 AM
    KPT
    09 Prerunner
    285's are an 11.2" wire tire, while 265's are a 10.4" tire. So 265's would stick out approx 1.2" from the wheels on each side (10.4-8)/2
    (11.2-8)/2 is 1.6" so 285's will stick out 1.6" on eac side of the wheel.
