Question regarding 1/4" Toytec spacer for 1st Gen owners
Discussion in '1st Gen. Tacomas (1995-2004)' started by FuTang909Inamo, Oct 21, 2009.
  1. Oct 21, 2009 at 1:13 AM
    FuTang909Inamo
    FuTang909Inamo [OP] Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Did the spacer correct the driver side lean on your 1st gens? Or are coilovers the only answer for this "issue"? I have an '03 DC by the way.
  2. Oct 21, 2009 at 6:16 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    It's supposed too but its not guarenteed since everyones truck, add-ons, weight, spring sag and etc is different. I was in the same boat. I debated months over Bilstein 5100 Adjustables, spacers and coilovers. I eventually decided to go with coilovers.
  3. Oct 21, 2009 at 6:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 1/4" spacer will give you 1/2" of lift.
    So, if your truck is leaning 1/2" or so - then it'll help.
    Every situation is different and if you have a full tank of gas, it'll lean even more.
    When I had my 96 tacoma, I dealt with the lean for a long time and tried all sorts of differen things to try and correct it. I finally got OME 881 coils up front that actually made it look a lot better.
  4. Oct 22, 2009 at 2:09 AM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    Are the OME coils different lengths for the first gens? Or is it just your OE coil sagging from use? Yea my truck is leaning about 1/2" so I guess just slap the spacer on and hope for the best. Thanks Janster
  5. Oct 22, 2009 at 6:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The OME coils are not side specific.
  6. Oct 22, 2009 at 7:20 AM
    Janster
    Jandy
    Lancaster, PA
    As Chris mentioned - the OME coils are not side specific and they're both the same length.
    I'm not sure why the tacomas lean and I can't comment about the OE coils.
    I installed a Rancho 1.5" lift kit (that was back in 99) and my truck developed the lean after that. I had the Rancho kit on for about 2 years or so before going with the OME coils. For some reason - the OME coils did a better job at preventing most of the lean. Rancho stuff really sucked and shocks wore out quickly & leaked.
